POV-Ray : Newsgroups : povray.binaries.images : Looking to the Sun Server Time
21 Mar 2026 04:17:05 EDT (-0400)
  Looking to the Sun (Message 11 to 19 of 19)
Subject: Re: Looking to the Sun
Date: 20 Mar 2009 17:15:01
Message: <web.49c4071aaa0d6de0617fb3dd0@news.povray.org>
"sooperFoX" <bon### [at] gmailcom> wrote:
> But is there a way to read/parse the probemap.lm file directly into POV or do I
> have to convert them into lights by hand?
Very rough version:
#declare dome_size = 10000;
#macro LoadLightMapGenFile( filename, manual_rotation,lightscale )
 #fopen file filename read
 #local number_of_samples = 0;
 #read (file, number_of_samples)
 #local phi = 0.0;
 #local theta = 0.0;
 #local solid_angle = 0.0;
 #local r = 0.0;
 #local g = 0.0;
 #local b = 0.0;
 #local i = 0;
 #while( i < number_of_samples )
  #read (file, phi, theta, solid_angle, r, g, b )
        light_source {
            <0,0,10000>
            rgb< r, g, b > * 2 * lightscale
            area_light < sqrt(solid_angle * dome_size) * rtod, 0, 0 > < 0,
sqrt(solid_angle * dome_size) * rtod, 0 >, 2, 2
            circular orient jitter
            rotate x * (-90 + (phi * rtod))
            rotate y * theta * rtod
            rotate y* manual_rotation
  #local i = i + 1;
 #fclose file
And the modified lightgenmap file (using a quick search and replace):
16,
1.67289808803656, 0.68722339297277, 1.6527013386, 0.0552636348, 0.0607447550,
0.0508851111,
1.54723438189297, 1.66111711558560, 0.7794830194, 0.0711220279, 0.0557181686,
0.0360830873,
1.61792021659874, 2.17162592179394, 0.5545587558, 0.0781337619, 0.0515972860,
0.0299037341,
1.41764368493239, 2.17947990342792, 0.0867880323, 0.0761284605, 0.0559703335,
0.0377449766,
0.91891585117501, 0.61261056745001, 0.8644722987, 0.0400214680, 0.0603732206,
0.0936556607,
0.94247779607694, 1.50403748290611, 0.4497592365, 0.0661152080, 0.0552642494,
0.0537655167,
1.20558618081508, 2.10486707790516, 0.1601643115, 0.0730255991, 0.0542870797,
0.0431215167,
0.75005524604456, 2.10879406872215, 0.3450847009, 0.0759069920, 0.0534908585,
0.0404571854,
1.69253304212150, 3.01592894744620, 1.5993434847, 0.0655947104, 0.0591190495,
0.0349534899,
1.29983396042278, 2.95702408519139, 0.3214766435, 0.0631420985, 0.0567937195,
0.0538687669,
0.81681408993335, 2.68998870963626, 0.2905465791, 0.0762574896, 0.0534339696,
0.0398534238,
0.81288709911636, 3.29867228626928, 0.5453702181, 0.0694099888, 0.0545476936,
0.0498176217,
1.64540915231765, 4.60243323750905, 1.7470526871, 0.0568613783, 0.0604094379,
0.0494299829,
1.61792021659874, 5.72947960198439, 1.3599216939, 0.0526376031, 0.0615689270,
0.0575421639,
0.91891585117501, 4.45713457728052, 0.9250347179, 0.0431348681, 0.0603335723,
0.0894638970,
0.95033177771091, 5.67057473972958, 0.8845644490, 0.0372447670, 0.0613860562,
0.1000061333,
Cheers,
Edouard.
Date: 20 Mar 2009 17:30:00
Message: <web.49c40a6eaa0d6de0c4ed4e470@news.povray.org>
"Edouard" <pov### [at] edouardinfo> wrote:
> Same old Jotero Ajax bust as always!
>   - 200mm lens at f/4 shot from about 1.7 meters away.
>   - HDR lightprobe I took a couple of evenings ago in nearby field.
>   - LightMapGen 16 sample median-cut lightdome, plus one hand-placed Sun light
> (no radiosity).
>   - Simple texture_map with three entries (shiny, dull and corroded).
>   - DF3 based proximity pattern (along with slope and bozo) to choose the
> texture via a pigment_map.
>   - focal blur only used 7 samples. I could have bumped that to 37, but I wanted
> to see the results today, not tomorrow :-)
> I guess the interesting technique (to me at least) was writing a seperate pov
> script to analysed the mesh and create the image slices that got combined into
> the DF3 file. This one used a 60x90x60 DF3 file created with 25 samples per
> voxel. You pay for a one-off creation time, but then get to use the DF3 file
> from then on (and it loads more or less instantly). It possibly might render
> quicker than an averaged fastprox pattern, but I'm not really sure.
> The background is just a bit of the sky from the lightprobe - with a bit of
> focal blur it came out looking nice even though the lightprobe resolution is
> pretty low.
> I'm pretty happy with how it turned out, but any feedback anyone has would be of
> course welcomed.
> Cheers,
> Edouard.
A pleasure for my eyes.
As usual!
Carlo
Date: 20 Mar 2009 17:40:01
Message: <web.49c40cd0aa0d6de0617fb3dd0@news.povray.org>
> Geez!
> What's that DF3 proximity pattern thing? I guess I'd like to learn about it:
> What exactly does it do? And how do you do it?
The object is just being coloured by a DF3 file, but the DF3 file was itself
created from the object by sample points in space around each voxel. The
density of the voxel is determined by how many samples are inside the object vs
how many samples are outside.
> (BTW, the corroded texture seems a bit too strong to me; or is that green color
> reflections?)
I've done some google image searches, and bronze patina's can be as strong as
this one, but often a bit paler in colour. There's an enormous variation from
what I can tell. It's being lit by a setting sun on the horizon, which might
contribute to the patina's intensity a little.
I'll try tweaking it when I do some more bronzes.
Cheers,
Edouard,
Date: 20 Mar 2009 17:50:00
Message: <web.49c40eb2aa0d6de0617fb3dd0@news.povray.org>
Opps - add this global
#declare rtod = (180 / pi);
Cheers,
Edouard.
Date: 20 Mar 2009 20:35:00
Message: <web.49c43569aa0d6de0db388e5b0@news.povray.org>
So basically it's a kind of antialiased voxel representation of the object?
Then I think it's not the ideal way to do it.
If I understand it correctly, the desired effect is that the DF3 helps you
texture an object differently in areas that "stick out" as opposed to
"recessing" regions. For this purpose, the DF3 should be "blurred" in a way.
If I get you right, your approach leveas all blurring to the "voxel
oversampling" and POV's DF3 interpolation. However, this is strongly dependent
on the DF3 resolution.
To improve the approach, the sample points could be jittered even beyond the
boundaries of their "nominal voxel" using a gaussian distribution, which can be
scaled according to the desired "blurriness" of the DF3 for more control, so one
can improve quality of the DF3 (by increasing resolution) without "sharpening"
it.
> > reflections?)
Taken by itself, it doesn't seem wrong to me; it's the contrast to the
uncorroded bronze that makes it look strange in my eyes. I can't imagine you'll
ever have that strong corrosion in some parts while others are perfectly shiny.
Date: 21 Mar 2009 00:15:00
Message: <web.49c4696aaa0d6de0617fb3dd0@news.povray.org>
> it.
I didn't explain it very well - sorry. Each voxel's value is determined by 25
samples taken (in this specific case) randomly within a sphere of 2.5 voxels in
radius. The voxel size and the sample radius are independent of each other.
Cheers,
Edouard.
Date: 21 Mar 2009 11:20:00
Message: <web.49c5057eaa0d6de041685c200@news.povray.org>
I see - so you already did the improvement I suggested ;)
(A gaussian distribution would probably give a better quality, but a uniform
spherical distribution should do a good job as well. Oh, it *does*, as can be
seen from your shot ;))
Date: 22 Mar 2009 10:05:00
Message: <web.49c64511aa0d6de03e3c08aa0@news.povray.org>
I did pick up on that, thanks - but it seems the news posting page "swallowed"
my response.
Is there any benefit to declaring that, over using the built-in degrees(rad)
float function?
Also I noticed that you included rotate and scale parameters, as well as a light
intensity multiplier - all things that I was considering when I initially saw
the words "light dome" - so thanks!
Date: 23 Mar 2009 07:45:00
Message: <web.49c77554aa0d6de0eba2273d0@news.povray.org>
> float function?
None at all - it was a quick hack, so was a bit of a mess... I'll try to find
the time to make some sort of proper lightprobe/lightdome/backplate loading
macros.
You're welcome, and thank-you in turn.
Cheers,
Edouard.
