POV-Ray : Newsgroups : povray.binaries.images : Realistic rusty bearing Server Time
16 Mar 2026 17:35:16 EDT (-0400)
  Realistic rusty bearing (Message 5 to 14 of 14)
<<< Previous 4 Messages Goto Initial 10 Messages
Subject: Re: Realistic rusty bearing
Date: 8 Feb 2014 08:14:46
Message: <52f62dc6@news.povray.org>
Some thoughts about different settings.
ini file: Display_Gamma=1
Using version 3.7, you may want to take advantage of the sRGB colour
space. Personally, I have my Display_Gamma set permanently to: sRGB.
Pigments:
You may want to play with srgb too inside the pigments. Change all 'rgb'
to 'srgb' and see the difference. If you want exactly the same output
you may need to tweak the rgb values, making them lighter.
Textures:
After some more testing and for a better result, I advice to change the
XE_rusty_steel texture to:
#declare XE_rusty_steel =
	bozo
	texture_map
		[ 0.0 XE_rust ]
		[ 0.2 XE_rust ]
		[ 0.5 XE_steel ]
		[ 1.0 XE_steel ]
	turbulence 1
	omega .6
	lambda 4
	warp { turbulence 1 }
Using sRGB colours without changing their values, you get the following
image. Left = XE_rusty_iron; Right = XE_rusty_steel.
Download 'rusty_bearing.png' (553 KB)
Preview of image 'rusty_bearing.png'
Date: 8 Feb 2014 08:40:00
Message: <web.52f63388190970a57a3e03fe0@news.povray.org>
> How about this? Different variations possible (see below). Textures
> courtesy of Xplo Eristotle.
> //start code
> // Metal textures by Xplo Eristotle
> #declare XE_iron_2 =
> texture {
>  pigment {
>    marble
>    pigment_map {
>      [0.00 color rgb <0.25, 0.25, 0.25>]
>      [0.20 color rgb <0.30, 0.30, 0.30>]
>      [0.45 color rgb <0.809995, 0.299123, 0.113405>*0.8]
>      [0.50 color rgb <0.25, 0.25, 0.25>]
>      [0.65 color rgb <0.23, 0.23, 0.23>]
>      [0.90 color rgb <0.24, 0.24, 0.24>]
>      [1.00 color rgb <0.25, 0.25, 0.25>]
>    scale 0.2
>    warp {turbulence 0.5}
>  normal {granite 0.3  scale 0.2}
>  finish {
>    roughness 0.01
>    specular 0.5
>    reflection 0.05
>    diffuse 0.8
> texture {
>  bozo
>  texture_map
>   [ 0.0 XE_rust ]
>   [ 0.2 XE_rust ]
>   [ 0.5 XE_iron ]
>   [ 0.6 XE_steel ]
>   [ 1.0 XE_steel ]
>  turbulence 1
>  omega .6
>  lambda 4
> //end code
> Thomas
XE_iron_2 declare, but not used.
Date: 8 Feb 2014 10:32:31
Message: <52f64e0f$1@news.povray.org>
>> //start code
>> texture {
>>   pigment {
>>     marble
>>     pigment_map {
>>     scale 0.2
>>   finish {
>>     roughness 0.01
>>     specular 0.5
>>     reflection 0.05
>>     diffuse 0.8
>> texture {
>>   bozo
>>   texture_map
>>    [ 0.0 XE_rust ]
>>    [ 0.2 XE_rust ]
>>    [ 0.5 XE_iron ]
>>    [ 0.6 XE_steel ]
>>    [ 1.0 XE_steel ]
>>   turbulence 1
>>   omega .6
>>   lambda 4
>> //end code
>> Thomas
Yes, you can choose your own combinations ;-)
Date: 8 Feb 2014 12:05:01
Message: <web.52f6632f190970a57a3e03fe0@news.povray.org>
> Thomas
I already understood it.
But, it would be desirable to see still options of other users.
Me completely rusty surface interests also.
And, for some reason it seems to me that normal works at the bearing badly.
Date: 9 Feb 2014 03:56:24
Message: <52f742b8@news.povray.org>
In p.b.scene-files I have given a collection of rusty metals by several
authors.
In the image: left = Ke_old_pitted_iron from the collection. normals are
looking 'normal' to my eyes ;-)
Download 'rusty_bearing.png' (702 KB)
Date: 9 Feb 2014 07:58:17
Message: <52f77b69@news.povray.org>
And as I am never entirely satisfied, here is a version with a HDRI
environment.
Left = XE_rusty_steel; Right = Ke_old_pitted_iron
Download 'rusty_bearing.png' (953 KB)
Date: 9 Feb 2014 08:20:00
Message: <web.52f78063190970a57a3e03fe0@news.povray.org>
> environment.
> Thomas
Thanks! On our site any technical problem, I can't enter to share your finds!
Very good materials! Thank you!
Date: 1 Sep 2014 10:30:01
Message: <web.5404820e190970a51fc1cbd50@news.povray.org>
> authors.
> Thomas
I have searched there Thomas ...
but can't seem to locate them.
Can you point more closely? ;)
tnx
terry
Date: 1 Sep 2014 11:20:46
Message: <54048ece$1@news.povray.org>
Am 01.09.2014 16:26, schrieb -ts-:
>> authors.
>> Thomas
That was in a thread also started by LanuHum, titled "Rusty bearing".
Date: 2 Sep 2014 03:21:33
Message: <54056ffd$1@news.povray.org>
Well, thanks indeed; I did not remember where I had put it. :-)
