On 3/22/21 7:22 AM, William F Pokorny wrote:
> On 3/21/21 5:04 AM, Chris Cason wrote:
>> Current status: www.povray.org is now back in read-write mode with the
>> database hooked back in.
> Do I need to login to get at the forums / news.povray.org/groups from
> the web page? This link just hangs for me currently.
Read only access worked just now for me - please ignore my question.
Bill P.
On 22.03.2021 18:05, Cousin Ricky wrote:
> One thing that was wonky for a long time but seems to be fixed now is
> that when non-ASCII characters were entered through a newsreader, they
> were incorrectly converted in the Web view. They look fine now.
The PHP version was very old. The newer ones fixed lotts of PHP bugs.
> The Web view also added an extra space if text was indented in the
> newsreader. This is still happening.
Extra space? Where?
Thorsten
> Extra space? Where?
> Thorsten
ah ok... you posting here reminded me of one other item i needed to look
at is the multilink extension you implemented. i see 6 files in the
tarball that chris made available. i don't see /any/ mysql calls that
need to be converted to mysqli... appears you're doing it differently.
want me to email you an archive of those files so you can
review/bless/decide /not/ to implement your code.
On 3/22/21 11:54 AM, Chris Cason wrote:
> Current status: the webview of the newsgroups is back up again, though
> in read-only mode for now (and not taking a feed from the NNTP server yet).
> There were a LOT of changes needed to the code to make it work with PHP7
> so some breakage or strange behavior can be expected. If anything looks
> particularly wonky please let me know.
> -- Chris
wiki status update: i've found only 21 occurrence (in two files) of
mysql->mysqli that needed to be converted. i've also been able to pull a
file i created from the database, but have /not/ done an import. i'd
like to resist doing that for now unless it's absolutely necessary. i'm
feeling 99% ready to get at a live wiki so i can finish testing
wikikdocgen
> Extra space? Where?
https://news.povray.org/60467377%241%40news.povray.org
My first indent in the code excerpt is two spaces, but the Web view
shows three spaces. A 4 space indent shows as 5, etc.
Does it even still work? It was very fragile depending on MediaWiki
version...
Thorsten
>> Extra space? Where?
Indeed, I can confirm this. I will see what is going on.
Thorsten
> >> Extra space? Where?
Ok, so it turns out there are really three spaces in the message. The
reason is, well, Thunderbird. You can see it in Thunderbird using
More->View Source. It implements an email extension on a new server. The
extension is called "format=flowed" and it is known to cause problems
when transmitting source code over email (and thus news messages as
well:
https://www.kernel.org/doc/html/latest/process/email-clients.html#email-clients
Just google "format=flowed thunderbird" (without quotes). You will find
plenty of complaints about it ...
Thunderbird (which I am also using) apparently has bugs with handling
soft and hand line breaks and the correct conversion process to a final
message format. It basically inserts the spaces even for hard line
breaks, which makes exactly no sense at all when posting source code
(which it cannot know, of course). It is only by chance that it then
doesn't soft wrap your code when displaying the message...
Sorry,
Thorsten
>> look at is the multilink extension you implemented. i see 6 files in
>> the tarball that chris made available. i don't see /any/ mysql calls
>> that need to be converted to mysqli... appears you're doing it
>> differently. want me to email you an archive of those files so you can
> version...
> Thorsten
yes it was working before the crash... however a /big/ performance hit
when editing/saving the reserved keywords page (it's loaded with
multi-links). having said that... i'm in favor of backing this extension
out. not sure what the busted link fallout will be. i'm hoping isolated
because i've /not/ been using the format. lol... remember i was /not/
pleased with the implementation, because at the release (last minute) i
had to find a way to deal with those links. i think i /might/ be able to
coax wikidocgen to help find them because i already have a case test in
the code.
> well:
OK, thanks. I just turned it off on my end. I'll see how that works
out in the future.
