POV-Ray : Newsgroups : povray.bugreports : Rendering is slow if scene contains lots large objects Server Time
3 Mar 2026 08:21:01 EST (-0500)
  Rendering is slow if scene contains lots large objects (Message 1 to 10 of 11)
Subject: Rendering is slow if scene contains lots large objects
Date: 10 Dec 2010 10:40:00
Message: <web.4d02479678703b77d816b68e0@news.povray.org>
// +W320 +H240
camera { location <0,50000,-100000> look_at <0,-10000,0> }
light_source { <-700000,1000000,-400000>, rgb <1,1,1> }
plane { y,0 pigment { color <0,.8,0> } }
#declare R = seed(0);
#declare Count=0;
#while (Count < 5000)
sphere {
        <0,1000,0>,
        1360  // 1350 works fast
        pigment { color <0,.5,0> }
        translate <(rand(R)-.5)*500000,0,(rand(R)-.5)*500000>
#declare Count=Count+1;
This takes over 4 minutes if the radius is 1360. If I change it to 1350 then
Render Time is just 1 or 2 seconds.
Tested with Athlon64 3200+, 3.7.0.beta.40 (Windows XP 32-bit) and 3.6.1 (Ubuntu
10.10 64-bit).
Subject: Re: Rendering is slow if scene contains lots large objects
Date: 10 Dec 2010 11:56:25
Message: <4d025bb9$1@news.povray.org>
On 10/12/2010 16:36, Juce wrote:
> // +W320 +H240
> camera { location<0,50000,-100000>  look_at<0,-10000,0>  }
> light_source {<-700000,1000000,-400000>, rgb<1,1,1>  }
> plane { y,0 pigment { color<0,.8,0>  } }
> #declare Count=0;
> #while (Count<  5000)
> sphere {
>          <0,1000,0>,
>          pigment { color<0,.5,0>  }
>          translate<(rand(R)-.5)*500000,0,(rand(R)-.5)*500000>
> #end
> 10.10 64-bit).
Confirmed.
Look at the Render statistics : 1350 get an additional line, "Bounding Box"!
Date: 10 Dec 2010 12:07:14
Message: <4d025e42$1@news.povray.org>
Am 10.12.2010 17:56, schrieb Le Forgeron:
>> 1350 then
>> 3.6.1 (Ubuntu
>> 10.10 64-bit).
> Confirmed.
> Box"!
There is a maximum coordinate value for bounding boxes; I'm just
guessing here, but it might be that the scene touches this borderline.
Date: 10 Dec 2010 13:19:09
Message: <4d026f1d$1@news.povray.org>
>>> 1350 then
>>> 3.6.1 (Ubuntu
>>> 10.10 64-bit).
>> Confirmed.
>> Box"!
> There is a maximum coordinate value for bounding boxes; I'm just guessing
Except that spheres do not get bounding boxes.
Thorsten
Date: 10 Dec 2010 13:21:16
Message: <4d026f9c$1@news.povray.org>
Am 10.12.2010 19:19, schrieb Thorsten Froehlich:
>>>> 1350 then
>>>> 3.6.1 (Ubuntu
>>>> 10.10 64-bit).
>>> Confirmed.
>>> Box"!
But I guess they are included in the bounding box tree, so they'd
normally be bounded hierarchically if I understand the bounding
mechanism correctly, right?
Date: 10 Dec 2010 14:15:59
Message: <4d027c6f$1@news.povray.org>
> But I guess they are included in the bounding box tree, so they'd normally
> be bounded hierarchically if I understand the bounding mechanism correctly,
> right?
IIRC yes.
	Thorsten
Date: 11 Dec 2010 07:54:50
Message: <4d03749a$1@news.povray.org>
>> normally
>> correctly,
>> right?
> IIRC yes.
> Thorsten
Excepted that in source/backend/parser/parse.cpp, the volume of each
bounding box is compared to INFINITE_VOLUME (aka BOUND_HUGE, i.e. 2.0e+10).
(even if sphere does not use bounding box for pruning intersections'
computation, it got a bounding box which is use for the volume)
as infinite in parse.cpp, not entering the bounding tree.
I would ponder the usage of BOUNDS_HUGE as a criteria against a volume.
than (or equal) BOUNDS_HUGE) should still be infinite.
What about comparing each dimension of the bounding box instead ?
(if it's bigger in at least one dimension, it's infinite, otherwise it
stay finite)
volume computation has issue with very large & very thin bounding box: a
larger thin object might be more finite than a smaller but thicker one
(who could be tagged if infinite).
E.g: bbox of size <1e+7, 1e+7,1e-4> is finite.
      bbox of size <1e+6, 1e+6, 1> is infinite.
Your thought ?
Date: 11 Dec 2010 14:53:27
Message: <4d03d6b7$1@news.povray.org>
Am 11.12.2010 13:54, schrieb Le Forgeron:
>>> normally
>>> correctly,
>>> right?
>> IIRC yes.
>> Thorsten
> stay finite)
> Your thought ?
I guess the idea behind this mechanism was, "if the bbox covers a lot of
volume, it will cover a lot of visible area, so we can just as well
presume we'll get a bounding box hit in virtually every direction anyway".
The flaw with this idea, which shows in this particular scene, is that
in reality the visible area covered will not only depend on the object's
volume, but also on its distance to the camera.
Maybe a good idea would be to test the volume in relation to the
distance to the camera:
   if ((a*b*c) / pow(dist_to_camera,3) >= INFINITE_VOLUME) ...
Date: 11 Dec 2010 15:24:51
Message: <4d03de13@news.povray.org>
I would stand by the code in the bounding box: when one dimension is big
enough, assume infinite (well, it's the opposite way: infinite object
set the bounding box to huge bound value in 3 dimensions...)
Or we can do like my national postal service: if the sum of the 3
dimensions is more than 1m, it's a non standard parcel... with added
price on the stamp.
Date: 11 Dec 2010 16:02:38
Message: <4d03e6ee$1@news.povray.org>
Am 11.12.2010 21:24, schrieb Le Forgeron:
> price on the stamp.
What if I define the parcel using
   box { <2,-1,-1>,<0,1,1> }
Do I get money back? :-P
