POV-Ray : Newsgroups : povray.general : Envelope deformation Server Time
11 Dec 2025 01:21:03 EST (-0500)
  Envelope deformation (Message 21 to 28 of 28)
Subject: Re: Envelope deformation
Date: 28 Jul 2025 11:41:35
Message: <68879a2f$1@news.povray.org>
On 7/25/2025 7:04 PM, Bald Eagle wrote:
> Josh English <Jos### [at] joshuarenglishcom> wrote:
>> On 7/25/2025 9:16 AM, Bald Eagle wrote:
>>> Perhaps a script could be written to convert mesh and mesh2 objects to arrays,
>>> and then we can have a macro to define the mesh from those arrays.
>> We would need to be able to serialize the mesh objects, though. I don't
>> know if 4.0 has any plans for that sort of thing. It would be nice to be
>> able to export them after a complicated modeling job.
>> Then again, I have Python at hand and I suspect most of us know other
>> coding languages that could do the same job. I'm trying to be an SDL
>> purist, probably to my detriment.
>> Josh
> Well, we have #read and #write.
> I've written tens of thousands of bicubic patch objects to files that way.
> So it shouldn't be that big of a problem to write a distorted mesh to a new
> file.
> - BE
I do that, too. I create arrays that track arrays and shove them all
into a mesh2 object. It would be nice to be able to take the created
mesh2 object and serialize instead of creating everything, writing to a
file, then importing it. But that's a high-level language thing.
I keep getting tripped up with my years of Python where everything is an
object.
Date: 28 Jul 2025 12:00:00
Message: <web.68879e0927ff662017bac71e8ffb8ce3@news.povray.org>
but so far I don't have an easy way to combine models into one
> modeling array that would allow for sharp corners.
Mmmm, what about weighting the knots? for maximum smoothness than handles shoud
be equally long and have the exact opposite direction. Lets call that a weight
of 1.
Weight of 0 could be handle length 0.0. other weights are interpolation of the
two extrema.
This scheme is not exact, for example, it does not account for asymmetric
handles, but it could be a starting point for tinkering.
With a modeller, no idea if it is not build in.
ingo
Date: 28 Jul 2025 17:15:00
Message: <web.6887e74827ff66201f9dae3025979125@news.povray.org>
"jr" <cre### [at] gmailcom> wrote:
> I think that with a second
> example perhaps and "fleshing out" your notes, this topic too would make a
> useful/valuable reference in the wiki.
Well, yes - however I was thinking about it today and tracking down some details
as a refresher, and any circle needs 4 bezier splines to get a good
approximation, so several of those shapes would really require 4-16 Bezier
Parallelpipeds to be stitched together.
Might not be so bad since I already worked that out and have example code but
.....  ugh.  Work.
I will add it to The List.
- BW
Date: 28 Jul 2025 20:38:54
Message: <6888181e$1@news.povray.org>
> of 1.
> two extrema.
> ingo
My rough rough rough idea is to build a copy of the Modeling Grid (which
is a 2D array) with a equally sized grid of <1,1,1,1> values (which
would cover positive and negative U and positive and negative V
weights). When I create the control point grid I create the internal
control points as 1/3rd the distance towards the adjoining point by
default.
So I could multiply that 1/3rd distance by the weight factor, or just
default the weight (or smoothness) factor to 1/3 across the board and
then tighten things up as necessary, making sure to not set any of them
to 0 because that will collapse the bicubic patch. At least, I think it
will break the bicubic patch.
I have to play with it down the road. I'm still trying to mimic  Oskar
Stålberg's irregular grids from Townscaper for this project.
Josh
Date: 29 Jul 2025 13:55:00
Message: <web.68890ae927ff66205985c6de25979125@news.povray.org>
> Josh
Is there a problem with simply butting 2 Bezier splines next to one another and
making a sharp bend that way?
irregular grids, and provided tutorials.
I see where the Wavefront Collapse is going now.  :)
- BE
Date: 29 Jul 2025 14:15:00
Message: <web.68890e7f27ff66205985c6de25979125@news.povray.org>
> .....  ugh.  Work.
However . . . I just recalled working out how to split a Bezier spline into 2 -
so I could do that recursively, and get a whole connected series of cubes, and
then just work out where the control points need to be for any given shape.
- BW
Date: 31 Jul 2025 11:18:47
Message: <688b8957$1@news.povray.org>
>> Josh
> There seem to be a number of people who have implemented Oskar Stålberg's
> - BE
My box modeler does this by extracting each face and generating the
bicubic patches for each side.
The problem as I see it is how do I tell my modeling system "this bit is
flat but that bit is round"?
As for the irregular grids, it's also not a matter of finding the
quadrilaterals and drawing them, it's a matter of creating them and
keeping track of them so I can traverse the irregular relaxed grid.
And yes, this is exactly all for this wave function collapse thing I'm
building.
Josh
Date: 31 Jul 2025 11:55:00
Message: <web.688b91d027ff6620e6b881e925979125@news.povray.org>
Need way more information and context to offer intelligent advice / solution.
Where is your input coming from?
Flat and round where?  On the edges?  On the face?
Can you use trace () ?
Maybe you need iterative interaction like I did with my analytical tangent
scene.
Details.
When I was making the Bezier stitched torus, I had my shape that was defined by
a set of parametric equations.  So I wrote macros to use where I was on the
parametric to find what patch I was on, and where in that patch I was.
Provide a workflow, diagrams, examples, etc - and there are surely solutions for
doing this.
If people are already doing it in other languages / software packages, we can
surely do it in POV-Ray.
> building.
I see you like to bite off huge projects like I do  :D
