POV-Ray : Newsgroups : povray.binaries.images : Help with lighting/texturing and such Server Time
15 Apr 2026 21:48:52 EDT (-0400)
  Help with lighting/texturing and such (Message 3 to 12 of 12)
<<< Previous 2 Messages Goto Initial 10 Messages
Subject: Re: Help with lighting/texturing and such
Date: 14 Jun 2001 07:11:38
Message: <3b289bea@news.povray.org>
What Gail said. Mostly drop the ambient to nearly zero.
Date: 14 Jun 2001 08:32:47
Message: <3B28B04C.8DF7FD67@yahoo.com>
And if you look hard enough, you can see you got perspective a bit wrong...
May I suggest moving the camera farther from its point of view and reduce the
viewing angle...
||  'How do you know I'm mad?' said Alice.
||  'You must be,' said the Cat, 'or you wouldn't have come here.'
 Simon Lemieux  (lem### [at] yahoocom)
Date: 14 Jun 2001 10:45:59
Message: <3B28CEE7.7C19D5A7@inapg.inra.fr>
Oldstench wrote:
> If anyone can help a decent modeller but terrible texture/lighting guy
> out, I would really appreciate it. Thanks.
Megapov's radiosity would really help a lot (see TonyB's post a few lines
above) to add realism.
G.
http://www.oyonale.com
Graphic experiments
Pov-ray gallery
Date: 14 Jun 2001 13:26:06
Message: <0f7iito5pu8imq1c7h9no5eoqnlsshdo2c@4ax.com>
"Gail Shaw" <gsh### [at] monotixcoza> wrote:
>Oldstench <sor### [at] butnocom> wrote in message
>news:p96hitcda0l0iuc5rvc8kn50cfnun5v26m@4ax.com...
>> 1) Can anyone help me with a good plastic texture? As you can see, mine
>> sucks. The highlights are nowhere near as good as the original (esp. on
>the
>> rightmost yellow plug.)
>What's your finish settings? If you're using metallic which it looks like
>you are)
>then remove it
>Try something like
> finish {
>  ambient 0
>  diffuse 0.78
>  specular 1
>  roughness 0.01
>> 3) How can I make a blurred shadow in Moray? I can not seem to be able to
>> do this.
>Area light, but your shadows look blurred already. What's the problem?
 I meant to say blurred reflections. Sorry
>Gail
>* gsh### [at] monotixcoza                *   Step into the abyss,           *
>* http://www.rucus.ru.ac.za/~gail/   *   and let go.          Babylon 5 *
>* The difficult we do immediately, the impossible takes a little longer *
Oldstench................
Date: 14 Jun 2001 13:32:56
Message: <8q7iitc47u23ebj6s88v5lsc6pmb40orp6@4ax.com>
>viewing angle...
Yeah, I can see that, but I wasn't trying to get it perfect, I just wanted
to try to get realistic textures and lighting. The models aren't the right
size either, but I just guesstimated from the picture. Thanks for the
input.
Date: 14 Jun 2001 13:34:19
Message: <9u7iit4ujhbgdguah1l13fka9bgcc7f7bs@4ax.com>
>G.
Is Megapov's radiosity any different from regular Pov's?
Date: 14 Jun 2001 14:23:44
Message: <3B2901F2.CCBA8921@inapg.inra.fr>
It gives better results and is easier to set up. It's also faster, unless one
cranks up the quality to extreme.
There's code for it in the scene-files groups, or you can go to Christoph
Hormann's page for his Megapov rad tutorial.
http://www.schunter.etc.tu-bs.de/~chris/
G.
Graphic experiments
Pov-ray gallery
Date: 14 Jun 2001 16:53:36
Message: <3B2925F4.89AA2062@mail.com>
I think things are not so bad as you think.  If you could use radiosity
to model the shadows (i.e.. in that shadowed groove of the yellow plug
to the right) and use focal blur things would look a lot better.
As far as modeling goes, it looks like you actually see light source
reflected on the plastic in the original.  I think that's why the
highlights are so saturated.  You could use the looks like keyword in
the light source declaration to make something that looks a bit like a
fluorescent light fixture.
I also agree that you need to drop your ambient down a bit, and turn the
specular, diffuse, and/or phong highlights up.  Plus, add in some amount
of reflection to the plastic.
Ben
Date: 15 Jun 2001 11:41:24
Message: <3B2A2CE6.57968CAB@gmx.de>
Oldstench wrote:
> Hello all,
> The image nice-plug(in).jpg was taken from the rhino forum. It was modelled
> in Rhino and rendered in Flamingo. The image stolen_plug_idea.jpg is my
> version, modelled in Rhino, set up and textured in Moray, and rendered in
> POV. The models and positioning are obviously not going to be exact, there
> is also no focal blur. Now for what I need help with.
Apart from the things already suggested (especially radiosity, reduced
ambient and reflection for the plastic), i would also consider blurred
relection.
In general when using a graphical modeller it often makes sense to do the
final tuning with a text editor in the povray source.  You are not
restricted to the possibilities Moray supports then.
Date: 15 Jun 2001 12:16:31
Message: <3b2a34df@news.povray.org>
I fear it's a quite hard challenge. It's not so easy to take an image made
with a particular renderer and to reproduce it exactly with another one.
This Flamingo rendering is really photorealistic and I don't think POV
(which is a fantastic raytracer, but which has a quite simplified lighting
model) could make an image as good as that.
(I'm writing this so that someone, -Gilles, H.E.Day, Warp, Hormann & Co-,
pushed by his pride, will soon post stunning images showing that, once
again, POV is the winner and that Flamingo, Lightflow, Lightwave and all
that $oftwares suck).
Call it POV-Pride.
JRG.
