POV-Ray : Newsgroups : povray.binaries.images : House Project Server Time
27 Mar 2026 15:29:46 EDT (-0400)
  House Project (Message 11 to 20 of 23)
<<< Previous 10 Messages Goto Latest 10 Messages Next 3 Messages >>>
Subject: Re: House Project
Date: 2 Mar 2008 17:30:01
Message: <web.47cb2956cfb38859a5d4a01d0@news.povray.org>
Hmmm...what radiosity settings are you using?  And do you have ambient lighting
turned off?
If you really want to add some extra realism (and extra render time), use an
area light.  Don't use it in the animation, of course.
Date: 3 Mar 2008 08:00:00
Message: <web.47cbf5f0cfb3885929e2db5f0@news.povray.org>
> turned off?
I am using the default radiosity settings.  I never used radiosity before this,
but I am still toying with effects.
And an area light was used once, but it added a ton of extra time for the
animation, and It wouldn't have been done in time for the actual due date.
I'll toy with the settings a bit more.  If you have any ideas, by al means, I
would like to know them.
-Nimish
Date: 3 Mar 2008 09:50:01
Message: <web.47cc0f6fcfb38859a5d4a01d0@news.povray.org>
> > turned off?
> -Nimish
I recommend trying this:
Set the default texture to ambient 0.  (You can add the default statement from
the Misc Directives insert menu).  Set radiosity settings to:
radiosity {
  count 5            //increase if blochy.  Sometimes all you need is 1.
  error_bound .8     //The smaller the value, the better and the slower.
  recursion_limit 1  //all you really need, most of the time
Date: 3 Mar 2008 10:58:57
Message: <47cc2041$1@news.povray.org>
Did you see my previous post? I have access to some 8-core machines.
Date: 3 Mar 2008 16:03:17
Message: <47cc6795$1@news.povray.org>
Nimish Ajmani nous apporta ses lumieres en ce 2008/03/03 07:58:
>> turned off?
> -Nimish
A way to greatly accelerate area_light is to add adaptive 0 or adaptive 1 if you
get artefacts. That way, your area_light is almost as fast as a regular light
for most of the scene, it only slow down in the penumbrae. Optimum aray for
adaptive are: 5, 9, 17, 33, 65,... Even in the penumgrae, an adaptive area_light
don't sample every points of the array, just those whose neibours are different.
You know you've been raytracing too long when you read about an algorithm or
datastructure and your first thought is: "How can I use this to speed up
raytracing?"
Christoph Rieder
Date: 4 Mar 2008 12:31:14
Message: <47cd8762@news.povray.org>
"Nimish Ajmani" <nomail@nomail> wrote in message
news:web.47cb1c9ccfb38859835874580@news.povray.org...
     Very nice, but my only crit would be to tan the coffee table glass a
little as it's quite hard to see at the moment, (for me anyway), but keep up
the good work, it's looking good!
        ~Steve~
> -Nimish
Date: 4 Mar 2008 19:55:00
Message: <web.47cdee50cfb38859835874580@news.povray.org>
Thanks to everyone for all of the critique.  WE had to show our teacher to day
our progress, and he was extremely pleased with my work.  Thanks to all who
helped with it.
I'll post new pics soon, but I've started the animation portion, so I might
intersperse an animation here or there.
Date: 4 Mar 2008 21:33:49
Message: <47ce068d$1@news.povray.org>
A suggestion for the animation...  take the ceiling off all the rooms
and start your flight path by looking down from above...  like a floor
plan or 2-D drawing...  then drop down into one of the rooms and wander
about on a spline path.
Love the work so far.  Won't be offended if you ignore this suggestion :-)
> helped with it.
Date: 4 Mar 2008 22:10:00
Message: <web.47ce0ea7cfb38859835874580@news.povray.org>
I had already planned a spline for a fly-around, but I love the idea of
"dropping in a room."  I will include it, and thank you for your suggestion.
-Nimish
Date: 5 Mar 2008 15:07:22
Message: <47cefd7a$1@news.povray.org>
>> I did that so I could have an animated tour made for the house.
>> Unfortunately,
>> radiosity makes that kinda diffucult, as the project is due friday,
>> and It's
>> taking several minutes per frame, for nearly 10000 frames.
> I can help you with slow renders, but unfortunately my system might
> cause problems with radiosity... Could be worth a try anyway. Email me
> the sources as they are now (unfinished), and I'll try a few dozen
> frames. If it ends up working correctly, I could do the full render when
> you're done modeling.
I tried a radiosity scene to see if it worked correctly. And indeed, I
have a problem... The progress bar goes *nuts* during the prerender
radiosity passes :) But that seems to be the only problem.
