POV-Ray : Newsgroups : povray.binaries.images : Multi-pass rendering and compositing in POV-Ray Server Time
13 Mar 2026 16:28:31 EDT (-0400)
  Multi-pass rendering and compositing in POV-Ray (Message 9 to 18 of 28)
<<< Previous 8 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Multi-pass rendering and compositing in POV-Ray
Date: 9 Mar 2011 04:02:26
Message: <4d774222$1@news.povray.org>
Well, Mister POVxar, you did it again it seems! Very smartly done.
I used your ao techniques several times and it added much to my scenes.
Date: 9 Mar 2011 08:25:01
Message: <web.4d777f1d6b0cef9b94d713cc0@news.povray.org>
"SafePit" <ste### [at] reids4funcom> wrote:
> > > So, here's an example shot of the "blob with negative strength" from the
> > > pvengine64 "Insert" menu, using five separate render passes.
> > And here's the final SDL composite :)
> > www.McGregorFineArt.com
> Wow, just wow!  Sounds promising.  Would it work with media and focal blur?
Yes, that's the beauty of it, it works with anything available in POV-Ray. And
you have the choice of using radiosity and/or standard lighting in a scene;
whichever makes objects/effects look best and render fastest.
And actually these example shots all make use of subtle focal blur using:
   location Cam_Loc
   look_at  Cam_At
   angle 50
   #if (Use_Focal_Blur)
      aperture 2
      blur_samples 7*Focal_Blur_Factor
      focal_point <10, 0, -2>
      confidence 0.9
      variance 1/200
Cheers,
Rob
Date: 9 Mar 2011 08:30:01
Message: <web.4d777fd66b0cef9b94d713cc0@news.povray.org>
Stephen <mcavoys_at@aoldotcom> wrote:
> On 09/03/2011 4:46 AM, Robert McGregor wrote:
> > And here's the Buddha Balls final comp
> I really like this one but I wish you had called it Buddha Spheres or
> something. ;-)
> Regards
>      Stephen
LOL, Stephen!!
"Buddha Balls" just rolls off the tongue better (sorry, couldn't help myself).
Message: <web.4d7780576b0cef9b94d713cc0@news.povray.org>
> Thomas
Thanks Thomas, I didn't realize that :)
Date: 9 Mar 2011 08:43:54
Message: <4d77841a$1@news.povray.org>
OOC, what exactly is the ambient occlusion pass used for? After all, the
global illumination effect should already be accounted for by the
radiosity pass.
AFAIK, in shader-based render engines, AO is used to get self-shadowing
right, and/or to /fake/ global illumination.
So I guess what you're doing there is actually just deepening the
shadows for artistic effect, and might better be served by tone mapping.
Date: 9 Mar 2011 10:35:01
Message: <web.4d779d2c6b0cef9b926cc9f10@news.povray.org>
> radiosity pass.
AFAIK, Ambient Occlusion is used to gain some render time and flexibility rather
than realism. In Mental Ray for instance, Photon mapping and Final Gather are
helpful to generate faster some color bleed, and global indirect light. Yes in
theory, you get more realistic lighting if you let photon mapping do all the
job, but in practice this makes the render time too long, so it is advised, in
most Mental Ray training material, to use Both (photon mapping + Final Gather)
and Ambient Occlusion together in a synergy, using the final gathering radius to
set up some degree of smoothing that depends on your AO distance: This way,
Photons+FG generate overall lighting, whereas self shadowing which happens at
smaller scales is left out of it thanks to Gather blurring and sparser sampling
but is simulated with Ambient Occlusion, rendered much faster than photons or
gathering would require to reach. So to some it up and anyone correct me if I'm
wrong,
Final Gather (wich in mental ray can also be used without photons) takes on the
widest scale, and Ambient Occlusion takes care of much smaller shadows.
In the process, if some photons are shot, some details can be added locally with
photons targeting from lights, importance, portals, various techniques, to get
also more small scale effects like luminous caustics (whereas AO only emulates
ambient shadows.
Being a pragmatic observation rather than lab approach, I would think of AO as
the opposite approach to unbiased techniques, where instead of calculating
indirect light for unspecified times towards some configuration that is the most
specific to your scene, you start by what is common to almost every scene, and
decide that some part of the light bounces so much that it will end up
contributing to all of a set to some degree and since it can happen all over the
place it's initial directions doesn't actually matter that much, so AO focuses
on shading places where light definitely wouldn't reach, which is contact
between surfaces and very acute angles. The important thing being that you can
tweak overall contribution of that ambient light by intensity of shadows and by
distance at which it extends far from the object casting it. Once it's decided
that this contribution is not zero you switch on AO and tune the frequency and
intensity of your other indirect lighting  features accordingly. This leaves
much more sampling budget for local effects.
It is often said that AO is not phisically correct, but I'd say that for a
uniformly and very thickly overcast sky with no lights around, then only AO
would be correct. Or the light cast by surrounding sky of some clear night.
So when you consider that you actually don't use AO by itself but only to take
care of some part of the light, you realize that this lighting component is to
various degrees present in almost every scene.
There are also other uses of AO like to bake it and use as a basis for dirt
maps, mask to mix different materials and many textures to process further.
Sorry if nothing of the above answers your question or if any of it is wrong, it
mostly comes from memories of CGSociety discussions, and I'm not a hardcore
programmer/scientist.
@Robert McGregor, Even If AO does not get implemented further into POV, I'm much
interested into any tutorial you could make and would love to include pov passes
to our Blender 2.5 to Povray exporter because Blender compositing pipeline is
quite capable and that's an area where both software would best synergize.
Thanks for your efforts.
Date: 9 Mar 2011 10:55:06
Message: <4d77a2da@news.povray.org>
"Robert McGregor" <rob### [at] mcgregorfineartcom> schreef in bericht
news:web.4d7780576b0cef9b94d713cc0@news.povray.org...
>> Thomas
Well... to tell the truth: the latest ones did not...  :-/
Date: 9 Mar 2011 11:10:01
Message: <web.4d77a6206b0cef9b8eebbb560@news.povray.org>
awesome.
But really, this is why pov-ray never quite gets much of a foothold:  only
ingenious guys like you, Sam Benge, Jaime Vives Piqueres and a host of others to
imagine such tricks.  And even worse: some tricks that ought to be in the
software are seemingly always reinvented by newcomers, like stacked sky,
micronormals and this one:  it is a well known fact that the multipass approach
is the way to go and that radiosity does not play fine with reflections,
refractions, media and now SSS.
So, how about a multipass switch for povray, devs?  I mean, sure there's the
quality switches going from 1 (plain constant ambient light) to 9 (full with
radiosity), but the numbers going higher only add more effects, don't isolate
them from one another.  I know it's a postprocess to combine the results and it
is outside the scope of a raytracer, but then again, an IDE to write scenes is
also outside the scope of a raytracer.  At the very least, providing scripts for
such...
Date: 9 Mar 2011 12:20:01
Message: <web.4d77b5f56b0cef9b86ff1d480@news.povray.org>
> rather than realism.
Exactly, it's fast and really brings out hidden geometric details that radiosity
doesn't typically reveal, and our brains are fooled into thinking it looks more
realistic even when it's not physically accurate.
Yes, and my AO solution is really just that: white materials under a very
thickly overcast sky with no lights around.
I usually only multiply in 15-50% of the AO pass, depending on the shot.
That's something else I'm working on, using the AO pass as an image_pattern mask
to control grime and such in crevices, for an additional dirt/grime pass.
Thanks, that sounds great; I'd be very interested to work with you on that!
Cheers,
Rob
Date: 9 Mar 2011 14:34:21
Message: <4d77d63d$1@news.povray.org>
Tell me about it ... I thought my doily trick was cleaver, but hey
here's the context for you ... I have a tough time drawing a straight
line /even/ when I use a straight edge ;-)
I look at it this way ... If you stay on the porch and never run wid da
big dawgs every now and then, you aren't going to ever learn anything.
What's cool about these guys is that they are willing to share!
