POV-Ray : Newsgroups : povray.binaries.images : Improving etched pyramids Server Time
5 Apr 2026 08:36:20 EDT (-0400)
  Improving etched pyramids (Message 11 to 20 of 24)
<<< Previous 10 Messages Goto Latest 10 Messages Next 4 Messages >>>
Subject: Re: Improving etched pyramids
Date: 13 Feb 2013 03:53:51
Message: <511b549f$1@news.povray.org>
> So my final idea was kind of a cheat: to color the planar surface
> with a gradient y pigment, receding into the surface--somewhat dark
> at the very surface, then immediately lighter, then falling to
> darkness again to the bottom of the pits. And using two area lights
> to either side.
   That looks almost perfect to me, at least for that particular SEM
picture posted by kmcpeak. And "cheating" seems more or less obligatory
here, as SEM photography doesn't involves lighting at all...
Jaime
Date: 13 Feb 2013 15:10:01
Message: <web.511bf2787ee00279f206134e0@news.povray.org>
"Kenneth" <kdw### [at] gmailcom> wrote:
> There's something intrinsic to electron microscope and SEM images that might
> make recreating the look with a 'standard' lighting setup difficult.
Things I have observed about SEM images (two of which you just covered):
  - surfaces typically become brighter near the edges (AOI-like effects)
  - nothing has a definite shadow, probably because the electron source isn't a
pinpoint
  - objects seem translucent, or like glowing firewood
It's that translucent appearance that is the missing factor in most faux SEM
images, I think. Careful use of a proximity pattern might just work.
Sam
Date: 13 Feb 2013 16:00:01
Message: <web.511bfdd07ee00279c2d977c20@news.povray.org>
Thanks. Now that I look at my image again, it doesn't seem so ambiguous after
all. But the longer I stare at it, the 'bumps' want to come back. :-(  With a
planar surface (and not much perspective, or none at all), there seem to be no
real 'depth cues'--other than the faux shadowing.
Date: 13 Feb 2013 17:30:33
Message: <511c1409$1@news.povray.org>
> I cobbled together a scene similar to the one posted, and it's really hard to
> get that SEM 'look.' Even more irritating is that the indents almost always look
> like bumps. I tried lights, radiosity with no lights, a radiosity 'ring' around
> the object, no_shadow, etc. This is the closest I've gotten--and it still looks
> somewhat ambiguous.
> Most such images appear to have 'lighting' that *surrounds* the object--except
> in the front. And no shadows, in the usual meaning. They almost look like
> photographic negatives. (I found one image--a really cool one of an ant--and
> 'inverted' it in Photoshop; the result looks like it's lit with a SINGLE light
> source, shining directly from the camera position...and with a rapid fall-off of
> light on all the side/slanting surfaces.) How to get the reverse of that with
> 'positive' lighting may not be so easy. For example, it's hard to get regular
> light sources to 'fall off' in brightness in just such a way as those SEM
> indents show. If the object was like an ant--in other words, a detailed 3D model
> in space--then maybe a radiosity set-up might work, using a white HEMISPHERE
> behind the model as the only 'light source.' But a simple planar surface--like
> the OP's model--can't take advantage of that.
> So my final idea was kind of a cheat: to color the planar surface with a
> gradient y pigment, receding into the surface--somewhat dark at the very
> surface, then immediately lighter, then falling to darkness again to the bottom
> of the pits. And using two area lights to either side.
One way could be to use a negative light, maybe with a fade_power larger
than 2, and a bright surrounding providing radiosity illumination.
You could also use a ring of actual lights.
Date: 13 Feb 2013 19:15:01
Message: <web.511c2bfa7ee0027912e8e29e0@news.povray.org>
> somewhat ambiguous.
Kenneth,
Wow, that looks great! Would you be willing to share your color map for the
gradient and the light_source parameters you used. Thanks so much for your help!
Kevin
Date: 14 Feb 2013 14:20:01
Message: <web.511d37937ee00279c2d977c20@news.povray.org>
Sure; glad to help. Here are the lights and the texture. This assumes that your
own square SEM model is lying flat horizontally, with the top surface exactly at
y=0 (and centered on the origin; but that's not critical.) Your own model might
not be the same size as mine (which is 1X1), so adjust the light distances and
the gradient y pigment scale if needed. BTW, the overall brightness will depend
on what assumed_gamma you use in your scene. (I used 2.2 for this test.)
// The lights...
light_source {
  <0, 0, 0>
  color rgb .7
  area_light
  <12, 0, 0> <0, 0, 12> // lights spread out across this distance (x * z)
  4, 4                // total number of lights in grid (4x*4z = 16 lights)
  adaptive 0          // 0,1,2,3...
  jitter              // adds random softening of light
  circular            // make the shape of the light circular
  orient              // orient light
  translate <-10, 7, 10>
light_source {
  <0, 0, 0>
  color rgb .9
  area_light
  translate <10, 20, 10>
// The texture...
texture{
   pigment{
      gradient y
      pigment_map{
           [.01 // For the top surface only
           average
           pigment_map{
              [1 rgb .16]
              [1.5 bumps scale .003]
           [.01 rgb .9] // immediately under the surface
           [1 rgb .2]// for the indents
           scale .039*<1,-1,1> // Adjust the multiplier so
// the bottom of your SEM indents don't start showing the repeating
// gradient y pattern. The -1 for y just 'flips' the gradient y, as
// I specified the colors going 'up', not down.
   finish{ambient 0 diffuse 1} // You might want to add a
// little bit of ambient.
Date: 15 Feb 2013 14:55:03
Message: <web.511e92657ee0027913f4465a0@news.povray.org>
> // The lights...
> light_source {
>   <0, 0, 0>
>   color rgb .7
>   area_light
> light_source {
>   <0, 0, 0>
>   color rgb .9
>   area_light
> // The texture...
> texture{
>    pigment{
>       gradient y
>       pigment_map{
>            average
>            pigment_map{
>               [1 rgb .16]
Kenneth,
Thanks again! I implemented your code with my mesh but I am having trouble
getting the pigment_map to work. I used a plane y and a difference statement to
determine that the top surface is at y=-1.3077 and the bottom of the pyramids is
around y=-2.9 (not all of them are the same depth). But the following
pigment_map does not look like yours:
#declare Tex_Silicon =
texture{
   pigment{
      gradient y
      pigment_map{
           [1.4 // For the top surface only
           average
           pigment_map{
              [1 rgb 0.16]
           [1.4 rgb 0.9] // immediately under the surface
           [2.9 rgb 0.2]// for the indents
           scale 1*<1,-1,1> // Adjust the multiplier so
   finish{ambient 0 diffuse 1} // You might want to add a little bit of ambient.
I zipped up my POV file so you (and others if they like) can work with the real
thing.
Your help (as are all the other posts on this thread) most appreciated!
Kevin McPeak
Download 'kmcpeak_pyramids_pov.zip' (1359 KB)
Date: 16 Feb 2013 13:40:01
Message: <web.511fd1767ee0027913f4465a0@news.povray.org>
> > // The lights...
> > light_source {
> >   <0, 0, 0>
> >   color rgb .7
> >   area_light
> > light_source {
> >   <0, 0, 0>
> >   color rgb .9
> >   area_light
> > // The texture...
> > texture{
> >    pigment{
> >       gradient y
> >       pigment_map{
> >            average
> >            pigment_map{
> >               [1 rgb .16]
> Kenneth,
> texture{
>    pigment{
>       gradient y
>       pigment_map{
>            average
>            pigment_map{
>               [1 rgb 0.16]
> thing.
> Regards,
> Kevin McPeak
I used a transform to bring the top of the silicon surface to y = 0. This helped
me figure out the pigment_map. Attached is my latest effort. I think I need to
move the lights a bit but overall this is way way better than where I started.
Thanks so much to all of you for your help!
Latest code:
texture{
   pigment{
      gradient y
      pigment_map{
           [0.01 // For the top surface only
           average
           pigment_map{
              [1 rgb 0.16]
           [0.01 rgb 0.6] // immediately under the surface
           [0.8 rgb 0.2]// for the indents
           scale 1.65*<1,-1,1> // Adjust the multiplier so
   finish{ambient 0.2 diffuse 1} // You might want to add a little bit of
ambient.
Download 'fig1_sem-pov_comparison.png' (304 KB)
Preview of image 'fig1_sem-pov_comparison.png'
Date: 16 Feb 2013 16:10:01
Message: <web.511ff54a7ee00279c2d977c20@news.povray.org>
> helped me figure out the pigment_map. Attached is my latest effort. I think
> I need to move the lights a bit but overall this is way way better than
> where I started.
Hey, that's looking *much* better.
I think (as you say) that the light positions are still not quite right. It
looks like they are 'diagonal' to the object, and still too close to it. In my
own tests, those light positions turned out to be rather critical, to change the
'bumps' into 'indents.' Try placing them exactly left-and-right to the object,
really far away, and maybe lower in y(?). (And no fade-power, of course.) With
some more experimentation, you'll probably find the 'sweet spot' for those
lights.
Date: 16 Feb 2013 16:20:01
Message: <web.511ff7567ee0027913f4465a0@news.povray.org>
> > where I started.
> lights.
After some movement of the lights and adding bumps to the etch pits attached is
my latest best effort. Might stop here... Code below:
texture{
   pigment{
      gradient y
      pigment_map{
           average
           pigment_map{
              [1 rgb 0.3]
              [1.25 bumps scale .0005]
           [0.01       // immediately under the surface
           average
           pigment_map{
              [1 rgb 0.7]
              [0.5 bumps scale .0005]
           [0.8     // for the indents
           average
           pigment_map{
              [1 rgb 0.5]
   finish{ambient 0.1 diffuse 1} // You might want to add a little bit of
ambient.
#declare Material_0=material{
texture {Tex_Silicon }
   location <0.00000, 55, 0.000000> // <up/down, height, right/left>
   look_at <0.000000, 0.000000, 0.000000>
   //up <0,0,1>
   rotate  <0, 90, 0>
// The lights...
// Top left
light_source {
  <0, 0, 0>
  color rgb .7
  area_light
  <20, 0, 0> <0, 40, 0> // lights spread out across this distance (x * z)
  8, 8                // total number of lights in grid (4x*4z = 16 lights)
  translate <50, 20, 80> // <+up/-down, +height, -right/+left>
// Right middle
light_source {
  <0, 0, 0>
  color rgb .9
  area_light
  <0, 0, 0> <10, 30, 0> // lights spread out across this distance (x * z)
  translate <10, 35, -60> // <+up/-down, +height, -right/+left>
// Top
light_source {
  <0, 0, 0>
  color rgb .2
  area_light
  <0, 0, 0> <30, 0, 30> // lights spread out across this distance (x * z)
  translate <0, 50, 0> // <+up/-down, +height, -right/+left>
Download 'fig1_sem-pov_comparison.png' (965 KB)
