POV-Ray : Newsgroups : povray.newusers : Radiosity troubles in POV. Server Time
10 Aug 2025 02:34:39 EDT (-0400)
  Radiosity troubles in POV. (Message 1 to 10 of 12)
Subject: Radiosity troubles in POV.
Date: 5 Aug 1998 20:48:51
Message: <35C8EDB5.F9F83764@geocities.com>
I have recently been experimenting with radiosity in POVRay but have had
no success. I am using Moray to control the radiosity settings in a
simple courtyard scene I created to test (based on this image:
http://www.lightscape.com/Contest98/az_honor.jpg, but just a bare bones
version). My problem is that the radiosity rendering is no different
from the raytraced rendering (yes I set POV to radiosity mode). That is,
it does not change any of the areas not lit by direct light, just one
big ambient colour mess, I can't make out any details in it, just what
would happen if I rendered without radiosity. So what am I doing wrong
(Other test renderings of other scenes have similar results)? HELP!!!
Thanks,
Chris Maryan
mailto:cma### [at] geocitiescom
My ideas are free,
Work is at least minimum wage.
Email me if you are interested in donating
to the Chris Maryan needs money fund,
Subject: Re: Radiosity troubles in POV.
Date: 6 Aug 1998 07:19:11
Message: <35c9831f.0@news.povray.org>
In povray.general Chris Maryan <cma### [at] geocitiescom> wrote:
: I have recently been experimenting with radiosity in POVRay but have had
: no success. I am using Moray to control the radiosity settings in a
: simple courtyard scene I created to test (based on this image:
: http://www.lightscape.com/Contest98/az_honor.jpg, but just a bare bones
: version). My problem is that the radiosity rendering is no different
: from the raytraced rendering (yes I set POV to radiosity mode). That is,
: it does not change any of the areas not lit by direct light, just one
: big ambient colour mess, I can't make out any details in it, just what
: would happen if I rendered without radiosity. So what am I doing wrong
: (Other test renderings of other scenes have similar results)? HELP!!!
  Radiosity parameters are really dificult to understand. I don't understand
them very well. You have to read the povray documentation very carefully to
get the right values.
  I have been playing with radiosity as well, but with much better results.
You can check them at http://www.iki.fi/warp/pics/Radiosity_test/
  I can post the radiosity values of those images if you want.
                                                              - Warp. -
Date: 6 Aug 1998 15:04:34
Message: <35C9EEAC.2B1170FA@geocities.com>
Your images do a great job of showing what radiosity does, are you using
area lights in the top two images?
Thanks for your help but I solved the problem, apparently some kind of
bug (see my other post to povray.general on this thread).
Does anyone know how I can increase the amount of light being diffusely
reflected by a texture without raising the ambient level (My scene has a
wide range of contrast and if I keep the ambient low, there isn't enough
detail in the shadows, if I raise the ambient, the bright areas become
pure white, I need brighter shadows and darker highlights(I never
thought photography would come back to haunt me :-) ).
Chris Maryan
My ideas are free,
to the Chris Maryan needs money fund.
Date: 7 Aug 1998 07:07:13
Message: <35cad1d1.0@news.povray.org>
: Your images do a great job of showing what radiosity does, are you using
: area lights in the top two images?
  Yes.
                                                              - Warp. -
Date: 7 Aug 1998 10:39:28
Message: <01bdc208$cb4d2740$a142a8c2@wphnvffu>
Yes Please
Mike Hazelgrove
Nieminen Mika <war### [at] assaricctutfi> wrote in article
<35c9831f.0@news.povray.org>...
had
is,
understand
to
results.
>                                                               - Warp. -
Date: 7 Aug 1998 13:23:57
Message: <01bdc21f$b1868600$639728a1@1733773.unitedspacealliance.com>
results.
Very nice, very helpful. I would be interested in seeing the values you
used.
Jon
Date: 12 Aug 1998 10:15:59
Message: <35d1958f.0@news.povray.org>
In povray.general Jon Berndt <jsb### [at] hal-pcorg> wrote:
: Very nice, very helpful. I would be interested in seeing the values you
: used.
global_settings
{ ambient_light <1,1,1>*4
  radiosity
  { brightness 8
    count 400
    distance_maximum 1
    error_bound .2
    gray_threshold .1
    low_error_factor .5
    minimum_reuse .001
    nearest_count 6
    recursion_limit 1
camera { location -z*17 look_at 0 }
// Room
difference
{ box { <-12,-9,-19><12,9,12> }
  box { <-11,-8,-18><11,8,11> }
  pigment { rgb <1,1,.8> }
box
{ <-11,-8,-18><-10.99,8,11>
  pigment { rgb <1,.5,0> }
box
{ <11,-8,-18><10.99,8,11>
  pigment { rgb <0,.5,1> }
                                                              - Warp. -
Date: 15 Sep 1998 05:16:48
Message: <35fe2270.0@news.povray.org>
I'm having the same problems with radiosity not working, with the exception
that mine works -some- of the time. I recall once that radiosity worked
after I removed one line, and that was the  -ambient_light Black - line.
Then I put it back and it rendered with radiosity fine. I've yet to find a
pattern to radiosity not working after having tried over 75 renderings on
the same scene with small modifications. I used the settings below, having
the scale of my scene approximately that shown, and it did not correct any
problems. Is there a bug I should know about that may be causing this?
-D.J. Brown
Nieminen Mika wrote in message <35d1958f.0@news.povray.org>...
>: used.
>global_settings
>  radiosity
>  { brightness 8
>    count 400
>    distance_maximum 1
>    error_bound .2
>    gray_threshold .1
>    low_error_factor .5
>    minimum_reuse .001
>    nearest_count 6
>    recursion_limit 1
>// Room
>difference
>box
>box
>                                                              - Warp. -
Date: 15 Sep 1998 07:33:52
Message: <35FE42E4.58A73427@pacbell.net>
HEY everbody ! Povray is now answering questions on this group.
WOW !
Ken
> -D.J. Brown
> >: used.
> >global_settings
> >  radiosity
> >  { brightness 8
> >    count 400
> >    distance_maximum 1
> >    error_bound .2
> >    gray_threshold .1
> >    low_error_factor .5
> >    minimum_reuse .001
> >    nearest_count 6
> >    recursion_limit 1
> >// Room
> >difference
> >box
> >box
> >                                                              - Warp. -
Date: 15 Sep 1998 23:05:10
Message: <35ff1cd6.0@news.povray.org>
Sorry, didn't realize I had typed in "Povray" for the name.. Hehe... :)
(red-faced grin)
Ken wrote in message <35FE42E4.58A73427@pacbell.net>...
>WOW !
>Ken
exception
a
having
any
>> -D.J. Brown
you
>> >: used.
>> >global_settings
>> >  radiosity
>> >  { brightness 8
>> >    count 400
>> >    distance_maximum 1
>> >    error_bound .2
>> >    gray_threshold .1
>> >    low_error_factor .5
>> >    minimum_reuse .001
>> >    nearest_count 6
>> >    recursion_limit 1
>> >// Room
>> >difference
>> >box
>> >box
>> >                                                              - Warp. -
