POV-Ray : Newsgroups : povray.binaries.images : luminosity problem - Cube_Radiosity_Final.jpg (1/1) Server Time
29 Jul 2024 20:21:15 EDT (-0400)
  luminosity problem - Cube_Radiosity_Final.jpg (1/1) (Message 1 to 7 of 7)
Subject: luminosity problem - Cube_Radiosity_Final.jpg (1/1)
Date: 11 Jan 2014 11:10:23
Message: <kurtzlepirate-AF1476.17102311012014@news.povray.org>
hello,
in your opinion, why both sides of the cube are so darker than the top
face ?
one plane, one sky_sphere and the cube.
no light.
use of standard "Radiosity_Final" parameter.
all object are white
ambient is set to zero in de default settings
thanks for your help.
klp
Download 'cube_radiosity_final.jpg' (47 KB)
Preview of image 'cube_radiosity_final.jpg'
Subject: Re: luminosity problem - Cube_Radiosity_Final.jpg (1/1)
Date: 11 Jan 2014 12:15:00
Message: <web.52d17bc75d182da3548443500@news.povray.org>
> face ?
> no light.
The light is coming from the sky sphere, and you have blocked the lower half of
that sphere with your plane.  Therefore, the sides are only exposed to roughly
half of the amount of light that the top gets.
Date: 11 Jan 2014 12:55:00
Message: <web.52d184a15d182da3df648c9e0@news.povray.org>
I just thought the same as Kirk. But how did you came to this image? Mondrian in
black and white as a stock photo? A very nice minimalistic scene IMO.
Best regards,
Michael
Date: 11 Jan 2014 14:45:01
Message: <web.52d19e465d182da3c8e1b36b0@news.povray.org>
kurtz le pirate <kur### [at] yahoofr> wrote:
> hello,
> face ?
Kirk is right: the ground plane is blocking light from the sky_sphere's lower
half.
Nice image. How did you produce the cube object, BTW? With an algorithm, or
hand-placed boxes?
Sam
Date: 11 Jan 2014 17:10:00
Message: <web.52d1c0495d182da3306548240@news.povray.org>
> hello,
> face ?
> no light.
My first thought was the same as the others--that the ground plane is blocking
half the light.  But then I thought, if the ground plane is white, isn't it
reflecting the same light as the sky?
It turns out, if the diffuse on the cube and plane is set to 1.0 /and/ the
radiosity recursion_limit is set high enough (5 in my trials), then all sides of
the cube are the same shade.
Date: 11 Jan 2014 19:30:00
Message: <web.52d1e1c85d182da3306548240@news.povray.org>
I just looked at Radiosity_Final, and it sets recursion_limit to 1.  If I
understand radiosity sufficiently, this means that the cube is not getting the
effect of the light reflected off the ground plane.  (At the first bounce,
radiosity is calculated only from non-radiosity illumination, of which there is
none in your scene other than the sky_sphere.)  This is why the ground plane
ends up blocking half the light, despite being white itself.
I never use recursion_limit 1 for a final render.  2 is usually sufficient, but
in your case, you'll need to go higher.
Subject: Re: luminosity problem - Cube_Radiosity_Final.jpg (1/1) - Cube_Radiosity_Modif.jpg (1/1)
Date: 12 Jan 2014 03:47:08
Message: <kurtzlepirate-872E10.09470612012014@news.povray.org>
hi,
it seems that the problem comes from the plane that block the light.
with the comment of 'Cousin Ricky', i'm testing changing some values
in /Radiosity_Final/ settings :
 * count 800 -> 50 //  just for speed in tests
 * error_bound 0.20 ->  0.05
 * recursion_limit 1 -> 2
 * brightness 1.0 -> 0.80
these parameters gives this new image which is much better.
i will continue my tests by adjusting other param/values.
about image itself, just an idea like that, i have not thought of
Mondrian. this image as hand-placed boxes, but, I had already made an
algorithm for generating Mondrian pictures.
you can see it on my page <http://louisbel.free.fr/scenes/scene021.shtml>
(in french)
thanks a lot for your help.
Download 'cube_radiosity_modif.jpg' (44 KB)
Preview of image 'cube_radiosity_modif.jpg'
