POV-Ray : Newsgroups : povray.documentation.inbuilt : Default values in v3.8.0 Server Time
13 Aug 2026 07:09:11 EDT (-0400)
  Default values in v3.8.0 (Message 11 to 20 of 24)
<<< Previous 10 Messages Goto Latest 10 Messages Next 4 Messages >>>
Subject: Re: Default values in v3.8.0
Date: 21 Sep 2018 07:35:41
Message: <5ba4d78d$1@news.povray.org>
Am 21.09.2018 um 13:24 schrieb Kenneth:
>           right  x*image_width/image_height
> Honestly, I thought that was the default(!).
Well, it is now ;)
> But I see that 4/3*x or <1.33,0,0>
> is the real one.
The latter actually. Which means that by default the aspect ratio wasn't
even really fitting for classic 4:3 images.
Date: 22 Sep 2018 18:40:49
Message: <5ba6c4f1$1@news.povray.org>
On 9/19/18 4:46 PM, clipka wrote:
> In POV-Ray v3.8.0, default values will be chaned as follows:
haven't started on this yet...a quick glance was all i did for now but i
/think/ i've already done some of them. i'm burnt so give me a bit
Date: 22 Sep 2018 20:14:22
Message: <5ba6dade$1@news.povray.org>
Am 23.09.2018 um 00:40 schrieb Jim Holsenback:
The new `ambient` and camera defaults are indeed already doc'd, so it's
a matter of finding a good place to document the new pigment colour (the
old default of pitch black doesn't seem to be explicitly mentioned) and
to overhaul the behaviour of the `#version` statement with respect to
the defaults.
Nothing too urgent I think, so no pressure.
Date: 30 Sep 2018 18:06:55
Message: <5bb148ff$1@news.povray.org>
> the defaults.
for default pigment just a brief /change/ annotation:
http://wiki.povray.org/content/Reference:Pigment
i created a talk page for the rest:
http://wiki.povray.org/content/Reference_Talk:Version_Directive
i cleaned up the intro paragraph. after the syntax diagram i grouped the
expanded discussions together. followed by examples.
in the 1st paragraph after the syntax at the sentence... As with version
3.8 or later... things kind of fell apart for me. what you had written
just didn't make any sense so that was the best i could do. please
review and edit on the talk page.
Date: 30 Sep 2018 19:47:06
Message: <5bb1607a$1@news.povray.org>
Am 01.10.2018 um 00:06 schrieb Jim Holsenback:
Just to make sure we're on the same page here: The behaviour you
presumably copy-and-pasted there from ambient is /not/ the way v3.8 will
eventually behave.
See there. I hope the complete rephrasing clarifies things.
Date: 30 Sep 2018 20:12:00
Message: <5bb16650$1@news.povray.org>
> eventually behave.
...as long as no explicit #default directive statement is specified????
yep... i going to merge that over to reference
Date: 30 Sep 2018 20:45:48
Message: <5bb16e3c@news.povray.org>
Am 01.10.2018 um 02:11 schrieb Jim Holsenback:
>> eventually behave.
> ....as long as no explicit #default directive statement is specified????
Sorry, I guess it wasn't clear what exactly I was referring to; this is
about the `#version` interaction.
The text currently reads "When #version is set as either the VERY first
statement of the scene file or via command-line option and the version
is 3.8 or greater ..."
As correctly explained on the `#verison` page, thanks to the recent
overhaul it will no longer be necessary to have a `#version 3.8` as the
VERY first statement to get the changed default; unfortunately the
overhauled behaviour is more complex, and maybe the easiest and least
disruptive way to solve this is just to phrase it something like this:
"The default pigment has been {{Change}}d in version 3.8 from `rgb
<0,0,0>` to `rgb <1,1,1>` (requires `#version 3.8` or equivalent INI
setting or command-line option; see [Version Directive] for more details)."
Date: 30 Sep 2018 20:55:00
Message: <5bb17064$1@news.povray.org>
Am 01.10.2018 um 02:45 schrieb clipka:
(Just for the records, The wording /can/ be interpreted to be correct:
If you don't specify `#version` as the VERY first statement with SOME
value, you can't set it to 3.8 later, and thus can't switch to the new
defaults. And the new defaults are enabled if the version is 3.8 or
greater at SOME particular point. But I guess that's not how most people
would understand it.)
Date: 1 Oct 2018 05:22:23
Message: <5bb1e74f$1@news.povray.org>
Is there a functional or technical reason that you are implementing
this? It will make things harder for me using my modeller as I can only
change the Pov version from the default (3.6) after the default version
has been declared in the .pov file.
Regards
Date: 1 Oct 2018 09:24:03
Message: <5bb21ff3$1@news.povray.org>
Am 01.10.2018 um 11:22 schrieb Stephen:
Wait, what?
Ok, let me clarify:
The text on the Wiki currently reads as quoted above (unless Jim has
already found time to change it).
This CAN be interpreted as:
"To get the new defaults, the VERY first statement in the scene file
must be `#version 3.8` [...]"
And as a matter of fact that's how it was(!) implemented in earlier
v3.7.1 / v3.8.0 pre-releases, and why it was worded like that.
However, the implementation has recently been changed; now the statement
in the wiki can only be considered correct (and only technically so) if
interpreted as:
must be `#version <whatever>` [...], and it needs to be set to 3.8
eventually.`
To make it completely clear, the updated requirements to get the new
defaults are as follows:
(1) Start the scene with ANY odd `#version` statement. (Not a primary
requirement, but you can't switch to `#version 3.8` otherwise.)
(2) Switch to `#version 3.8` before the `pigment`/`finish`/`camera`
statements that are supposed to be based on the new defaults. (You'll
get v3.7 defaults otherwise.)
(3) Make sure you have switched to `#version 3.8` before any `default`
statement. (`#version` will cease to auto-switch defaults after you have
specified defaults manually, for reasons that I guess are self-evident.)
And here's the same from the implementation point of view:
(A) Defaults are initially set up according to the `Version` INI setting
or equivalent command-line option; if absent, v3.7 [or, technically more
exact, v3.62] defaults are used.
(B) Any `#version` statement changes the defaults accordingly [unless
rule (C) has kicked in].
(C) Any `default` statement prevents all subsequent `#version`
statements from changing the defaults.
(D) If rule (C) has kicked in, any `#version` statement that would
otherwise change the defaults will generate a warning instead.
Plus, unrelated:
(X) If a `#version` statement in the main scene file tries to set the
version to 3.8 or higher, and the first statement was not a `#version`
statement, generate an error.
So unless your modeller is throwing you some additional curveball, I
think you should be fine.
