POV-Ray : Newsgroups : povray.binaries.images : Can you tell what it is yet? Server Time
22 Mar 2026 03:09:36 EDT (-0400)
  Can you tell what it is yet? (Message 11 to 20 of 73)
Subject: Re: Can you tell what it is yet?
Date: 13 Oct 2005 02:28:59
Message: <434dfeab$1@news.povray.org>
news:434da298$1@news.povray.org...
> Why is there no gravity?  If you take a sun-sized star and build a
> sphere of Earths around it at 1 AU (dunno where you'd get that many
> Earths), does the now hollow sphere not have gravity on either its
> inside or outside surface?
> Tim Cook
> http://home.bellsouth.net/p/PWP-empyrean
Yes finding so much matter should be a problem but Alain is still right:
what could prevent other parts than equator falling in the star.
Marc
Date: 13 Oct 2005 03:00:01
Message: <web.434e05b34ff5b9987d39e9c30@news.povray.org>
"Anthony D. Baye" <Sha### [at] hotmailcom> wrote:
> Mike Williams wrote:
> > Apart from the absence of the plasma tube, I'd say it was Thistledown.
> > Where does your hollow asteroid get its light from?
> Wow.  Someone else reads what I read.
> A.D.B.
> P.S. Alain,  Gravity is based on mass.  A sphere the size of earth's
> orbit with a shell thick enough to withstand impacts would naturally
> have a reasonable amount of gravity on it's inside surface.
Sorry Anthony,
but Alain is right. Inside a sphere there is no gravity from the sphere -
ask any physics guy ( me, eg ;-) ); at least if the sphere is homogeneuos
(spelling?). While Your statement definitely sounds convincing, this is one
of the few cases proving common sense can go wrong without dealing with
quantum mechanics ...
Happy Raytracing to all
Karl
Date: 13 Oct 2005 03:06:04
Message: <YX1VKAAnZgTDFwNB@econym.demon.co.uk>
Wasn't it Tim Cook who wrote:
>Alain wrote:
>> I have a BIG problem with Dyson spheres! Inside an hollow sphere, there
>> is NO gravity, if the sphere is built around a star, everything not held
>> in place will fall in the star. If you make it spin, all the air will
>> collect at the equator, untill the sphere collapses unto itself. The
>> equatorial part goes flying away and the poles plunging into the star.
There's gravity on the outside, but not on the inside. It just so
happens that the strong contributions from the small regions under your
feet are exactly cancelled out by the weaker contributions from the much
larger regions over your head. I don't think there's any simple way to
demonstrate that, you have to calculate the integral like Newton did.
Mike Williams
Gentleman of Leisure
Date: 13 Oct 2005 04:07:58
Message: <434e15de$1@news.povray.org>
There's a good lot of discussion on Wikipedia. Search for Dyson Sphere
and then go to the discussion page (tab at the top). Talks about the
calculations et. al.
There'd be neutral gravity on the inside, but if you spin the sphere
fast enough, then momentum-in-a-circular-restriction (aka centrifical
force) will stick you to the sphere. Something like 32km/s (or 320 ..
it's been a while) for a 1AU sphere.
(And the gravity on the outside would be horrendous, the gases from the
sun would kill you, there's not enough matter to make it .. yada yada ..
great concept for SciFi, and ray tracing, but not real life!)
Cheers!
Rick Measham
Date: 13 Oct 2005 05:44:34
Message: <q1S5yNA5oiTDFwIT@econym.demon.co.uk>
But only the people standing on the equator would get vertical gravity
at full strength.
The strength of the force varies with cos(latitude) and the angle to the
local vertical is proportional to latitude. So people standing near the
poles get very little force, and what force there is would be almost
horizontal.
Date: 13 Oct 2005 07:02:34
Message: <434e3eca@news.povray.org>
> horizontal.
Which is where the original argument came from (and I agree) .. the
poles would implode, thus degrading the structure and causing the
equator to explode.
One poster (somewhere, not here) suggested a band rather than a sphere.
The 'band' would be the equatorial region and would (somehow) hold
together as it spun.
Download 'animated.gif' (62 KB)
Preview of image 'animated.gif'
Date: 13 Oct 2005 11:33:08
Message: <434e7e34$1@news.povray.org>
Anthony D. Baye nous apporta ses lumieres en ce 2005-10-12 20:50:
> A.D.B.
The gravitational pull from the relatively small but very near region under your feet
is exactly
countered by that of the extremely large and distant part over your head.
That leave you with ONLY the gravity from the sun witch is straight up... NOT a good
thing.
'hAS ANYONE SEEN MY cAPSLOCK KEY?'
Date: 13 Oct 2005 12:40:56
Message: <434e8e18$1@news.povray.org>
<English swot>
Homogenuous!
</English swot>
See you in Khyberspace!
Yadgar
Now playing: Starship Trooper (Yes)
Date: 13 Oct 2005 13:51:22
Message: <434e9e9a$1@news.povray.org>
>> A.D.B.
> under your feet is exactly countered by that of the extremely large and
> up... NOT a good thing.
Far be it from me to dislike being proved wrong.
but an interesting factoid:  Larry Niven's Ringworld, which was
conceived as an intermediate step toward a dyson sphere, spun at 770
mi/h.  It was determined that, in order to withstand the shearing forces
from the spin, the base material which measured 1000' thick would have
had to have had a tensile strength on the order of the force which holds
the nucleus of an atom together.
A.D.B.
Date: 13 Oct 2005 13:54:03
Message: <434e9f3b$1@news.povray.org>
Let me get this straight.  If you put a hypothetical mass, say, ten
times the mass of the earth, in an orbit exactly opposite the earth, the
gravity under your feet will be countered by a certain amount by the
extremely large and distant mass over your head?  In other words, to
simplify things, without extra masses...you weigh less at noon?
Tim Cook
Version: 3.12
