POV-Ray : Newsgroups : povray.general : Simple L-system library for POV-Ray v3.7 Server Time
23 Mar 2026 21:23:09 EDT (-0400)
  Simple L-system library for POV-Ray v3.7 (Message 11 to 20 of 29)
<<< Previous 10 Messages Goto Latest 10 Messages Next 9 Messages >>>
Subject: Re: Simple L-system library for POV-Ray v3.7
Date: 19 Jul 2023 23:00:00
Message: <web.64b8a2b1753f6159a909f4889db30a9@news.povray.org>
"ingo" <nomail@nomail> wrote:
> "Tor Olav Kristensen" <tor### [at] TOBEREMOVEDgmailcom> wrote:
> > [...] I started to
> > rewrite his L-system code to work in POV-Ray v3.7.
> I already started wondering about the silence from Norway, but then, as Jack out
> of the box, there is beautiful code. Thank you Tor Olav.
Hi Ingo  :-)
I'm just lurking around in the background. I do not have as much time for
POV-Ray code writing as I once had.
Lately I've been working, slowly, on these two projects - which are not finished
yet:
https://github.com/t-o-k/POV-Ray-matrices
https://github.com/t-o-k/Predynastic-Egyptian-granite-vase
Tor Olav
http://subcube.com
Date: 19 Jul 2023 23:05:00
Message: <web.64b8a3dc753f6159a909f4889db30a9@news.povray.org>
"Colin Fleming" <Colin Fleming> wrote:
> Hi Tor,
> This is great work!
Thank you Colin
> Przemyslaw Prusinkiewiczs book, "The Algorithmic Beauty of Plants" was one of
> the first books I bought on L-Systems.
> If anyone is interested, you can download the book here:
> http://algorithmicbotany.org/papers/abop/abop.pdf
Thank you for that link. I did not know that it is freely available.
Tor Olav
http://subcube.com
Date: 19 Jul 2023 23:20:00
Message: <web.64b8a6ce753f6159a909f4889db30a9@news.povray.org>
> > >   axiom = FX
> > >   X -> >[-FX]+FX
> > >   angle = 40
> > Yes, this was the one. I had to scratch my head more than once when I used it.
> > It couldn't be symmetric and an angle of 40 could not be right.
> > I usually trust PB a lot but I guess something went wrong during publishing...
> Have to correct myself.
> It took some time to figure out how it works but it is symmetric and the angle
> is acceptable, too.
> But his rule means branches grow (>) with each iteration instead getting smaller
Those rules can be a bit confusing.
If the scale number is greater than 1, then > will increase the line width and <
will decrease it. And if it is less than 1 the opposite will happen.
It seemed that P.B. had used the golden ratio for the branch width scaling:
phi = (1 + sqrt(5))/2 = 1.618033988749...
So to make the branch radii decrease by their "distance" from the stem when
using the > symbol, I used the reciprocal of phi, i.e. 1/phi = 0.61803398875...
Tor Olav
http://subcube.com
Date: 21 Jul 2023 17:30:00
Message: <web.64baf7f4753f6154915286f3b2af915@news.povray.org>
> I don't know if this reprint (or new edition ?) "The Fractal Geometry of Nature"
> book by Mandelbrot contains any L-system images/rules:
> https://www.amazon.com/Fractal-Geometry-Nature-Benoit-Mandelbrot/dp/1648370403
> If so then I'll have to consider buying it.
I think the 'The Algorithmic Beauty of Plants'
(http://algorithmicbotany.org/papers/abop/abop.pdf) is a more up-to-date version
of L-Systems.
> But I'm not sure how the rules should work in 3D. Have you seen any such
> images with accompanying 3D rules? If so, that would help me understand what is
> needed.
It's not too much. 2 symbols for pitch up/pitch down and 2 symbols for roll
left/roll right. And some 'placeholder' chars like A,B,...
See chapter 1.5 in the book I mentioned above.
There is also an axiom and rule for the famous Hilbert curve in 3D and a 3D
bush-like structure including images of both.
The only program that covers 3D L-Systems is Lparser by Laurens Lapre but it's
MS DOS only. But I will rummage through the .LS files to find things we can use.
Cheers, Droj
Date: 22 Jul 2023 00:05:00
Message: <web.64bb5403753f6154915286f3b2af915@news.povray.org>
> > needed.
Hi TOK,
Let's take the example of PB's Pythagoras tree. We can easily use a copy of it
and rotate it 90*y to get a tree with more branches.
But instead we can use your L-system directly and the following axiom/rules:
axiom:
AB
rules:
A = [F[+F<A][-F<A]]
B = [F[^F<B][&F<B]] // rotate
< // l/LengthScale
angle = 45 degrees
The confusing thing is: Lindenmayer's System is a righthanded system and ^ and &
mean pitch up/pitch down.
We are used to the lefthanded system and that means to me: roll left/roll right
in which case we have to use \ and /.
See image generated with L. Lapres Lparser and rendered with Povray.
Here's a link with lots of examples:
https://www.houdinikitchen.net/2019/12/21/how-to-create-l-systems/
Cheers, Droj
Download 'pyth017.png' (267 KB)
Preview of image 'pyth017.png'
Date: 22 Jul 2023 04:35:00
Message: <web.64bb93b9753f61517bac71e8ffb8ce3@news.povray.org>
Same here.
You have some nice looking projects there.
ingo
Message: <web.64bb948e753f61517bac71e8ffb8ce3@news.povray.org>
> MS DOS only.
The code of it is available https://github.com/jvail/L-System
A nice one to test stuff: https://jvail.github.io/L-System/
ingo
Date: 22 Jul 2023 12:05:00
Message: <web.64bbfd2c753f61580c03e9d6cde94f1@news.povray.org>
hi,
> The code of it is available ...
and works, with v little work, on Linux.  liking the VRML output :-).
regards, jr.
Date: 26 Jul 2023 08:55:00
Message: <web.64c11767753f615a0768d5a3b2af915@news.povray.org>
> If so, then I've shown how this can be used without much adaptation in a new
> example in the repository.
> Please post some more images made with the axioms and rules that you've
> collected.
Hi TOK,
I packed some POV files using your L-system in the archive below to extend your
examples collection.
Cheers, Droj
Download 'tok_l-sytems.zip' (12 KB)
Date: 26 Jul 2023 21:05:00
Message: <web.64c1c281753f61565b3b5af89db30a9@news.povray.org>
> > collected.
> Hi TOK,
Thank you Droj. I'll have a look at it.
I should mention that I have now made a modified version of my L-system library
that can create 3D shapes. - And I've managed to render a 3D Hilbert curve. But
I have not had time do more test.
Now I'm in doubt if I should create a new repository for the 3D version of the
library, or if I should update the existing 2D library, making it more
circumstantial to use.
Tor Olav
http://subcube.com
