POV-Ray : Newsgroups : povray.binaries.images : Friday Afternoon Doodle Server Time
12 Jul 2025 23:17:08 EDT (-0400)
  Friday Afternoon Doodle (Message 4 to 13 of 13)
<<< Previous 3 Messages Goto Initial 10 Messages
Subject: Re: Friday Afternoon Doodle
Date: 7 Mar 2022 06:00:00
Message: <web.6225e45c15dda32b4cef624e6e066e29@news.povray.org>
"Chris R" <car### [at] comcastnet> wrote:
> So I've been playing around with shapes extruded along one of the axes, by
> changing the rounding parameter and the scaling parameters on the other two
> axes, as well as translating the center of the rounded box along those two other
> axes in various ways, including linear interpolation, spline interpolation, and
> various other functions.
> This is the one where the scale decreases linearly from bottom to top, the
> rounding factor decreases linearly from bottom to top, and the x and z centers
> of the box are translated using sin(y*2*pi/height) and cos(y*2*pi/height).
That's a nice result, and a clever use of functions. And gold colors! I assume
that this is just one function-object, not a 'combination' of several function
shapes?
I experimented with function-based isosurfaces years ago, but have forgotten
some of the finer points, like how to 'taper' an object (like you did in y.) But
I happened to be playing around with this same kind of technique this week! I
can make a nice sine-wave shape, but what is the trick for getting the shape to
taper or scale so nicely? IIRC, it is something relatively simple-- but I
can't remember what :-(
Date: 7 Mar 2022 06:50:00
Message: <web.6225f0e015dda32b1f9dae3025979125@news.povray.org>
IIRC, I emailed you a copy of Mike Williams' isosurface tutorial, which is no
longer on the internet.   :(  Not sure if I can post .odt or .pdf files to this
server anywhere...
I think what you're looking for is under "variable substitution" or something
similar.
We should have a section of the website for archiving these master reference
works - like Friedrich Lohmueller's site.
Date: 7 Mar 2022 09:45:00
Message: <web.62261a6115dda32bd6fc33af5cc1b6e@news.povray.org>
William F Pokorny <ano### [at] anonymousorg> wrote:
> On 3/4/22 16:29, Chris R wrote:
> > One of the things I've noticed is how fast and clean isosurfaces based on built
> > in functions, like f_rounded_box are, and how bad any of my attempts at doing
> > extruded shapes end up being, so I thought about using an isosurface to extrude
> > f_rounded_box.
> Cool shape! :-)
> Yep, isosufaces are sometimes more flexible and faster than other
> shape/surface options! However, as with most things in POV-Ray, where
> they work best depends greatly on particulars.
> Note. IIRC, the f_rounded_box() function has a changing gradient outside
> everywhere and into the rounded box only to the rounding radius - after
> which the returned values become fixed 'inside.' This makes the function
> difficult / impossible to use in many more complex situations. In other
> words. it's a function which can be difficult to use other than as a
> stand alone shape(1).
> Bill P.
> (1) - Why the povr fork added an explicit f_box() inbuilt.
Yes, I have noticed that, especially when attempting to add a wood pigment
function to the exterior with the grain pushing into the box with a very small
rounding radius.  It seems fine for a grain extending out of the box.
-- Chris R.
Date: 7 Mar 2022 10:05:00
Message: <web.62261e5e15dda32bd6fc33af5cc1b6e@news.povray.org>
> shapes?
Here's a pretty simple example with linear tapering.  I did something similar
with the image above, but embedded the tapering in functions instead.
#macro TaperedBox(SizeBase,SizeTop,RoundingBase,RoundingTop,Height)
   #local _xSlope = (SizeTop.x - SizeBase.x)/(2*Height);
   #local _zSlope = (SizeTop.z - SizeBase.z)/(2*Height);
   #local _rndSlope = (RoundingTop - RoundingBase)/Height;
   #local _xScaleBase = SizeBase.x/2;
   #local _zScaleBase = SizeBase.z/2;
   #local _xScaleFn = function(l) {
      _xScaleBase + _xSlope*l
   #local _zScaleFn = function(l) {
      _yScaleBase + _ySlope*l
   #local _rndFn = function(l) {
      RoundingBase + _rndSlope*l
   #local _sy = Height/2;
   #local _shapeFn = function(x,y,z) {
      f_rounded_box(x, y, z, _rndFn(y+_sy), _xScaleFn(y+_sy), _sy,
_zScaleFn(y+_sy))
   #local _maxx = max(SizeBase.x,SizeTop.x)/2;
   #local _maxz = max(SizeBase.z,SizeTop.z)/2;
   #local _lbounds = -<_maxx, _sy, _maxz>;
   #local _ubounds = <_maxx, _sy, _maxz>;
   #local _shape = isosurface {
      function {
         _shapeFn(x,y,z)
      threshold 0
      contained_by { box { _lbounds, _ubounds } }
   #undef _shapeFn
   #undef _rndFn
   #undef _zScaleFn
   #undef _xScaleFn
   _shape
TaperedBox(<2,2>, <1,1>, 0.2, 0.1, 2)
I have purposefully, pedantically, broken things out, because it helps me
remember why I wrote the code when I go back to it months down the line.
This should give you a truncated pyramid with a rounded bottom, rounded edges,
with the rounding decreasing as you move up the pyramid.
I use the RC3 Metal macros to create the gold texture.
-- Chris R.
Date: 7 Mar 2022 14:00:00
Message: <web.6226560215dda32bd6fc33af5cc1b6e@news.povray.org>
> > shapes?
>       _zScaleBase + _ySlope*l
> _zScaleFn(y+_sy))
>       function {
>          _shapeFn(x,y,z)
>       threshold 0
>    #undef _shapeFn
>    #undef _rndFn
>    #undef _zScaleFn
>    #undef _xScaleFn
>    _shape
> #end
> -- Chris R.
Sorry, transcription error, yScaleBase should have been zScaleBase in _zScaleFn
-- Chris R.
Date: 7 Mar 2022 18:50:00
Message: <web.6226991515dda32b4cef624e6e066e29@news.povray.org>
> ...what is the trick for getting the shape to
> server anywhere...
> similar.
Yes, I remember reading part of that last year! So I re-read our email
exchanges... but there's no attachment there(!) :-(  Damn. I've been looking all
over my Win10 computer today for that tutorial, but can't find it. I'm thinking
that *maybe* you posted it to a newsgroup thread instead(?), sometime prior to
April 2021. But I haven't had any luck searching the newsgroups either. Bummer!
I know I have it *somewhere*...
Date: 7 Mar 2022 19:25:00
Message: <web.6226a1d015dda32b1f9dae3025979125@news.povray.org>
Backup email and attachments incoming...
Date: 7 Mar 2022 20:20:00
Message: <web.6226ad3b15dda32b4cef624e6e066e29@news.povray.org>
> [code snip]
Thanks! That's really interesting (and a bit more complex than I thought, ha.)
Now I can play around, to see what I can muck up! :-O
I had to make some minor changes to your code to get it to run-- replacing some
z's with y's -- probably because the macro call uses two-part vectors, like
<2,2> for the 'SizeBase' etc. So that would be like <x,y> (or even <u,v>)
instead of <x,z>... which POV-ray chokes on ;-) At least in Windows.
I've attached my own trial image... just as a sanity check, to make sure I'm
seeing what you intended!
BTW, there are a few interesting pieces of your code that I'm clueless about, as
to what they mean and how they work. Example:
That's a lower-case 'L'. I'm familiar with the typical x (or y or z) use in a
function-- which AFAIU usually represent spatial axes--  but I have never used
just a 'generic' letter as a substitute. Could you briefly explain what that
means, in the context of your code?
Anyway, thanks again for the example!
#include "functions.inc"
  // #local _zSlope = (SizeTop.z - SizeBase.z)/(2*Height); // [ORIGINAL]
   #local _zSlope = (SizeTop.y - SizeBase.y)/(2*Height); // changed both to y
  // #local _zScaleBase = SizeBase.z/2; // [ORIGINAL]
   #local _zScaleBase = SizeBase.y/2; // changed to y
    //  _yScaleBase + _ySlope*l   // [ORIGINAL]
        _zScaleBase + _zSlope*l // [update]
_zScaleFn(y+_sy))
  // #local _maxz = max(SizeBase.z,SizeTop.z)/2; // [ORIGINAL]
   #local _maxz = max(SizeBase.y,SizeTop.y)/2; // changed both to y
      function {
         _shapeFn(x,y,z)
      threshold 0
   #undef _shapeFn
   #undef _rndFn
   #undef _zScaleFn
   #undef _xScaleFn
   _shape
Download 'isosurface_tapering_example_1.jpg' (10 KB)
Preview of image 'isosurface_tapering_example_1.jpg'
Date: 8 Mar 2022 07:47:05
Message: <62275049$1@news.povray.org>
Op 8-3-2022 om 02:15 schreef Kenneth:
Yep. Me too.
I second that!
Date: 8 Mar 2022 12:55:00
Message: <web.6227974915dda32b89a9c4065cc1b6e@news.povray.org>
> > [code snip]
> _zScaleFn(y+_sy))
>       function {
>          _shapeFn(x,y,z)
>       threshold 0
>    #undef _shapeFn
>    #undef _rndFn
>    #undef _zScaleFn
>    #undef _xScaleFn
>    _shape
> #end
Yes, that's exactly it.  And I apologize for the x/y/z errors.  I originally
wrote the macro to move along the Z axis and then rotated the object to stand it
upright for the image, and then didn't get all of the mental rotations right in
the text above.
By default, if you define a function, it takes three arguments (x,y,z).
However, you can declare it with any parameters you want; (hence
f_rounded_box(x,y,z,rnd,sx,sy,sz))
Since my scaling function only depends on the distance along the extrusion axis,
and I might want to reuse that function in some other object along a different
axis, I just declared it to be a function with one parameter, called "l".  When
it is actually called, I can give it any axis I want.
I have a computer programming background, and the C compiler flags unused
parameters as wasteful and confusing, so I tend to define my functions just to
include the parameters I need in the body, and give them meaningful names.
-- Chris R
