POV-Ray : Newsgroups : povray.general : Texture maps different in 3.5 even when using #version Server Time
13 Jul 2026 02:29:11 EDT (-0400)
  Texture maps different in 3.5 even when using #version (Message 1 to 10 of 12)
Subject: Texture maps different in 3.5 even when using #version
Date: 1 Feb 2003 06:24:20
Message: <3e3bae64@news.povray.org>
I find the following texture renders markedly differently in 3.5 compared
with both 3.0.20-10 debian and megapovplus 0.5.0.2.5a-1 (3.1 equivalent),
which both render the images similarly to each other.
It looks to me like the grade between 0 and 1.0 in the texture map of the
older versions is quite different to the grade in 3.5 .. for example as
if one used a linear gradient and the other an exponential one. I hope
someone understand what I mean.
I don't see this mentioned in the documentation or in the bugs so far
listed in povray.general or povray.bugreports, or by googling old usenet
postings.
I haven't played much with 3.5, but have checked that if I use a plain
pigment it is the same color.
Can someone tell me this is a bug, or is expected behaviour and why? If
so, how do i figure out how to translate an old-style texture into a new
one?
I will post images to povray.binaries.images with the subject line
'Texture maps different in 3.5 even when using #version'
Simeon
#version 3.0
//test.pov
//bah there is some bug in the 3.5 textures i think
//Simeon Scott 2003-02-01 ////////////////////////
//Something like a blue agate.
background
  { color White }
global_settings
  ambient_light 0.05
  assumed_gamma 1
camera
  location <0, 0, -3>
  look_at <0, 0, 0>
  scale 0.2
light_source
  {  <2, 4, -3> color White scale 0.4 }
#declare Sim_Blue_Agate = texture
  waves
  texture_map
    [  0.15 pigment { color White }        ]
    [  1.0  pigment { color <0, 0, 0.3> }  ]
  turbulence <10, 10, 0.3>
  scale 0.1
sphere
  {  <0, 0, 0>, 0.3	texture {  Sim_Blue_Agate } }
Subject: Re: Texture maps different in 3.5 even when using #version
Date: 1 Feb 2003 07:07:39
Message: <3e3bb88b@news.povray.org>
On Sat, 01 Feb 2003 22:29:17 +1100, Not My Real Email Address wrote:
I should have been more specific about the version I guess .. this is
3.50c for linux downloaded from povray.org as binary.
The problem occurs regardless of whether I declare #version 3.0 (or 3.1)
or just render it without the version declaration.
Simeon
> compared with both 3.0.20-10 debian and megapovplus 0.5.0.2.5a-1 (3.1
> equivalent), which both render the images similarly to each other.
> the older versions is quite different to the grade in 3.5 .. for example
> as if one used a linear gradient and the other an exponential one. I
> hope someone understand what I mean.
> postings.
> one?
> Simeon
> #version 3.0
> //test.pov
> //bah there is some bug in the 3.5 textures i think //Simeon Scott
> 2003-02-01 //////////////////////// //Something like a blue agate.
> background
>   { color White }
> global_settings
>   ambient_light 0.05
>   assumed_gamma 1
> camera
>   location <0, 0, -3>
>   look_at <0, 0, 0>
>   scale 0.2
> light_source
>   waves
>   texture_map
>     [  0.15 pigment { color White }        ] [  1.0  pigment { color <0,
>     0, 0.3> }  ]
>   scale 0.1
> sphere
Date: 1 Feb 2003 07:08:33
Message: <3e3bb8c1$1@news.povray.org>
In article <3e3bae64@news.povray.org> , Not My Real Email Address
The images are not in p.b.i yet...
    Thorsten
Date: 1 Feb 2003 07:19:29
Message: <3e3bbb51@news.povray.org>
AFAIK, the noise-generator was changed from 3.1 to 3.5,
not to mention the new one added to avoid some "plateaus"
in number-distribution or what-not. I'm not so sure about
thise topic, but I DO know that the new noise-generator is
default in 3.5, and AFAIK you have to set that manually to
overcome the problem, just a #version won't help.
But that's just a guess, so don't blame me if I'm wrong! :-)
Tim
Tim Nikias
Email: Tim### [at] gmxde
> postings.
> one?
> Simeon
> #version 3.0
> //test.pov
> background
>   { color White }
> global_settings
>   ambient_light 0.05
>   assumed_gamma 1
> camera
>   location <0, 0, -3>
>   look_at <0, 0, 0>
>   scale 0.2
> light_source
>   waves
>   texture_map
>   scale 0.1
> sphere
Date: 1 Feb 2003 07:38:33
Message: <3e3bbfc9@news.povray.org>
Bah this newsreader! Had trouble posting images to usenet, but here they
are on my website (for now).
http://bur.st/~shevek/test_3.0.jpg
http://bur.st/~shevek/test_mega0.5.jpg
http://bur.st/~shevek/test_3.5.jpg
Thanks in advance for your kind help :)
Simeon
On Sat, 01 Feb 2003 23:21:44 +1100, Tim Nikias wrote:
> AFAIK, the noise-generator was changed from 3.1 to 3.5, not to mention
> the new one added to avoid some "plateaus" in number-distribution or
> what-not. I'm not so sure about thise topic, but I DO know that the new
> noise-generator is default in 3.5, and AFAIK you have to set that
> manually to overcome the problem, just a #version won't help.
> Regards,
> Tim
> Tim Nikias
> Homepage: http://www.digitaltwilight.de/no_lights/index.html Email:
> Tim### [at] gmxde
>> example as if one used a linear gradient and the other an exponential
>> one. I hope someone understand what I mean.
>> usenet postings.
>> new one?
>> Simeon
>> #version 3.0
>> //test.pov
>> background
>>   { color White }
>> global_settings
>>   ambient_light 0.05
>>   assumed_gamma 1
>> camera
>>   location <0, 0, -3>
>>   look_at <0, 0, 0>
>>   scale 0.2
>> light_source
>>   waves
>>   texture_map
>>     <0, 0, 0.3> }  ]
>>   scale 0.1
>> sphere
Date: 1 Feb 2003 09:13:40
Message: <3e3bd614@news.povray.org>
In article <3e3bbb51@news.povray.org> , "Tim Nikias" <tim### [at] gmxde>
Indeed.  Reading section "2.6.14 Changed features that may 'break' old
scenes" in the manual explains all this.
    Thorsten
Date: 1 Feb 2003 13:59:00
Message: <3e3c18f4@news.povray.org>
  Actually the noise-generator from 3.1 was not modified (AFAIK). It's simply
that two new noise-generators were added and the *default* noise-generator
was changed. You can still get the old noise-generator by adding
global_settings { noise_generator 1 } to your scene.
  (In the same way the media algorithm from 3.1 was not modified in 3.5,
but two new algorithms were added and the default when none is specified
was changed to one of the new ones.)
Date: 1 Feb 2003 19:21:16
Message: <3e3c647c$1@news.povray.org>
You're right about that. I had that in mind while writing,
but as it sometimes happens, I've written something I
didn't mean in its fullest extent.
Tim
Tim Nikias
Date: 4 Feb 2003 08:08:08
Message: <3e3fbb38@news.povray.org>
>     Thorsten
Sorry in advance for the rude tone of this post.
1) I am not inclined to ignore the documentation. The documentation does
not 'explain all this' ...
    2.6.14  Changed features that may 'break' old scenes
    Noise:
    New noise functions have been added in POV-Ray 3.5. Noise functions
    are internaly used in patterns. The default function in 3.5 is not
    the same as it was in 3.1 and earlier. This may affect the appearence
    of textures in old scenes.
    Solution: put noise_generator 1 in global_settings{}.
'noise and pigment functions' in the TOC takes me to
    3.6.3.6  noise and pigment functions
    Some of the internal functions have a random or noise-like structure
    Together with the pigment functions they are one of the most powerful
    tools for designing isosurfaces. We can add real surface displacement
    to the objects rather than only normal perturbation known from the
    normal{} statement.
    The relevant internal functions are:
    * f_noise3d(x,y,z)
      uses the noise generator specified in global_settings{} and
      generates structures like the bozo pattern.
The words 'noise generator' above link to
    6.7.12.4  Noise Generators
    There are three noise generators implemented. Changing the
    noise_generator will change the appearence of noise based patterns,
    like bozo and granite.
    * noise_generator 1 the noise that was used in POV_Ray 3.1
    * noise_generator 2 'range corrected' version of the old noise, it
      does not show the plateaus seen with noise_generator 1
    * noise_generator 3 generates Perlin noise
    The default is noise_generator 2
    Note: The noise_generator can also be set in global_settings
So it looks like indeed the 'noise generator' MAY be the culprit, but
I need to verify what exactly uses these 'noise generator's and what
doesn't.
So I go back to '3.6.3.6  noise and pigment functions' and this time
click on the words 'internal functions'.
    3.6.3.4  internal functions
    There are a lot of internal functions available in POV-Ray. For
    example a sphere could also be generated with function
    { f_sphere(x, y, z, 2) } These functions are declared in the
    functions.inc include file. Most of them are more complicated and
    it's usually faster to use them instead of a hand coded equivalent.
    See the complete list for details.
The words 'complete list' are hyperlinked, supposedly to
povdoc_082.html#target_141 but in fact this is a dead link. It refers to
the exact paragraph of text that it appears in.
So I am still in the dark of whether the 'noise generator' parameter is
theoretically supposed to fix the problem. But I can tell you it does not
in practice.
And in my opinion, it should NOT be necessary. What is #version 3.0 or
#version 3.1 supposed to do, if not set values like this to the necessary
values to recreate a scene made using a previous version of povray?
So there are three bugs for you for the price of one.
1) documentation: dead link at 'complete list' in paragraph at
2) #version does not set correct value of noise_generator in order to
recreate images from source code created with previous versions of
povray (if I am to believe what I hear here).
3) povray 3.5 does not recreate image correctly from my source code
generated for previous version of povray (3.0, 3.1-compatible megapov0.5)
even with global_settings { noise_generator 1 }, optionally also with
#version 3.0 or #version 3.1.
Thanks for replying, I hope this can be easily sorted. Thanks povray team
for many years of joy (and frustration! ;)
I did not bother attaching the output from the changed source, since it
is exactly the same output as generated previously using povray 3.5, but
here below is my source code amended to include the 'noise_generator'
setting, so that you can verify that I have not made a typo.
In fact, it makes no difference whatsoever to the output generated
whether noise_generator is set to 1, 2 or 3, nor whether I remove the
#version directive.
Simeon
with both 3.0.20-10 debian and megapovplus 0.5.0.2.5a-1, which both
render the images similarly.
Simeon
#version 3.0
//test.pov
background
  { color White }
global_settings
  ambient_light 0.05
  assumed_gamma 1
  noise_generator 1
camera
  location <0, 0, -3>
  look_at <0, 0, 0>
  scale 0.2
light_source
  waves
  texture_map
  scale 0.1
sphere
Date: 4 Feb 2003 08:44:51
Message: <3e3fc3d3@news.povray.org>
  Is it supposed to?
  The #version directive only emulates older versions at language level.
It does not emulate older versions at rendering level. (Eg. you won't get
halo back, no matter how many #version directives you write.)
  There have been many changes which are not affected by #version because
they are not a simple language syntax thing.
