POV-Ray : Newsgroups : povray.general : text & trace() bug Server Time
11 Sep 2025 05:59:31 EDT (-0400)
  text & trace() bug (Message 1 to 10 of 10)
Subject: text & trace() bug
Date: 24 Oct 2003 01:04:12
Message: <Xns941EADC736F7Caelum@204.213.191.226>
I quickly searched the newsgroups for this, but didn't find anything.  Is
it a known bug that the normal returned by trace() for a text object is
reversed?
Quick example:
// ---- START ----
// Blue lines are traces from x=0 towards the objects
// Red lines are the normals returned by trace()
// reference sphere works as expected
// text doesn't
#version 3.5;
global_settings {
  assumed_gamma 1.0
default { texture {
  pigment { color rgbt <1,1,1,0.5> }
  finish { specular 0 roughness 1 } } }
camera { location  <0, 0, -3> }
light_source { <-2,2,-4> color rgb 1 }
#declare Sphere = sphere { 0, 0.5
  translate <-1,0,0>
Sphere
#declare Text = text {
  ttf "arial.ttf" "O" 1, <0,0,0>
  scale 2
  translate <0.5,-0.75,-0.5>
Text
cylinder { <0,-2,0>, <0,2,0>, 0.025 }
cylinder { <-2,0.2,0>, <0,0.2,0>, 0.025 pigment { color rgb <0,0,1> } }
cylinder { <0,-0.2,0>, <2,-0.2,0>, 0.025 pigment { color rgb <0,0,1> } }
#declare TN = <0,0,0>;
#declare TH = trace(Sphere,<0,0.2,0>,-x,TN);
cylinder { TH, TH+TN, 0.025 pigment { color rgb <1,0,0> } }
#declare TH = trace(Text,<0,-0.2,0>,x,TN);
// ---- END ----
Subject: Re: text & trace() bug
Date: 24 Oct 2003 02:23:52
Message: <9qTjkCAqBMm$EwRW@econym.demon.co.uk>
>reversed?
I see that it's only the sides of the text characters that show this
effect. If the trace() ray hits the front or back face of a letter, then
the normal is correct. (To see this, rotate the text like this in your
scene
    scale 2
    translate <-0.5,-0.3,0>
    rotate y*45
    translate <1,0,0>
It looks like the sides of the characters are inside out. If we paint a
text with a red texture and a green interior_texture we can see that the
sides are interior and the faces are exterior.
#version 3.5;
global_settings {assumed_gamma 1.0}
camera { location  <0, 0, -2> }
text {ttf "arial.ttf" "O" 1, <0,0,0>
  texture { pigment { color rgb x }}
  interior_texture {pigment {rgb y}}
  scale 2
  rotate y*20
Mike Williams
Gentleman of Leisure
Date: 24 Oct 2003 07:18:37
Message: <3f990a8c@news.povray.org>
  That sounds like a genuine bug.
  Normally the direction of the normal vectors don't matter because POV-Ray
flips them as necessary. It's only with features which rely on the direction
of the normal vector, such as interior_texture and trace(), where the
difference can be seen. Such features were added long after the text object
was added to POV-Ray and thus it's logical that such "bug" was never caught
(because it never affected rendering in versions previous to 3.5).
  I wonder if there are other primitives with inverted normal bugs...
Perhaps someone should check. :)
Date: 24 Oct 2003 09:00:15
Message: <Xns941E5B90C1BF1Caelum@204.213.191.226>
Mike Williams <nos### [at] econymdemoncouk> wrote in
news:9qTjkCAqBMm$EwRW@econym.demon.co.uk:
Thanks for confirming and elaborating.  I came across this because I was
trying to use text with my ball sim code.  Really wasn't working right and
I couldn't figure out what I was doing wrong at first.  Then I was thinking
I could simply make a special case for text and reverse the normal, but
since it's only the sides that are inverted, it won't be that simple.
Date: 24 Oct 2003 09:20:01
Message: <3f992701@news.povray.org>
  A workaround (read: kludge) would be to take the intersection point and
advance it a tiny bit in the direction of the normal vector and see
with inside() whether this point is inside the text object. If it is,
then simply negate the normal vector.
Date: 24 Oct 2003 12:44:57
Message: <Xns941E81B69E7E0Caelum@204.213.191.226>
Warp <war### [at] tagpovrayorg> wrote in news:3f992701@news.povray.org:
Sounds good.  I was thinking of basing myself on the text's orientation.
Since the front and back of the text should always (I think) be flat, then
a collision with a text trace normal that is parallel with the front normal
would be used as is, all others would be negated.  This would mean that I
would need to keep track of the text orientation, but I think it might also
mean less computation in the sim loop.
Date: 24 Oct 2003 17:58:35
Message: <cjameshuff-E8D923.17562724102003@netplex.aussie.org>
In article <Xns### [at] 204213191226>,
This is a good idea...the normals are either perpendicular to the face
axis or parallel to it, making them quite easy to distinguish.
Another possibility is to trace against an intersection of a text object
and two planes or a box for the normal computation.
http://tag.povray.org/
Date: 25 Oct 2003 09:04:20
Message: <Xns941F5C4A2741CCaelum@204.213.191.226>
Christopher James Huff <cja### [at] earthlinknet> wrote in
news:cja### [at] netplexaussieorg:
> object and two planes or a box for the normal computation.
Thanks but I just tried an intersection between text and a box or plane and
the normals remain the same.  Unless I'm not understanding correctly.  Why
two planes?
Date: 25 Oct 2003 15:56:58
Message: <cjameshuff-12F1D7.15545425102003@netplex.aussie.org>
> two planes?
Actually, I don't think what I was thinking of is expressible in POV, so
just ignore that.
If the text object is untransformed, you could just check the z
component of the returned points and use that to decide whether to flip
the normal. You could do it even if the text is transformed, though it
would be a little more complex.
Date: 9 Nov 2003 08:52:10
Message: <Xns942E5A3888BC8Caelum@204.213.191.226>
Warp <war### [at] tagpovrayorg> wrote in news:3f990a8c@news.povray.org:
Looks like the lathe also has it's normal inside out.  I haven't tested all
types of lathes.
