POV-Ray : Newsgroups : povray.binaries.images : the Johnson solids Server Time
16 Mar 2026 14:37:43 EDT (-0400)
  the Johnson solids (Message 9 to 18 of 28)
<<< Previous 8 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: the Johnson solids
Date: 13 Jul 2009 10:22:42
Message: <4a5b4332$1@news.povray.org>
I liked the other image more... It had that "wow!" factor to it.
Date: 14 Jul 2009 04:23:38
Message: <4a5c408a$1@news.povray.org>
Well, this picture just isn't as sparkly since the textures are "just"
jadestone or marble... I guess if you would change the texture to
transparent glass with high refractive index they would look more
spectacular.
But let us be glad that not every stone is a sparkling diamond...  it would
become boring after a while.
So: well done! I am looking forward for more :-)
"Warp" <war### [at] tagpovrayorg> schrieb im Newsbeitrag
news:4a5b4332$1@news.povray.org...
Date: 14 Jul 2009 07:00:00
Message: <web.4a5c64fc76bf31cf6dd25f0b0@news.povray.org>
True, and I'm glad I took the opportunity to try a translucent rock texture. But
Warp's right, this image isn't nearly as pretty as the first one. I think I'll
try a glass version to see how it looks...
Thank you, so am I! Although I'm undecided as to how to present the next lot.
Bill
Date: 14 Jul 2009 09:20:00
Message: <web.4a5c851576bf31cf5fee4dc70@news.povray.org>
> So, the next batch of polyhedra. This little lot are the Johnson solids,
> basically all the convex polyhedra composed only of regular polygons, that
> aren't either Platonic or Archimedean solids.
.... nor prisms or antiprisms. Otherwise we'd have an infinite lot of them :P
> There's 92 of them, so I thought
> the best way to show them off equally was another overhead view, in a spiral
> pattern this time. Rather than use the glass again, I thought I'd go for a
> polished stone look... mostly successful, I think.
Very beautifully arranged & illuminated (again!).
> (took 140 hours to render at 2000x2000 - eek!)
Sounds to me like a case of "ur doin' it wrong": I see nothing in that shot that
would justify such a long render time. Maybe too high-res area lighting? (Using
the "jitter" keyword is much superior to increasing maximum resolution.) Or
maybe too high-quality radiosity settings?
(Then again it's just a gut feeling, and maybe I'm missing something.)
Date: 14 Jul 2009 09:35:01
Message: <web.4a5c889c76bf31cf6dd25f0b0@news.povray.org>
Yes, it's entirely possible. However, refining the render time would probably
take me several evenings' tinkering with the source, whereas if I just did
something else during that time it's half finished anyway. :) The isosurface
floor could probably use a smaller max_gradient, I could certainly get away
with a lower-res area_light, radiosity quality may well be too high, and I seem
to recall that the default media sampling (which this uses) is unwise. Including
the media seemed to produce the biggest slow-down... and, of course, merely
activating the aa on a scene like this is a huge drag.
(2000x2000 is also 4x the pixels posted here, but I guess you twigged that!)
Date: 14 Jul 2009 11:42:01
Message: <4a5ca749@news.povray.org>
Did you use adaptive for your area_light? It can greatly improve the
rendering speed. With adaptive 1, a 65x65 area_light is barely slower
than a 4x4 or 5x5 one without.
You may have inefecient bounding. If your construction make it that
there are no bounding of your objects (intersection of planes), then
each ray hace to be tested against every planes of every object. adding
a bounded_by to your objects may greatly speed up the rendering.
Date: 14 Jul 2009 11:45:00
Message: <web.4a5ca75076bf31cf5fee4dc70@news.povray.org>
Um... yeah, if aside from area lights and radiosity you also did use isosurfaces
and media, then I'll keep my cake-hole shut :X
BTW, I don't agree with the other posters that the shot would look much better
with transparent material; you win the caustics, but I guess you lose a lot on
the shadow effect that this image shows off very impressively.
Date: 14 Jul 2009 11:55:01
Message: <web.4a5ca9ea76bf31cf6dd25f0b0@news.povray.org>
I never use area lights without it!
Good thought, but my objects are meshes, so I assume they are bounded optimally.
I blame the media ;-)
Date: 14 Jul 2009 12:00:00
Message: <web.4a5caa7476bf31cf6dd25f0b0@news.povray.org>
The isosurface isn't obvious (although probably more needed than in the other
image), but I would expect you to spot the media in the subsurface scattering
on those gems... :-D
I thankyou. I may still try the glass version too though!
Date: 14 Jul 2009 13:25:00
Message: <web.4a5cbe3b76bf31cf5fee4dc70@news.povray.org>
In fact, "more than optimally" if there is such a thing :) (In addition to
having a fitting bounding box for the whole object, meshes use an internal
bounding hierarchy for the individual triangles.)
