POV-Ray : Newsgroups : povray.binaries.images : Sphere_sweep: gradient along a curve. Server Time
14 Mar 2026 05:15:27 EDT (-0400)
  Sphere_sweep: gradient along a curve. (Message 31 to 40 of 51)
Subject: Re: Sphere_sweep: gradient along a curve.
Date: 11 Feb 2014 08:50:00
Message: <web.52fa29ffa5ee4db891114470@news.povray.org>
Le_Forgeron <lef### [at] freefr> wrote:
> Le 11/02/2014 00:14, Robert McGregor a écrit :
> > If POV-Ray could auto-calculate UVs on sphere_sweeps at render time, that would
> > be the optimal solution to this... maybe a simple patch can fix it.
> Something like u being the "position" on the sphere_sweep and v being
> the circumference ?
> A few questions:
> * for u, what is the range ? 0 to 1 for the whole sphere_sweep, or 0 to
> n-1, n being the number of coordinates ?
> * for v, most complex: how to orient it (where is 0 ?)
Exactly: u = spline position, v = circumference
I think a normalized u over 0-1 range for the entire sweep would make texturing
more manageable, using something like:
sphere_sweep {
   texture { uv_mapping
         gradient u
         color_map { [0 rgb <1,0,0>][1 rgb <0,1,0>]] }
The starting position for v shouldn't matter as it's a seamless loop around the
circumference (like cylindrical mapping).
www.McGregorFineArt.com
Date: 11 Feb 2014 09:57:56
Message: <52fa3a74@news.povray.org>
it's not the starting position, it's keeping it coherent along the
various components... maybe a target position such as <0,0,0> to define
the 0, and a clockwise or anticlockwise rotation to increase the value.
Yet it fails when the spheresweep pass through the target position.
Putting the target position at some infinity does not work either, when
the direction of the cylinder/conic is aligned with that direction.
An easy cheating would be u only, v is always 0 (or 0.5), but it's bad.
You can ignore v, but it should be defined... and not constant.
It's also problematic when on a connecting sphere (at one of the vertex).
Just because nobody complains does not mean all parachutes are perfect.
Date: 11 Feb 2014 12:05:01
Message: <web.52fa579ba5ee4db87a3e03fe0@news.povray.org>
Using Blender and Python I have no problems to receive mesh from hair and to
paint it somehow, using UV
But, the number of hair on the head fluctuates from 100 to 150 thousand.
If 150 000 * 300 = 45 000 000 triangles
It is a lot of for a scene
Download 'curve2mesh.jpg' (105 KB)
Preview of image 'curve2mesh.jpg'
Date: 11 Feb 2014 12:40:01
Message: <web.52fa5fd6a5ee4db891114470@news.povray.org>
My 300 polygons each was from using a 5-sided profile and 50 segments along the
path, which could easily be a simpler, lighter mesh. But I agree, that is still
far too many polygons, which is why a native sphere_sweep UV solution would be
ideal.
Date: 12 Feb 2014 13:00:01
Message: <web.52fbb5f6a5ee4db891114470@news.povray.org>
Here is another test, this time using 15,000 sphere_sweeps, each sampling it's
unique color from a photograph of actual hair via eval_pigment(). Added Fresnel
reflections; still very slow to render.
Download 'hairtest_spheresweeps.png' (828 KB)
Preview of image 'hairtest_spheresweeps.png'
Date: 12 Feb 2014 13:03:46
Message: <52fbb782@news.povray.org>
Really awesome, really real. Well done.
Do not judge my words, judge my actions.
http://www.avast.com
Date: 13 Feb 2014 03:38:24
Message: <52fc8480@news.povray.org>
Your experiments are the best hair simulations I have seen so far. One
way or another, it would be worthwhile to see if this could be used for
Poser Hair exports through Poseray: If the /lines/ there could be
exported as splines, sphere_sweeps would be an easy matter. Hmm, would
need also an automatic sphere_sweep builder for so many hairs... ;-)
I believe that render speed is not really an issue if the final result
is astounding.
Date: 13 Feb 2014 06:21:14
Message: <52fcaaaa$1@news.povray.org>
The growth of the hairs usually is slow...
A beautiful image!
Paolo
Date: 13 Feb 2014 11:55:01
Message: <web.52fcf846a5ee4db87a3e03fe0@news.povray.org>
>  Hmm, would need also an automatic sphere_sweep builder for so many hairs... ;-)
> I believe that render speed is not really an issue if the final result is
>astounding.
> Thomas
Use Blender3D :)
Date: 14 Feb 2014 03:13:25
Message: <52fdd025$1@news.povray.org>
On 13-2-2014 17:52, LanuHum wrote:
> Use Blender3D :)
Yes, I know, but I was thinking of Poser and its hair, /and/ rendering
in POV-Ray.
