POV-Ray : Newsgroups : povray.binaries.images : using an image_map for media density/color Server Time
21 Mar 2026 12:47:56 EDT (-0400)
  using an image_map for media density/color (Message 8 to 17 of 17)
<<< Previous 7 Messages Goto Initial 10 Messages
Subject: Re: using an image_map for media density/color
Date: 10 Apr 2006 03:20:01
Message: <web.443a06e9dc50c7b3f466d5bb0@news.povray.org>
> Kenneth,
> I tested your code and found out that you only need two images. The
> absorption and emission images being the same, you can use one for both the
> absorption and emission media.
> Just thought to mention this.
> Thomas
Hmm.  When I try that, the results don't look very good; the colors are kind
of "grayed-out."  I assume you mean using image #4 for both types of media?
The absorption-media image (#3) is different from the emitting-media image
(#4).  Or perhaps I'm misunderstanding your suggestion?
Ken
Date: 10 Apr 2006 03:54:10
Message: <443a0f22@news.povray.org>
"Kenneth" <kdw### [at] earthlinknet> schreef in bericht
news:web.443a06e9dc50c7b3f466d5bb0@news.povray.org...
> "Thomas de Groot" <t.d### [at] internlnet> wrote:
> > Kenneth,
the
> > Thomas
kind
media?
I think I am missing something. What is different between image #3 and #4?
Both have no-alpha channel, and a black background? Or is there something
else? I admit that I did not entirely understand your explanation there...
Date: 10 Apr 2006 05:50:00
Message: <web.443a29a1dc50c7b32ff47f1a0@news.povray.org>
> Thomas
No problem; sorry if I didn't make that clear.  Image #3 is just the dino
*shape* in white, surrounded by black; no greys or colors. (It looks the
same as the original image's alpha channel, but it's actually a separate
image.) It's used to create the solid black "plug" of absorbing media, in
the shape of the dino. Then image #4 is used for all three emitting medias;
this image contains the actual colors of the dino, to create three
primary-colored medias which are simply added to (or combined with) the
black plug.
Ken
Date: 10 Apr 2006 09:12:52
Message: <443a59d4@news.povray.org>
news:web.443a29a1dc50c7b32ff47f1a0@news.povray.org...
medias;
> black plug.
Right! Now, illumination has finally seeped through my thick braincase :-)
Thanks Kenneth! My results were indeed paler than yours (using the same
skeleton :-)  )
Date: 11 Apr 2006 03:25:01
Message: <web.443b58abdc50c7b3acc8f35f0@news.povray.org>
"Bob H" <omniverse@charter%net> wrote:
> I've been sitting here looking this over a while now, trying to figure what
> it does, and finally rendered something to check it out here.
> ...I also multiplied a color_map gradient
> z to get the fading out effect, as was suggested.
Congrats on accomplishing that so quickly; you beat me to it!  Not being
very wise in the way of math functions, I had to slog through a fair amount
of trial-and-error, discarding one attempt after another, before coming up
with a fade-out technique that worked well and looked good. Since the
medias are so dense, I needed a way to fade them out exponentially. Here's
my final result:
Create another pigment function:
#declare my_function_3 =
function{
 pigment{
  gradient z
  color_map{
   [0.0 rgb 1]
   [1.0 rgb 0]
Then use this in each of the four medias the same way, multiplying the
original function in each media by this one.  Like this...
for the absorbing media...
density{
 function{
  my_image_function_1(x,y,z).gray
  * my_function_3(x,y,pow(z,.07)).gray
and for each emitting media...
density{
 function{
  my_image_function_2(x,y,z).red // and green, and blue
Play around with pow(z,.07) to see the varying fade-out effect.
BTW, I got rid of the "extra" dino image on the rear of the box by using
interior_texture{pigment{color rgbt 1}}
Not ideal, but it does the job. Interior textures can behave strangely,
depending on where the camera AND the lights are positioned. If the camera
is moved around behind the box, then suddenly the box's REAR dino image is
visible and the front one isn't. And it creates a bit of havoc with light
sources, too. With the camera in the front (the -z direction) and a light
positioned behind the box, the "invisible" rear-face image casts no shadow.
 But if the light is also moved in front of that rear face, suddenly it DOES
cast a shadow...even though the rear image itself is not visible from the
front. The interior_texture doesn't actually ELIMINATE that rear-face image
(which is still on the "outside" surface of the box); it just "hides" it
from the camera and lights--depending on where THEY are.
Ken
Download 'dino_fadeout.jpg' (51 KB)
Preview of image 'dino_fadeout.jpg'
Date: 11 Apr 2006 03:55:00
Message: <web.443b600adc50c7b3acc8f35f0@news.povray.org>
"Chambers" <bdc### [at] yahoocom> wrote:
> Hasn't similar work been done using media voxels?  In any case, this looks
> amazing :)
Thanks!  I didn't know much about voxels at all, but your post  got me
interested, so I looked up the subject.  Fascinating! So THAT's how those
cool super-computer tornado simulations are accomplished...the swirling,
volumetric animations of air masses and densities. (Seems that isosurfaces
are involved as well.) So with POV, we already have the tools to do some
weather simulations!!
Ken
Date: 12 Apr 2006 10:04:02
Message: <443d08d2$1@news.povray.org>
"Kenneth" <kdw### [at] earthlinknet> wrote in message
news:web.443b58abdc50c7b3acc8f35f0@news.povray.org...
> density{
> function{
Good idea, you are right about the linear gradient fadeout being too solid.
---8<---
Very good point made there, glad you described the limitations. I tried the
following instead and it looks okay.
         gradient z
         pigment_map {
    [0.5 image_map {png "mediatest.png" map_type 0 interpolate 2 once}]
    [0.5 rgbt 1]
         scale 1.01 translate -0.001*z
Date: 12 Apr 2006 20:58:57
Message: <443da251@news.povray.org>
Kenneth nous apporta ses lumieres en ce 11/04/2006 03:20:
> my final result:
> function{
>  pigment{
>   gradient z
>   color_map{
>    [0.0 rgb 1]
>    [1.0 rgb 0]
> density{
>  function{
> density{
>  function{
> Ken
Have you tried cuting a slice off the box with another with an rgbt 1 pigment?
Enlarge the actual box toward the back, make a second shalow box a bit taler and
whider, and
difference it from the first.
This way, it will make the back of the box it's texture: pigment{rgbt 1}
Gravity is a Myth.  The Earth Sucks!
Date: 14 Apr 2006 03:05:00
Message: <web.443f48c6dc50c7b37e0dcd410@news.povray.org>
whider, and
Great idea!  I didn't think of that. Thanks. (Sometimes I get so wrapped up
with the problem at hand that a more obvious solution doesn't occur to me.)
I also tried using a slope pattern, which has its own idiosyncracies. You're
suggestion is much more straightforward.
Ken
Date: 14 Apr 2006 03:10:00
Message: <web.443f4a85dc50c7b37e0dcd410@news.povray.org>
> ... I tried the
>         pigment {
>          gradient z
>          pigment_map {
>     [0.5 rgbt 1]
A pigment_map is something I didn't think of. Very clever. I'll have to try
this!
Ken
