POV-Ray : Newsgroups : povray.binaries.images : Ringworld Server Time
15 Mar 2026 11:32:24 EDT (-0400)
  Ringworld (Message 42 to 51 of 61)
Subject: Re: Ringworld
Date: 15 Oct 2013 03:12:38
Message: <525ceae6$1@news.povray.org>
On 14-10-2013 18:28, posfan12 wrote:
> I wasn't satisfied with my other attempts at generating the landscape.
> There are supposed to be mountains along each edge of the ring, correct?
There are the so-called spill-mountains along the edge which serve to
recycle the sludge from the deep seas.
> Also, I liked the idea of having a navigable water corridor circling the
> entire structure.
Now that you are a member of the Known Space Ringworld Engineers Group
(KSREG), you are entirely free to model your world as you understand it.
Beware however from the very strict orthodox engineers around as they
are disguised Pak Protectors. ;-)
Date: 15 Oct 2013 03:16:27
Message: <525cebcb$1@news.povray.org>
On 14-10-2013 18:25, posfan12 wrote:
> I've tweaked the landscape a bit and added two belts of clouds. I'm not
> sure the two belts make sense on the ringworld. On Earth there is one
> cloud belt around the equator, and several jet streams I think.
Nice one. I don't think the two belts make any sense on the Ringworld as
the whole surface is equally illuminated by the sun. There are no
climate bands.
Date: 15 Oct 2013 03:19:10
Message: <525cec6e$1@news.povray.org>
On 15-10-2013 6:41, posfan12 wrote:
> Here's my latest render. Not realistic, but it looks OK. You can now see
> a little hint of blue in the ring. Not much green however.
Looking good. What are the shadows in the media beyond the Shadow
Squares? I guess media artefacts, in which case you need to use more
samples.
Date: 15 Oct 2013 03:25:00
Message: <web.525ceda9f2e6f38c5b7d07940@news.povray.org>
> climate bands.
Maybe not described in the book, but climate bands would be the sort of thing
the engineers might implement anyway, judging by other design choices!
Date: 15 Oct 2013 03:31:15
Message: <525cef43@news.povray.org>
>> climate bands.
Ah! That's an interesting idea indeed. That might certainly be correct.
Date: 15 Oct 2013 03:35:00
Message: <web.525cef98f2e6f38c5b7d07940@news.povray.org>
And also keep the air in.
You wouldn't notice the mountains from space unless you were very close to the
edge - they are described as only being 1000 miles high, which is practically
sub-pixel if you're viewing the whole ring width (~1e6 miles).
> > entire structure.
"Warning: KSREG mods may react out of proportion to your species' sense of
justice. Failing to abide by forum rules can result in a ban, and/or genocide."
Date: 15 Oct 2013 03:41:16
Message: <525cf19c$1@news.povray.org>
>>> climate bands.
>> of thing
> Thomas
There might be friction along the wall edges. Very minor friction maybe.
Plus, cloud density might be greater or less (I don't know) over water
than over land.
http://isometricland.net
Date: 15 Oct 2013 03:42:08
Message: <525cf1d0$1@news.povray.org>
> samples.
> Thomas
I don't know what they are. Were in the code do I increase samples?
Date: 15 Oct 2013 03:45:19
Message: <525cf28f$1@news.povray.org>
Indeed. The spill-mountains are a later addition. Originally, the Rim
was a featureless wall (it still is in my latest render of 2010, visible
as a darker shadow to the right). In later stories it was sculpted into
a mountain profile and the spill-mountains were added.
>>> entire structure.
LOL shudder...
Date: 15 Oct 2013 03:52:06
Message: <525cf426@news.povray.org>
>> samples.
>> Thomas
In the media for the Corona. In your code, you are using the default
sample value. Add the samples to the code:
media {
   samples 100
   scattering {1, light_color/20}
etc
Play with the value increasing/decreasing it until the artefacts
disappear. Render time may become a bit longer but not much.
