POV-Ray : Newsgroups : povray.binaries.scene-files : Granite_21 macro - beta #1.4 Server Time
31 Jan 2025 09:53:30 EST (-0500)
  Granite_21 macro - beta #1.4 (Message 11 to 20 of 36)
Subject: Re: Granite_21 macro - beta #1.5
Date: 31 May 2021 05:50:00
Message: <web.60b4b03c388d0b7a79416a1f607c1b34@news.povray.org>
> Interesting you say that and thanks for this info. When I searched
> them that were not operational any more (the majority, but over a long
> time period of a century or so). Looking also at the geological maps,
> depletion is very probable for many of them indeed. The mentioned
> granite is a very local occurrence I guess, only available around
The topic arose because I was asking about availability of "Verde Oceano." It
may not be a true granite but it's amazingly beautiful - lots of iridescence. It
looks like an underwater scene complete with brightly colored tropical fish.
Photos are totally insufficient. Adding that to your granite project would be
quite a task (maybe for the next granite update sometime around 2050), but lots
of granites do have iridescence - or at least stones that are being sold as
granite whatever they might actually be...
Kind regards,
Dave Blandston
Suggested motto: "With POV-Ray anything is possible, but nothing is easy"
Download 'verdeoceano.jpg' (219 KB)
Preview of image 'verdeoceano.jpg'
Date: 31 May 2021 06:30:00
Message: <web.60b4b9e5388d0b7a1f9dae3025979125@news.povray.org>
> There is indeed an error there. Replace the following line:
> #ifndef (_GRANITE_FILE_INC_)  #include "DakotaRedGranite.inc"  #end
> by:
> #ifndef (_GRANITE_FILE_INC_)  #local Granite_file =
So, I guess I'm still not understanding your intent.
Working backwards,
You have :"DakotaRedGranite.inc", so I guess the file you recently supplied
needs to be renamed with capitals.
Before this, You're checking to see if _GRANITE_FILE_INC_ is a declared
identifier.  Where is this identifier supposed to be properly declared?   In the
include file?
I just looked through "dakotaredgranite.inc" and it doesn't get declared in
there.
Also, this implies that _GRANITE_FILE_INC_ is a requisite line in any color_map
include file.  Correct?
Also, the arrays in any include file must have the proper names: A_Granite_map1,
A_Granite_map2, etc.
I see no real problem there at the moment, although it will need to be clear how
to properly implement multiple granite materials in a scene, so a demo ought to
have that feature and some comments.  Just pointing it out, since some people
like to have all of their include stuff at the top of a scene, and then do all
the processing later.
One last thing that occurred to me as I was trying to get to sleep - I decided
that I don't like the way I implemented the array for the color_map:
1. it uses separate entries for the color vector rather than a single vector.
2. That makes it difficult if not impossible to use rgbft colors
a 2d array with color_map location and color vector would likely be better.  The
macro probably has to get tested with an rgbft statement as well to make sure an
vector promotion happens as expected, etc.
- Bill
Date: 31 May 2021 11:05:58
Message: <60b4fb56$1@news.povray.org>
Op 31-5-2021 om 12:26 schreef Bald Eagle:
>> by:
> Working backwards,
No.
> include file?
This is an ancient trick I learned decades ago ;-). The form
_GRANITE_FILE_INC_ (the last underscore is maybe redundant) somehow
covers all the possible forms of writing (capitals, dots, etc) of which
a file name is composed. And it works perfectly well for me.
And then...!!!! [thunderclap]
So I forgot to give you the proper Line 70, which should be of course,
after Line 69, as given:
#include Granite_file
Sometimes I get blind to the most obvious things... :-/
For the proper use, you declare the file you want, /before/ calling the
macro. Example:
#declare Granite_file = "MyElectricGranite.inc";
Which includes the necessary paths too of course, like:
#declare Granite_file = "FolderA/FolderB/MyElectricGranite.inc";
> there.
No. It should be all controlled by the above.
Yes indeed. Those names are then used by the macro.
YEs, that might give some clashes. Nothing very serious but one has to
be aware of /what/ the macro exactly does.
The granite include files, as I have defined them, use a 2d array
already. As the macro can render veins, where transmit info is supplied
by the corresponding array (the map2 one) it is just a matter of reading
the proper info in the right place. The macro takes care of that.
Thanks for your thoughts! It keeps me on my toes. ;-)
Date: 31 May 2021 11:12:46
Message: <60b4fcee@news.povray.org>
Op 31-5-2021 om 11:45 schreef Dave Blandston:
Aha! a larvikite! also monzonite granitoid, and a beautiful one indeed,
very often used in the front walls of prestigious shops or offices.
Date: 31 May 2021 14:10:00
Message: <web.60b525ac388d0b7a1f9dae3025979125@news.povray.org>
You're killin' me.
I have never seen this used before, or even mentioned.
Is this in the documentation?
So I guess I will have to play with this...  is the _GRANITE_FILE_INC_
"operating on" the #local Granite_file declaration ...?  Does it need the _INC_
part then...?
I'm even more confused by the #local Granite_file = "DakotaRedGranite.inc" when
the actual file name isn't capitalized.   Maybe I've run out of dried frog
pills....
> already.
Well, yes, but what I mean is that instead of:
array [Map1_entries][4] {
  {0.00, not_0, not_0, not_0},
it might be preferable to have:
array [Map1_entries][2] {
  {0.00, <not_0, not_0, not_0>},
or
  {0.00, <not_0, not_0, not_0, not_0, not_0>},
I am riding the struggle bus here.
Convert () returns a basic rgb, not an rgbft,
and map2 has transmit, yes, but not filter.
My thought was that the macro should accommodate full 5D color vectors
everywhere, because we have the Norbert Kern / Sean Day / Robert McGregor types
who will squeeze every last bit of artistic flair out this if allowed to.
You certainly have your own tricks up your sleeves that keep me on mine!!
Date: 1 Jun 2021 02:59:48
Message: <60b5dae4@news.povray.org>
Op 31/05/2021 om 20:06 schreef Bald Eagle:
> You're killin' me.
No idea. I guess I learned it from a 'smart one'. I would not be
surprised if that was Sam Benge. But others have used the trick too I am
convinced.
> part then...?
Now you ask too much ;-) A learned one like William Pokorny may know...
> pills....
This is one of those cases where DFP do not help I am afraid. I do not
know th mechanism but it works. Same as my laptop: no idea how it
functions... ;-)
>> already.
> or
I am not a fan of this... The first would be a possibility... hmm, I
have to think about this a bit. For instance, Map1 /never/ should have
any filter or transmit info.
They are free to try, but have to play by my rules ;-) For different
reasons, I have restricted the use of transmit to the veins where
filters are not allowed and imo, are not recommended.
Veins, btw, is still an issue of course.
Glad to be of help :-)
Date: 1 Jun 2021 08:35:00
Message: <60b62974$1@news.povray.org>
Op 1-6-2021 om 08:59 schreef Thomas de Groot:
>> the _INC_
>> part then...?
>> frog
>> pills....
Well... it appears I am in serious need of a fresh batch of the "Super
Strong Extra" frog pills myself. :-/
Don't ask me how or why I completely messed up here, that will be food
for the psychiatrist; I have an inkling but that is for another time.
Your bewilderment was completely right and I got the full bucket of cold
water on my head the moment when I /really/ tested with a new granite
include file. As you can guess ("I told you so") it did not work.
So, after having flogged myself almost senseless, I guess the following
lines should replace the offensive ones in the macro:
#ifndef (Granite_file)  #local Granite_file = "DakotaRedGranite.inc"  #end
Also, to make successive calls of the macro more comprehensive (for
now), add the following line in section 7:
#undef Granite_file
This seems to work correctly, at least for me. Hope it does for you too
of course.
Yeah... my sleeves are full of holes and I often get pretty blind to
them... ;-[
Date: 1 Jun 2021 08:50:00
Message: <60b62cf8$1@news.povray.org>
Op 31-5-2021 om 03:41 schreef Bald Eagle:
>> - A comprehensive demo scene file
>> - An investigation/implementation of Real World dimensions (should have
>> started with that, but you know of it goes...)
>> - Additional xxxGranite.inc files to be fed to the macro
> So I was playing with a scene for editing the material's color_map, and in
> addition to the inc file stuff, I noticed that you had removed all of the macro
> parameters.
> I think that works really nicely, so far.
> On the one hand, I like the #undef stuff at the end, but with what I'm doing
> with variations on the same theme, I noticed that that causes me to have to
> redeclare any macro parameters before each call.  No big deal - I can work with
> that.
Yes, but it might not be the best solution...
> But I'm thinking if it doesn't change anything, maybe have it work like
> Granite_21 (optional parameters_persist)
> (default is no)
> and then #if (parameters_persist) would govern macro section 7
Problem is that the 'optional' parameter is still only version 3.8 of
POV. Not desirable for now I am afraid.
> I have some things laid out with to-scale rulers, and with respect to the SSLT
> I'm wondering what I should do to indicate the - depth - of the translucency
> effect.  I'm not sure that I know of an equation / documentation / diagram for
> calculating / estimating the effect given an rgb 1 light_source and material
> thickness.
After all the commotion about the Granite_file, I still have to plunge
into this.
> I'm going to try to figure out a way to get as much useful visual info into the
> scene, but minimize the long render time effect of the SSLT.
> Perhaps as a lead-in to the documentation, you could just briefly comment on the
> layout and purpose of the macro parts - the masks and such?
I shall see what I can do on short term....
> Thanks,
> - Bill
> Attached is highlighting 2 color_map entries in green, and then replacing them
> with black.  Just a little macro to make it easier to do from within the scene
> file.
That could be nice indeed... The original color_maps will need a serious
overhaul I am afraid.
Date: 1 Jun 2021 16:20:00
Message: <web.60b69548388d0b7adbe79f5e699c58ab@news.povray.org>
> You're killin' me.
> part then...?
This is a lifting of a "protection" mechanism from the C language (at least
that's where I first encountered it).
The basic form is in your main .c file is:
#include <somefile.h>
#include <someotherfile.h>
Assume that somefile.h also includes other files, and those include others.
Further assume that someotherfile.h also includes other files.  If it ends up
that some set of includes is /duplicated/ then you run into problems.
So, to avoid that, in C somefile.h will contain something like this:
/* file: somefile.h */
/* defines some stuff */
ifndef(_SOMEFILE_H_)
 #define _SOMEFILE_H_
 #declare bob=1
 #declare ted=2
The idea is that each include file defines the variable name associated with
that file, so that if that include file is hit /again/ when resolving includes
the first ifndef line will discover that, the include file contents will be
'skipped', and nothing /more/ will happen.
I'm not aware of any 'magic' that happens in povscript WRT defining a
_filename_INC_ variable, but there could be such.
(hope this helps clear up the concept)
Date: 1 Jun 2021 17:45:00
Message: <web.60b6a96a388d0b7a1f9dae3025979125@news.povray.org>
Thanks, James - I have seen that type of thing in the various POV-Ray include
files, and probably in some source and arduino code.  I thought that's what was
getting done, but at present it seems that TdG was trying to invoke some kind of
POV "woo".
Yeah - I was stunned that there was some such thing that I had never heard of or
seen.  On the other hand, it's an interesting concept - maybe a clever macro
could "search" for all variants of a particular filename...
So do I.  The world just keeps getting cloudier, murkier, more opaque, and more
obscure as time goes on it seems...
I'm going to sacrifice another lime and offer up a supplication that Thomas gets
the rest, therapy, - and medication - that he so desperately needs to find
clarity of mind and inner peace.  We love you, Thomas.   Help is always just a
forum-post away.   :)
