POV-Ray : Newsgroups : povray.binaries.images : Sphere_sweep: gradient along a curve. Server Time
11 Apr 2026 10:42:02 EDT (-0400)
  Sphere_sweep: gradient along a curve. (Message 1 to 10 of 51)
Subject: Sphere_sweep: gradient along a curve.
Date: 22 Jan 2014 12:05:00
Message: <web.52dff97746aac96b7a3e03fe0@news.povray.org>
Hi!
Sorry!
For creation and a coloring of this curve I used while
I want to learn, whether it is possible to paint so sphere_sweep? I can't.
Povray doesn't want to create 4000 curves using while: it is a big problem at
creation of hair. :(
Thanks!
Download 'povwip.png' (18 KB)
Preview of image 'povwip.png'
Subject: Re: Sphere_sweep: gradient along a curve.
Date: 22 Jan 2014 13:49:26
Message: <52e012b6@news.povray.org>
Le 22/01/2014 18:02, LanuHum nous fit lire :
> Hi!
> Sorry!
One rule of povray: the pattern/color is 3D distributed, the shape is
just immersed in the pattern.
(forget about UV-mapping)
Date: 22 Jan 2014 14:00:01
Message: <web.52e014bba5ee4db87a3e03fe0@news.povray.org>
I understood nothing :(
Date: 22 Jan 2014 16:00:01
Message: <web.52e0313ba5ee4db891114470@news.povray.org>
Let me try; the sphere_sweep is not UV mapped, it only displays patterns that
are distributed across it through 3D world space. That means a gradient won't
work like it would on a UV map.
You could normalize the texture distribution on the sweep first, over a certain
axis, then transform it into position to maintain those colors...
www.McGregorFineArt.com
Date: 22 Jan 2014 16:05:01
Message: <web.52e03238a5ee4db891114470@news.povray.org>
Could also save UV mapped parametric mesh representations of the sweeps and
render those just as one normally would expect the hair to be textured.
Date: 22 Jan 2014 16:12:18
Message: <52e03432$1@news.povray.org>
> Hi!
> Sorry!
> Thanks!
If I understand you want to create more than 4000 curves using while and
sphere_sweep?
Do not judge my words, judge my actions.
http://www.avast.com
Date: 23 Jan 2014 01:40:00
Message: <web.52e0b8b1a5ee4db86e3fa5c50@news.povray.org>
That's right. It's just like that object intersect the pattern.
Date: 23 Jan 2014 03:14:27
Message: <52e0cf63$1@news.povray.org>
Interesting, but I am lost about your two solutions ;-) would you mind
to give us a little piece of code?
Date: 23 Jan 2014 07:01:46
Message: <52e104aa@news.povray.org>
>> Hi!
>> Sorry!
>> problem at
>> Thanks!
> sphere_sweep?
This image contains 5000 curves made with sphere_sweep and a while loop.
It is that you want?
Download 'call_rand_curve_test_hair.bmp.dat' (586 KB)
Date: 23 Jan 2014 11:15:00
Message: <web.52e13f37a5ee4db87a3e03fe0@news.povray.org>
Hair in a blender are presented by the array from splines.
Developers of the official version of the Blender2Povray exporter used these
splines for sphere_sweeps array creation.
Povray counts sphere_sweep enough, but,
I had an idea to streak hair, to decolour tips of hair as it is done by some
people in beauty shops or hairdressing salons.
I tried to paint sphere_sweep as necessary.
At me it didn't turn out.
Therefore I addressed to other way to use the array of splines of the Blender:
while
But, I can't use the second way to receive all hair: the system hangs.
Therefore here I asked a question of opportunity correctly to paint sphere_sweep
From all comments I understood that such opportunity isn't present.
I can't make transformation of hair after texturing
Maximum of hair by means of while
Download 'povhair.png' (397 KB)
Preview of image 'povhair.png'
