![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Hi!
Problem with matrixes. :(
#version 3.7;
#include "shapes.inc"
#include "functions.inc"
global_settings {
assumed_gamma 1.000000
sky_sphere {
pigment {rgb<0.050, 0.050, 0.050>}
#declare Default_texture = texture{pigment {rgb 0.8}}
#declare Material = texture{
pigment{color rgbft <0.8000,0.0388,0.1277,0.0000,0.0000>}
finish{
diffuse 0.8000
brilliance 1.8000
crand 0.0000
emission 0.0000
ambient <0.0000,0.0000,0.0000>
#declare data_Box_shape_003_ob = box { -1,1
texture {Material}
#declare data_Cone_shape_001_ob = cone {
<0,0,-1.0000>,1.0000,<0,0,1.0000>,0.3000
texture {Default_texture}
#declare data_Box_shape_ob = box { -1,1
#declare data_Box_shape_001_ob = box { -1,1
texture {Material}
#declare data_Box_shape_002_ob = box { -1,1
texture {Material}
#declare data_Boolean_000_ob =
difference {
union {
object {data_Box_shape_ob
matrix <1.000000, 0.000000, 0.000000, 0.000000, -0.000000, -1.000000,
0.000000, 1.609000, -0.000000, 3.005314, 0.000000, 0.000000>
object {data_Cone_shape_001_ob
matrix <1.000000, 0.000000, 0.000000, 0.000000, 1.000000, 0.000000,
0.000000, 0.000000, 2.432501, 2.941242, 0.000000, 0.000000>
#declare data_Boolean_001_ob =
difference {
union {
object {data_Boolean_000_ob
rotate x*90
0.000000, 1.609000, -0.000000, -0.840426, 0.000000, 0.000000>
object {data_Box_shape_003_ob
matrix <0.166166, 0.000000, 0.000000, 0.000000, -0.000000, -0.166166,
0.000000, 0.166166, -0.000000, 0.000000, 1.426066, 1.168468>
object {data_Boolean_001_ob
rotate x*90
0.000000, 1.609000, -0.000000, 1.365901, 0.000000, 0.000000>
object {data_Box_shape_001_ob
0.000000, 0.166166, -0.000000, 0.000000, -1.779218, 1.168468>
object {data_Box_shape_002_ob
0.000000, 1.297221, -0.000000, 2.212118, 1.555311, 0.825095>
light_source {
<5.07,5.58,4.28>
color rgb<1, 1, 1>
fade_distance 25.0000000000
fade_power 1
perspective
location <0,0,0>
look_at <0,0,-1>
right <-1.7777777777777777, 0, 0>
up <0, 1, 0>
angle 49.134343
rotate <-27.098163, 46.688390, -0.903519>
translate <7.481132, 5.343666, 6.507640>
Download 'csg-problem.jpg' (90 KB)
Preview of image 'csg-problem.jpg'
![csg-problem.jpg](/povray.binaries.images/attachment/%3Cweb.55c64901a06367f07a3e03fe0%40news.povray.org%3E/csg-problem.jpg?preview=1)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
"LanuHum" <Lan### [at] yandex ru> wrote:
> Hi!
> #version 3.7;
> global_settings {
> sky_sphere {
> finish{
> diffuse 0.8000
> brilliance 1.8000
> crand 0.0000
> emission 0.0000
> texture {Material}
> texture {Material}
> texture {Material}
> difference {
> union {
> difference {
> union {
> rotate x*90
> rotate x*90
> light_source {
> <5.07,5.58,4.28>
> color rgb<1, 1, 1>
> fade_power 1
> camera {
> perspective
> location <0,0,0>
> look_at <0,0,-1>
> up <0, 1, 0>
> angle 49.134343
without further explanation of what you're trying to accomplish, the only thing
I can see is that your z axis appears to be flipped between the wireframe on the
right and the render on the left.
Your camera is a lot more complex than I would normally use, but I assume this
is a result of export from blender.
Normally, I would simply have
up y
right x*(image_width/image_height)
and adjust my height and width on the command line, or via an ini file.
I assume specifying the angle compensates for distortion in the foreground from
having a wide format aspect ratio with a perspective camera...
I also notice that you've converted your camera for a right-handed coordinate
system by negating the aspect ratio and looking toward the negative z... This
might explain the flipped axis. Is blender right-handed or left?
A.D.B.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> up y
> Regards,
> A.D.B.
There are objects which are correctly displayed. Color - red. Look in the
3D-viewport.
Only csg are incorrectly displayed. What does it have to do with camera?
I create box:
#declare obBox = box{}
I create cone:
#declare obCone = cone{}
I create csg:
#declare obBox_Minus_obCone = difference{
object {obBox matrixBox}
object {obCone matrixCone}
I make transformation and I declare:
object{obBox_Minus_obCone matrixObBox_Minus_obCone}
Result wrong
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> > up y
> > Regards,
> > A.D.B.
> 3D-viewport.
> I create box:
> I create cone:
> I create csg:
> Result wrong
As near as I can tell, your objects are exactly where your matrix
transformations say they should be, though that's a really ambiguous way of
performing a scale and translate.
the offending translations appear to be happening in your difference objects.
matrix <
and
matrix <
Respectively, seem to have the objects shifted in the positive x axis.
I inserted axes using:
union {
cylinder { -1e5*x, 1e5*x 1/128 pigment { rgb <1,0,0> } }
cylinder { -1e5*y, 1e5*y 1/128 pigment { rgb <0,1,0> } }
cylinder { -1e5*z, 1e5*z 1/128 pigment { rgb <0,0,1> } }
x: red
y: green
z: blue
A.D.B.
Download 'lanu01.png' (111 KB)
Preview of image 'lanu01.png'
![lanu01.png](/povray.binaries.images/attachment/%3Cweb.55c6e45d4327e3232aaea5cb0%40news.povray.org%3E/lanu01.png?preview=1)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I edited your description for legibility, and added a camera above, looking
down:
#version 3.7;
global_settings {
sky_sphere {
finish{
diffuse 0.8000
brilliance 1.8000
crand 0.0000
emission 0.0000
texture {Material}
texture {Material}
texture {Material}
difference {
union {
difference {
union {
rotate x*90
rotate x*90
light_source {
<5.07,5.58,4.28>
color rgb<1, 1, 1>
fade_power 1
perspective
location <0,0,0>
look_at <0,0,-1>
up <0, 1, 0>
angle 49.134343
// Camera above, looking down
perspective
location <0.0, 10, 0.06>
up z
look_at 0
union {
You'll notice that things weren't exactly as they seemed in the isometric view
that blender provides.
This is one of the things I dislike about the controls in blender. They don't
provide you per-axis translation, so you can't be certain that things are where
you think they are.
Unless blender has an orthographic three-panel view that I haven't found...
A.D.B.
Download 'lanu02_topdown.png' (42 KB)
Preview of image 'lanu02_topdown.png'
![lanu02_topdown.png](/povray.binaries.images/attachment/%3Cweb.55c6edc04327e3232aaea5cb0%40news.povray.org%3E/lanu02_topdown.png?preview=1)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
It's hard to tell in the image on the right what is solid and what isn't
due to the transparency.
Mike
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> Regards,
> A.D.B.
In 3D-window: Menu => View => Toggle Quad View
#version 3.7;
global_settings {
sky_sphere {
pigment{color rgbft <0.8000,0.0300,0.0546,0.0000,0.0000>}
#declare Material_001 = texture{
pigment{color rgbft <0.8000,0.0510,0.0190,0.0000,0.0000>}
#declare Material_002 = texture{
pigment{color rgbft <0.7838,0.8000,0.0830,0.0000,0.0000>}
#declare data_Box_shape_006_ob = box { -1,1
texture {Material_001}
#declare data_Box_shape_005_ob = box { -1,1
#declare data_Box_shape_004_ob = box { -1,1
#declare data_Cone_shape_ob = cone { <0,0,-1.0000>,1.0000,<0,0,1.0000>,0.3000
texture {Material}
texture {Material_002}
#declare data_Boolean_002_ob =
difference {
union {
0.000000, 2.166961, -0.000000, 0.000000, 0.000000, 0.000000>
object {data_Cone_shape_ob
texture {Material}
matrix <1.073773, 0.000000, 0.000000, 0.000000, -1.038544, -0.272790,
0.000000, 0.272790, -1.038544, 0.000000, 0.000000, 0.598508>
difference {
union {
texture {Material}
#declare data_Boolean_ob =
difference {
union {
texture {Material}
object {data_Boolean_002_ob
rotate x*90
matrix <0.702762, 0.000000, 0.000000, 0.000000, -0.000000, -0.702762,
0.000000, 1.522857, -0.000000, -1.625485, 0.000000, 0.000000>
rotate x*90
0.000000, 1.522857, -0.000000, 1.729432, 0.000000, 0.000000>
object {data_Box_shape_006_ob
matrix <0.000000, -2.966263, 0.000000, 0.000000, -0.000000, -0.118176,
0.118176, 0.000000, 0.000000, 0.000000, -0.098659, 0.806181>
object {data_Box_shape_005_ob
0.118176, 0.000000, 0.000000, 0.012403, -0.098659, -0.806181>
object {data_Box_shape_004_ob
0.118176, 0.000000, 0.000000, 0.855792, -0.098659, 0.000000>
0.118176, 0.000000, 0.000000, -0.744167, -0.098659, 0.000000>
matrix <2.966263, 0.000000, 0.000000, 0.000000, -0.000000, -0.118176,
0.000000, 0.118176, -0.000000, 0.000000, -1.649006, 0.000000>
0.000000, 0.118176, -0.000000, 0.000000, 1.635401, -0.000000>
object {data_Boolean_ob
rotate x*90
0.000000, 1.522857, -0.000000, 0.000000, 0.000000, 0.000000>
light_source {
<5.07,5.58,4.28>
color rgb<1, 1, 1>
fade_power 1
perspective
location <0,0,0>
look_at <0,0,-1>
up <0, 1, 0>
angle 49.134343
Download 'for_views.jpg' (271 KB)
Preview of image 'for_views.jpg'
![for_views.jpg](/povray.binaries.images/attachment/%3Cweb.55c70fd34327e3237a3e03fe0%40news.povray.org%3E/for_views.jpg?preview=1)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Am 08.08.2015 um 20:22 schrieb LanuHum:
> Hi!
It's difficult for me to tell from the images what's happening; however,
in general I would check...:
- whether the matrix export /per se/ works properly, and puts the
coefficients in the right order; and
- whether in this case the actual matrix should be exported, or its
inverse instead.
Also, if in Blender the transformation is stored in a different format
(like a set of rotation and a scaling operations), then I would suggest
exporting those, instead of trying to "bake" them into a matrix.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
If the object is transformed by modifiers, I can't receive its arrangement
without matrix:
translate = matrix.translation[:]
rotate = tuple([degrees(e) for e in matrix.to_3x3().to_euler()])
scale = matrix.to_scale()[:]
But, without modifiers - seldom it is ( little) used.
Orientation of the exporter - animation.
The user will use armature (bones), array, array with curve, dupliverts,
dupliface, dupliframe, dupligroup, particles.
All coordinates are calculated from object.matrix_world
> inverse instead.
matrix.inverse csg or components?
I in matrixes understand nothing!!! :(
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Am 09.08.2015 um 20:29 schrieb LanuHum:
>> inverse instead.
I'm refering to the matrix inverse here. In a nutshell, a matrix's
inverse is the matrix that, when applied, reverts the effect of applying
the matrix itself: If the original matrix applies a rotation, the
inverse applies the opposite rotation; if the original matrix applies a
scaling by the factor N in any direction, the inverse applies a scaling
by the factor 1/N in that same direction; if the original matrix applies
a translation by a vector V, the inverse applies a translation by -V;
and if a matrix applies any combination of the above in a particular
order, the inverse applies the respective inverse of the individual
operations in reverse order.
In raytracing, a transformation matrix's inverse is needed internally
for some computations, so maybe in some cases, what Blender considers
"the operation" might be what POV-Ray considers "the inverse of the
operation".
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
