POV-Ray : Newsgroups : povray.general : Reading mesh2 data from file Server Time
26 Apr 2024 07:50:03 EDT (-0400)
  Reading mesh2 data from file (Message 2 to 11 of 11)
<<< Previous 1 Messages Goto Initial 10 Messages
Subject: Re: Reading mesh2 data from file
Date: 3 Jul 2021 02:35:00
Message: <web.60e004a3c54a2bf05e0fed26cde94f1@news.povray.org>
hi,
"Kima" <nomail@nomail> wrote:
> Since a mesh is made of thousands or millions of triangles, it is tidy to keep
> the data in separate files and include them in the .pov file whenever necessary.
> I mean something like
> #declare Vertices = read from vertices.txt;
> #declare Faces = read from faces.txt;
> fopen directive of POV-Ray reads the file into variables,
> #read (FILE_HANDLE_IDENTIFIER,MyString,MyFloat,MyVect)
> I don't know if it works as vertices and faces are thousands/millions of
> vectors.
storing vertex and face coords/points in separate files etc should/would work.
however, have you considered only doing "the work" once?  that is, create an
..inc file from your '*.txt' files instead and simply use that from then on?
have attached an example.
regards, jr.
Download 'cube2_mesh.inc.txt' (1 KB)
Date: 3 Jul 2021 02:57:09
Message: <60e00a45$1@news.povray.org>
Am 03.07.2021 um 07:57 schrieb Kima:
If you really want to keep the vertices in a different file than the
faces, what you could do is use:
     mesh2 {
       vertex_vectors {
         #include "vertices.inc"
       face_indices {
         #include "faces.inc"
making sure to store the vertices and faces, respectively, in the format
expected by POV-Ray, and putting the number of entries at the top of
each file.
Meshes tend to take a long time to parse, simply due to the sheer number
of data points, and every overhead you add to the parsing of that data -
every single processing step - will only make matters worse. Far, far worse.
That said, I would argue however that it is neater to have all the data
for one mesh in one file. It is customary to put the entire `mesh2` into
a single include file, preceded by a `#declare`, like so:
     #declare MyThingumajig = mesh2 {
In your main scene file, you then use:
     #include "my_thingumajig.inc"
     object { MyThingumajig }
(As an exception, if you are rendering an animation of a mesh that
changes shape, it might make sense to place vertex and normal vectors in
one file and the face indices and uv vectors in another, to avoid
duplicating data, as typically you'll want different vertex and normal
vectors for each frame but the same face indices and uv vectors for all
frames.)
Date: 3 Jul 2021 16:10:00
Message: <web.60e0c2f4c54a2bf0e75ac487d427f3e5@news.povray.org>
"jr" <cre### [at] gmailcom> wrote:
> hi,
> > vectors.
> regards, jr.
I admit it is odd. I create the vertices and faces by a script in C. I save the
vertex and face vectors within loops directly into files by fprintf. Then, I get
the numbers at the end of the loops. AT  this stage, I cannot append the numbers
at the beginning of the vectors saved into files.
Therefore, my output is two files and the corresponding numbers.
Message: <web.60e0c335c54a2bf0e75ac487d427f3e5@news.povray.org>
>      mesh2 {
>        vertex_vectors {
>        face_indices {
> each file.
> frames.)
#include "vertices.inc" trick works like a charm. So silly of me that forgot
#include can do the job. I agree we should minimise any unnecessary process, but
I think reading two files (perhaps three, adding normals) is not a significant
overhead.
Date: 3 Jul 2021 20:23:10
Message: <60e0ff6e$1@news.povray.org>
Am 03.07.2021 um 22:06 schrieb Kima:
> overhead.
Given the constraints of your process to create the data, it seems like
a reasonable approach. Given typical mesh sizes, the overheard of
opening two additional files (or even up to four, with normals and UV
vectors) should indeed be benign compared to the overhead of actually
parsing the data.
Date: 4 Jul 2021 03:27:19
Message: <XnsAD5D602EDC952seed7@news.povray.org>
You have a look at meshmaker.inc in the \include folder. When mesh are
generated all different parts, vertices, normals, uv-vectors are kept in
different arrays. The there is a separate macro to assemble all data to a
mesh. There are also macro's to write and read mesh data as an include
file.
You can write the seperate data to a file and use the BuildWriteMesh2 to
build the actual mesh2
Ingo
https://ingoogni.nl
Date: 4 Jul 2021 03:55:41
Message: <XnsAD5D64FFC2275seed7@news.povray.org>
> file.
Should have added, if you use the macros you can write the mesh to an
*.arr file. Then the data is written as separate arrays for vertex, normal
etc. You can also write to *.obj files, but not read them with POV-Ray.
https://ingoogni.nl
Date: 4 Jul 2021 05:25:00
Message: <web.60e17d41c54a2bf05e0fed26cde94f1@news.povray.org>
hi,
> > regards, jr.
odd, yes. :-)  I gather that the "script in C" is your own, so what I do not
understand is, why not keep everything in RAM until all calculations are done,
and do the "fprintf()"s after?  (my own effort too is in C, make use of it if
you wish
<https://news.povray.org/povray.text.scene-files/message/%3Cweb.5e2ec3f92af4d0a48c662f470%40news.povray.org%3E/#%3Cweb.
5e2ec3f92af4d0a48c662f470%40news.povray.org%3E>)
regards, jr.
Date: 5 Jul 2021 03:50:00
Message: <web.60e2b882c54a2bf0e75ac487d427f3e5@news.povray.org>
> you wish
b.
> regards, jr.
Thanks for sharing your script. It's quite sophisticated. Mine is messy :)
For two reasons, I directly use fprintf():
1. The mesh may get large, and surely I will have stack overflow. Thus, I have
to allocate the memory dynamically to keep all the data in memory. The memory
footprint is trivial for the modern machines, but I considered to be safer to
directly write them to the files.
2. When saving the data in raw forms (vectors), I can easily create other mesh
formats from the separate files. It is unlikely, as I only use POV-Ray, but it's
not a bad idea to keep the system flexible for future expansion.
Date: 5 Jul 2021 06:40:00
Message: <web.60e2e029c54a2bf05e0fed26cde94f1@news.povray.org>
hi,
don't they all, always, start "messy"?!  :-)
I think your second point very important to bear in mind, always.
regarding the first, agree, memory storage is not going to be a concern.  I also
appreciate the "hassle" aspect wrt managing (de-)allocation.  sometimes one can
find a "tool for the job" in a library already installed on the system.  if you
don't mind making your code depend on a library (shouldn't be a problem for
"personal" code), then, for instance, the 'glib' has an useful sounding 'GArray'
type which quote "Arrays are similar to standard C arrays, except that they grow
automatically as elements are added".
regards, jr.
