POV-Ray : Newsgroups : povray.binaries.images : Simple radiosity scene, with questionable results Server Time
7 Apr 2026 11:03:52 EDT (-0400)
  Simple radiosity scene, with questionable results (Message 11 to 16 of 16)
Subject: Re: Simple radiosity scene, with questionable results
Date: 10 Aug 2006 20:03:59
Message: <44dbc96f$1@news.povray.org>
Kenneth nous apporta ses lumieres en ce 10/08/2006 17:18:
>>> Alain <ele### [at] netscapenet> wrote:
>>>> Shifting this "may" help you getting rid of some artefacts near corners like
>>>> dark spots along inside corners.
>>> Shifting it up ot down?  Is it better to use a higher value for this or a
>>> lower value?
>> Equivalent. You only want the pretrace sampling to shift place so that they miss
>> the problem pixels. It's also advisable to move the camera a very small amount,
>> like +/-0.000001 unit.
> Do you mean, shifting the camera BETWEEN the pretrace steps? If so, how
> is that done?
> Ken W
Not during the pretrace. Before you start the rendering. There are some cases
where a radiosity sampling falls exactly on an internal corner. In those cases,
the sampling can look behind a wall for example, taking information from a
totaly dark area, leading to dark spots along the corner.
Changing pretrace_start or moving the camera very slightly can cause the problem
sampling to miss the critical points.
Wouldn't it be nice if whenever we messed up our life we could simply press
'Ctrl Alt Delete' and start all over?
Date: 10 Aug 2006 20:06:56
Message: <44dbca20$1@news.povray.org>
Kenneth nous apporta ses lumieres en ce 10/08/2006 16:18:
> "Samuel Benge" <stb### [at] hotmailcom> wrote:
>> Hi Ken. Are you the same Ken who once ran a big list of graphics links?
> Nope, never did. Sorry!
>> If I may give you some settings I always use for radiosity. Try these alone...
> I'll give them a whirl, and report back with the results.  Thanks.
>> The error_bound should be low for better shadows. This is one of the most
>> important settings. error_bound and count together should be modified
>> before anything else.
> Yes, I've been wondering about that.  It seems that count
> ISN'T the FIRST  thing to modify (given defaults
> for everything else.) Not much visual
> difference between low and high values, without modifying other things "in
> step" as well. Thanks for the tip.
>> In addition to these things, you should use a bright, fading (fade_power 2)
>> light inside the sphere instead of just making the sphere very bright. An
>> area_light (with orient and circular flags added) works well for this. The
>> sphere should be given the no_shadow flag to let the light shine through.
> Alas, I was *hoping* I could light this scene realistically just by using a
> pure, small ambient "light source," but I do understand that the radiosity
> equations (and/or just the default values) were made to be used with
> ACTUAL light sources. I may ultimately have to do as you suggest.  Haven't
> given up yet, though! ;-)
> Let me ask a very basic question:
> 1)  Is it ALWAYS better --that is, more realistic and of higher quality--to
> use the highest count possible and a very low error_bound value? (Assuming
> that the resulting l*o*n*g render time is unimportant.)
> Ken W.
You can have realy good lighting using only radiosity, but you get beter result
if you use relatively large ambient lights.
Everybody should believe in something: I believe I'll have another drink.
Date: 11 Aug 2006 07:16:50
Message: <44dc6722$1@news.povray.org>
Kenneth wrote:
> Sorry, I may have described things the wrong way.  In my scene, it *seems*
> that there should be MORE color spill onto the ceiling, from the
> saturated-color walls. But then again, the tall (distant) box shape seems
> to show quite good color spill from the red wall.  So perhaps I'm looking
> for an effect that really shouldn't be there. Difficult to tell!
   Then I think you are expecting too much spill, more than normal for
regular surfaces.
> [...] A higher nearest_count DOES radically improve
> things--but from what I've seen, it appears to make shadows less defined,
> sort of smoothing them out. Am I mistaken about that? Is it interacting
> with "something else" that I should change?
   Yes, with every other parameter!!! :) But I usually also raise
error_bound and that compensates the effect.
> I'm still trying to understand this "bounce" idea. But you're right, higher
> recursion_limit values seem to have less and less of an effect. I've
> settled on 3. Is it correct to assume that the more bounces, the more the
> various radiosity-created colors in the scene blend together and become
> MORE muted? If so, it sounds like something to be avoided (?) As you can
> see, I'm really struggling with these concepts!
   The more bounces, more realistic is the radiosity, as in reality
there are infinite bounces. But it's only useful with maze-like
situations. I think you should only use the number of bounces needed
just to light all the visible parts of the scene, no more.
Jaime
Date: 12 Aug 2006 17:30:00
Message: <web.44de475e88c0609f149e6880@news.povray.org>
Yes, that has been my experience as well. Making my single ambient 1 light
just two or three times larger greatly improves the "realistic" look of the
bounced radiosity.  I think that I might be giving POV a somewhat *extreme
situation* to deal with, by making my single light sphere so small. In
"normal" radiosity scenes that I've done, using a sky_sphere
and several actual light sources, it is MUCH easier to get
good results.
Ken
Date: 12 Aug 2006 19:47:44
Message: <44de68a0@news.povray.org>
Kenneth nous apporta ses lumieres en ce 12/08/2006 17:28:
> good results.
> Ken
Small ambient light mean more chance for ALL samplings from any sampling area to
miss it, resulting in dark patches in areas that should be lighted. If you rely
on a small ambient light, you must use a high count value to increase your
chance that any sampling will actualy hit that small object.
OFFICE ARITHMETIC
Smart boss + smart employee = profit
Smart boss + dumb employee = production
Dumb boss + smart employee = promotion
Dumb boss + dumb employee = overtime
Date: 13 Aug 2006 14:50:00
Message: <web.44df729388c060969698a500@news.povray.org>
That's a good analysis of something quite important that I
didn't realize. Thanks!
Ken
