POV-Ray : Newsgroups : povray.general : Blurred reflections Server Time
13 Aug 2025 07:43:37 EDT (-0400)
  Blurred reflections (Message 1 to 10 of 16)
Subject: Blurred reflections
Date: 6 Jul 2002 17:23:00
Message: <3d275fb4@news.povray.org>
I am experimenting with using blurred reflections and am using the method
Warp lists in his PovQandT on his web site.  But rendering with this
technique takes an extremely long time to render.  What other proven
techniques are there to create blurred reflections (that are preferrably
faster to render)?
...too bad POV-Ray doesn't support blurred reflections like MegaPOV does
Here is the technique listed in the PovQandT:
#declare BlurAmount = .2; // How blurred the reflection should be
#declare BlurSamples = 40; // How many reflected rays to shoot
object
{ MyObject
  texture
  { average texture_map
    { #declare Ind = 0;
      #declare S = seed(0);
      #while(Ind < BlurSamples)
        [1 pigment { ObjectPigment } // The pigment of the object here
           finish { ObjectFinish } // The finish; should have reflection
           normal
           { bumps BlurAmount
             translate <rand(S),rand(S),rand(S)>*10
             scale 1000
        #declare Ind = Ind+1;
Here is how I used it (and rendering takes forever):
#declare BlurSamples = 20;
#declare Polished_Chrome =
   material  // Polished_Chrome
      texture
                #declare Ind = 0;
                #while( Ind < BlurSamples)
                [1 pigment
                     color rgb <0.2, 0.2, 0.2>
                   finish
                     ambient 0.1
                     diffuse 0.7
                     brilliance 6.0
                     phong 0.8
                     phong_size 120.0
                     reflection 0.6
                   normal
                     bumps BlurAmount
                     translate <rand(S), rand(S), rand(S)>*10
                     scale 1000
                 #declare Ind = Ind + 1;
Subject: Re: Blurred reflections
Date: 6 Jul 2002 17:50:01
Message: <3d276609@news.povray.org>
  It wouldn't help much. MegaPov does basically the same thing, and it's
not any faster there.
  Using this trick, however, you can do much more than MegaPov's blurred
reflection can.
Date: 7 Jul 2002 14:43:24
Message: <chrishuff-1BF970.13410007072002@netplex.aussie.org>
In article <3d275fb4@news.povray.org>, "Paragon" <use### [at] hostcom> wrote:
> faster to render)?
MegaPOV uses the same basic technique, except that it just randomly
jitters the rays. The averaged texture method is slower if you compare
by the number of blur rays cast, but you usually don't need as many
samples because the rays aren't purely random, and it is much more
flexible: it can be used to simulate different shapes of bumps or ridges
on the surface. It might be possible to make a patch that has the same
flexibility but is as optimized as possible, it would be a bit more work
than the MegaPOV blur but it is possible.
Date: 7 Jul 2002 19:02:34
Message: <3d28c88a@news.povray.org>
  I would bet that in pov4 we will have some way of saying in a texture
(or whatever property of the surface) things like "shoot a ray in this
direction and return me the color", which can eventually be used to make
blur-reflecting textures or whatever we like.
Date: 7 Jul 2002 19:56:39
Message: <3D28D52C.D40C769F@pacbell.net>
And I hope pov4 doesn't become just another programmers only toy.
Ken Tyler
Date: 8 Jul 2002 03:07:26
Message: <3d293a2e@news.povray.org>
> MegaPov does basically the same thing, and it's not any faster
Even when two blurred objects are close to each other and the rays ping
pong? That takes ages with the blur "trick" but the rendertime can be
considerably reduced with a low max_trace_level without any noticeable
difference.. Maybe MegaPOVs blurred reflection wouldn't change it's speed
with max_trace_level? It would be a better way then, because a scene may
have other objects that need a very high max_trace_level.
> you can do much more than MegaPov's blurred reflection can.
The best results are when the averaged normals are scaled very big, but then
the layers have a random value .. if you understand what I mean ... with
only a few layers, this does not always look good.. Besides it seems a very
big limitation that we can't apply both blur *and* an ordinary normal
pattern / image_map ... doing so does not mix well without MegaPOV.
Hugo
Date: 8 Jul 2002 09:25:15
Message: <3d2992ba@news.povray.org>
  It wouldn't make any sense if max_trace_level would not affect blurred
reflection.
  You can scale the normal very small, thus getting a similar result to
MegaPov's blurred reflection. It isn't very nice either (*really* grainy).
  The Q&T tip describes how to use both the blurred reflection trick and a
regular normal pattern.
Date: 8 Jul 2002 11:16:16
Message: <chrishuff-6DA49C.10135608072002@netplex.aussie.org>
In article <3d293a2e@news.povray.org>, "Hugo" <hua### [at] post3teledk>
> pong?
The blur patch doesn't do anything special in that case. That can get
very slow with the blur patch as well, and you need more samples to get
fairly smooth results.
> noticeable difference.. Maybe MegaPOVs blurred reflection wouldn't
> change it's speed with max_trace_level? It would be a better way
> then, because a scene may have other objects that need a very high
> max_trace_level.
There isn't any special difference between ordinary reflection and
blurred reflection, max_trace_level behaves the same. A blur patch
*could* do something like that, but the existing one doesn't.
I don't understand. The part about using large scale normals is what
makes the technique better than what the patch does, I don't know what
you mean by "the layers have a random value".
With only a few layers, it doesn't look good...and the blur patch
doesn't look good with only a few samples. Your point?
> Besides it seems a very big limitation that we can't apply both blur
> *and* an ordinary normal pattern / image_map ... doing so does not
There aren't any problems with image_maps. You *can* mix normals and
blur, it does get tricky though...a built-in feature would be simpler to
use.
Date: 8 Jul 2002 12:19:03
Message: <3d29bb77@news.povray.org>
> use.
  A builtin version would also take a lot less memory and be a tiny bit faster.
However, it would be difficult to get the same versatility with a builtin
version - it would have to be designed very carefully.
  Of course I have the feeling that we can forget that when we get pov4
some time in the distant future. My guess is that it will most probably have
some kind of way of specifying quite meticulously how a surface is colored
(something extremely similar to renderman shaders). Making any kind of
blurred reflection with that will probably be very easy.
Date: 8 Jul 2002 12:25:24
Message: <3d29bcf4$1@news.povray.org>
then
I'll try again then. I was only talking about the reflection tricks without
Megapov. Lets say you average 5 normals, using the bump pattern scaled very
big. Then you have 5 normals, but their directions are random..
Example: You apply the blur texture on a plane and put a white sphere above
it, that is supposed to be reflected on the plane, and use a black
background.. The result with 5 averaged normals is not 5 eqaul steps between
black/white. Because the bump patterns have random values (psudo-random, to
be precise).
Hugo
