See povray.bugreports
Download 'ivy.png' (54 KB)
Preview of image 'ivy.png'
Subject: Re: shadows don't honor image_map alpha channel
Date: 6 May 2009 04:03:51
Message: <4a014467@news.povray.org>
That is strange... See my image: also a png image map.
Download 'imagemaptest3.jpg' (103 KB)
Preview of image 'imagemaptest3.jpg'
The shadows seem to work with both methods:
PNG with internal alpha channel or by using pigment_pattern -
the way I do prefer, because you can add specular highlights:
#local Leaf_1_opaque = texture {
uv_mapping
pigment {P_Leaf}
normal {N_Leaf}
finish {
ambient 0 diffuse 0.9
specular 0.1 roughness 0.1
#local Leaf_1_trans = texture {
uv_mapping
pigment {P_Leaf transmit 1}
normal {N_Leaf}
finish {
specular 0.0 roughness 0.1
#declare T_Leaf_1 = texture {
uv_mapping
pigment_pattern {A_Leaf1}
texture_map {
[0 TA03_Leaf_1_trans]
[1 TA03_Leaf_1_opaque]
But as soon as you add media or fog the transparent parts become
partial visible in 3.7 beta, see the attached shrub. This happens
also with both methods.
Download 'testleaf.jpg' (27 KB)
Download 'testshrub.jpg' (52 KB)
Preview of image 'testleaf.jpg'
Preview of image 'testshrub.jpg'
> Thomas
Maybe we're using different ways to get the transparency into the shot, or
different objects or whatever? This is the code I used (boiled down to its
essence):
#declare Entwined_Ivy_leaf_adult_=mesh2{
vertex_vectors{
4,
<-1,1,-1>,
<-1,1,1>,
<1,1,1>,
<1,1,-1>,
normal_vectors{
4,
<0,1,0>,
<0,1,0>,
<0,1,0>,
<0,1,0>,
uv_vectors{
4,
<0,0>,
<0,1>,
<1,1>,
<1,0>,
face_indices{
2,
<0,1,2>,
<2,3,0>,
uv_indices{
2,
<0,1,2>,
<2,3,0>,
normal_indices{
2,
<0,1,2>,
<2,3,0>,
inside_vector <0,0,1> }
#declare p_map22 = pigment { image_map { png "efeu1.png" interpolate 2 transmit
all 0 filter all 0 } }
#declare Ivy_leaf_adult_=
material{
texture {pigment{ uv_mapping p_map22}
finish{specular 0 roughness 0.09632328 ambient rgb <0.00,0.00,0.00>
diffuse 0.6 reflection{0 } conserve_energy}
object{Entwined_Ivy_leaf_adult_ material{Ivy_leaf_adult_} hollow}
plane{y,0
pigment { color rgb 1 }
finish { diffuse 0.7 ambient 0 }
As some keen-eyed person may guess, this is output from Thomas Luft's Ivy
Generator, converted to POV-Ray format using PoseRay (hand-edited to reduce the
mesh to a single, perfectly flat leaf).
When I use a texture_map instead - as in the following code - I get good results
as well, so it's a feasible workaround, but I'd expect PNG alpha to do the same
job on its own:
material{
uv_mapping
image_pattern { png "efeu1.png" use_alpha }
texture_map {
[0.0 pigment{ uv_mapping p_map22}
diffuse 0.6 reflection{0 } conserve_energy} ]
[1.0 pigment { transmit 1 } ]
Not so in my experience with the Ivy Generator output run through PoseRay.
It's also not a 3.7 problem, but is seen in 3.6 as well (more precisely I tested
it with MegaPOV 1.2.1).
I guess this is due to the non-solid nature of the mesh employed: You have
surfaces where light "enters into" the mesh object, but fails to leave it
later; and while presumed "inside" the mesh object, it will ignore the outer
object's media settings.
Did you check this with 3.6?
I remember something about the "inside_vector" having some default; I guess this
might prevent POV from prudently assuming that a mesh without an "inside_vector"
represents a surface but no volume, and should therefore not affect meda.
This is really strange because my attached leave image uses the PNG
alpha channel in the same way you do - and I do get the shadows.
#local T_Leaf = texture {
pigment {image_map {png "AutumnLeaf1" interpolate 2} }
finish {ambient 0 diffuse 1}
#local LeafBase = mesh {
triangle { <0,0,0>, <1,0,0>, <1,1,0> uv_vectors <0,0>, <1,0>, <1,1> }
triangle { <0,0,0>, <1,1,0>, <0,1,0> uv_vectors <0,0>, <1,1>, <0,1> }
#declare Leaf = object {
LeafBase
texture {T_Leaf}
translate <-0.5,-0.5,0>
rotate x*90
scale <1, 1, 1.4> * 10.0
hollow
double_illuminate
I do not think this is related to the Ivy Generator (how should it?).
Could you post the PNG file you did use?
It works perfectly well with 3.6 and MegaPov.
But 3.7 renders those huge XFrog tree meshes about 3 times faster (per
core!!!) than 3.6 and works well until no media is used.
Which is kinda sad and currently a show stopper to me.
-Ive
It seems that the UV mapping is the key. I modified your code to use
"uv_mapping", resulting in the same black square for a shadow:
pigment { uv_mapping image_map {png "AutumnLeaf1" interpolate 2} }
I guess we can rule out the picture: With your original code, I don't see the
error with my PNG either. But I do see it once I add the "uv_mapping" keyword,
which I cannot do without.
(BTW, I use the original "efeu1.png" included with Thomas Luft's free Ivy
Generator.)
Yeah, I can imagine.
Ahh, I remember now there was something about not putting uv_mapping
into the pigment statement (for unknown reasons, maybe a bug), that's
why I do always use it this way:
uv_mapping
Sorry it did by mistake remove the uv_mapping keyword when I did remove
the normal statement to simplify things.
-Ive
Just to be clear, uv-mapped images maps with alpha channel do work
only as expected when the uv_mapping statement is put into the
texture block but not into the pigment statement.
-Ive
