POV-Ray : Newsgroups : povray.binaries.images : Yet another ruddy knot Server Time
22 Dec 2025 06:18:18 EST (-0500)
  Yet another ruddy knot (Message 1 to 7 of 7)
Subject: Yet another ruddy knot
Date: 9 Feb 2006 05:45:01
Message: <web.43eb1c8c5a636d8a731f01d10@news.povray.org>
What ho
Another knot for your perusal. This one's slightly longer than the previous
one, and is composed of some 79,500 meshes. It took just over 10 minutes to
parse (reading precalculated knot path positions from a data file) and a
further 90 minutes to render with 2 area lights and radiosity on my iBook
(1.2 GHz, 512Mb RAM).
Interestingly, I tried the same scene on my office PC (~0.9GHz, 128Mb RAM)
and it took over 14 hours. A better illustration of the need for plentiful
memory I've yet to see. :)
I have plans to instantiate and copy all three knots several times in a
single scene. Does anyone know if the tiny memory overhead of mesh cloning
extends to meshes grouped in a union? (i.e., if each knot is a union of
meshes, will copies of that union gobble up my RAM?)
Bill
Download 'granny1.jpg' (204 KB)
Preview of image 'granny1.jpg'
Subject: Re: Yet another ruddy knot
Date: 9 Feb 2006 13:31:22
Message: <43eb8a7a$1@news.povray.org>
AFAIK, you will end up with references to all meshes, not to the union.
Altough those references should take little space that could be a lot,
assuming you're 79,500 meshes. Can't you merge some of those meshes (Not
the POV 'merge', of course)? Meshes don't need to be contigous, you know.
HTH,
Florian
Date: 10 Feb 2006 05:45:00
Message: <web.43ec6d87fb3f67d2731f01d10@news.povray.org>
It would be possible, but not my preferred option. I don't suppose anybody
knows just how much memory a mesh reference occupies?
Bill
Date: 10 Feb 2006 08:40:02
Message: <43ec97b2@news.povray.org>
I guess you'll find it in the sources, though creating a short test
scene should be faster:
A scene consisting of nothing but one of my JPatch models (exported as
mesh) took a peak memory of 30291988 bytes (about 28 MB). Using 10000
copies of the model instead resulted in about 55 MB of peak memory.
20000 copies cost about 82 MB, which makes about 27 MB per 10000 copies.
So a copy took about 2.7 KB additional memory, but that seems to be
quite a lot. I didn't add a transform or new texture to every copy, but
another quick test that showed that with a transform added, 20000 copies
cost 121 MB, which is significantly more.
HTH,
Florian
Date: 10 Feb 2006 11:05:00
Message: <web.43ecb987fb3f67d2731f01d10@news.povray.org>
Indeed. I've just tried a quickie, but the results are a little
inconclusive.
A basic trefoil knot with 25,000 meshes
Parse: 0.75mins
Peak mem: 46,912,657 bytes
Two of the above, 50,000 meshes
Parse: 4.5mins
Peak mem: 132,811,445 bytes
Three of the above, 75,000 meshes
Parse: 12.5mins
Peak mem: 172,211,521 bytes
The parse times are probably jumping because the memory runs out (128MB),
but the overall memory usage is a bit of a mystery. I shall experiment
further.
Bill
Date: 10 Feb 2006 14:02:57
Message: <43ece361$1@news.povray.org>
> further.
Hm, those memory values are certainly strange. Just to make sure: You're
using the mesh-copie mechanism (i.e. declaring and referencing objects)?
	#declare MyBigMesh = mesh { ... }
	object { MyBigMesh transform somewhere }
	object { MyBigMesh rotate a_bit }
What about textures/transforms/etc? Are they declared and referenced
also? Embedding them in the mesh should do the job, too, although I'm
not sure if embedding them in the union does.
HTH,
Florian
Date: 13 Feb 2006 04:45:00
Message: <web.43f05483fb3f67d2731f01d10@news.povray.org>
Yes, but the single knot was not #declared first, and the others are
#declared as unions of meshes. It looks as if (for meshes, at least) the
declaration takes up the same amount of space as the instantiation, so I've
actually got three knots in memory for the 2-knot case and four knots in
memory for the 3-knot case. So large unions should probably not be
#declared and copied unless the code takes up a *lot* of space!
After playing with the composition of my scene a little, I think I may get
away with just one of each type. This will probably fit into memory without
too much of a squeeze...
Bill
