POV-Ray : Newsgroups : povray.binaries.images : Blurred transparence - attached files (1/1) Server Time
23 Mar 2026 14:53:17 EDT (-0400)
  Blurred transparence - attached files (1/1) (Message 1 to 10 of 13)
Subject: Blurred transparence - attached files (1/1)
Date: 11 Oct 2000 19:19:35
Message: <chrishuff-8E2C39.18215211102000@news.povray.org>
I have been working on a new transparence patch, eventually it will
allow transparency to be controlled independantly of the pigment
color(which will make use of transparent image_maps easier), but
currently, only blurring is implemented. I have added two blur
algorithms, one is based on the one used in the blurred reflection
patch, which shoots a number of randomly jittered rays and averages
their results, and a new one which attempts to solve the graininess
problem of the original but is less accurate and has other aliasing
problems. Basically, it shoots evenly spaced rays in two planes parallel
to and intersecting along the ray, and perpendicular to each other.
I plan to update the blurred reflection patch as well...my blurring code
is at a deeper level, so the same code can be used for both reflection
and transparence.
Christopher James Huff
Download 'blrtrns0.jpg' (15 KB) Download 'blrtrns1.jpg' (14 KB)
Preview of image 'blrtrns0.jpg'
Preview of image 'blrtrns1.jpg'
Subject: Re: Blurred transparence - attached files (1/1)
Date: 11 Oct 2000 20:41:45
Message: <39e508c9@news.povray.org>
Glee!!! Keep working on it. You're a smart kid, I'm sure you'll get
something good working soon. :)
Date: 12 Oct 2000 06:40:38
Message: <39e59526@news.povray.org>
:D
Very nice!!
#declare Ultimate_Povray_Programmer =
 merge {
  object {
   Chris_Huff
  object {
   Nathan_Kopp
  object {
   Pov_Team
:p
ian
Chris Huff wrote in message ...
Date: 12 Oct 2000 12:36:54
Message: <slrn8ubq58.87n.ron.parker@fwi.com>
On Thu, 12 Oct 2000 06:45:26 -0700, ian wrote:
>:D
>Very nice!!
> merge {
>  object {
>   Chris_Huff
>  object {
>   Nathan_Kopp
>  object {
>   Pov_Team
But then you wouldn't be able to see parts of Nathan, because you'd get a
coincident surface problem with the two copies of him.
Ron Parker   http://www2.fwi.com/~parkerr/traces.html
My opinions.  Mine.  Not anyone else's.
Date: 12 Oct 2000 15:07:34
Message: <39E60BF7.A7CE2A8D@schunter.etc.tu-bs.de>
> and transparence.
That looks promising, but if i understand things right both blurred reflection
and transparency are only fakes for rough surfaces (of course that doesn't mean
they are obsolete) The structures in the second version seem to have some
similarities with shadows from area lights.
I estimate both algorithms take quite long to render compared to normal
transparency depending much on what's behind the transparent object.
BTW, I remember you working on some pattern blurring function, did you have any
results in that direction ?
Date: 12 Oct 2000 15:57:16
Message: <chrishuff-14C6EB.14594912102000@news.povray.org>
In article <39E60BF7.A7CE2A8D@schunter.etc.tu-bs.de>,
> reflection and transparency are only fakes for rough surfaces (of
> course that doesn't mean they are obsolete)
True, they are intended to simulate evenly rough surfaces. You can get
more precise and controllable results using a normal, but you need
antialiasing to get the effects to be visible, and that affects the
whole scene and is slow.
If I can figure out a way to supersample specific textures or objects, I
will try to implement it...it could use a method similar to the blur
algorithms I am working on now. If I can work out how to get an estimate
of the ray footprint, a sort of imitation differential ray-tracing might
be possible.
> The structures in the second version seem to have some similarities
Yes, because the rays "fan out" and are evenly spaced, the spacing gets
larger with distance, similar to the way area shadows spread out.
These artifacts should be less visible with more random backgrounds(the
checker pigment used here really shows the problem because of it's
repetitive nature).
I suppose if the original algorithm is like media method 1, the current
one is like media method 2. I have a couple ideas for anti-aliasing the
blur:
1) Sample along 2 perpendicular directions, like the existing method 2,
but super-sample between two samples when their difference in color
exceeds a threshold. This would be sort of like media method 3...
2) Send rays out in a triangular pattern, dividing into sub-triangles
when necessary. This would have the advantage of covering an area of
space instead of sampling along two directions...the recursive triangle
pattern might make the aliasing less noticeable, too.
Compared to ordinary transparency: yes, it is much slower. However, the
second version can sometimes produce smoother results with the same
number of samples than the first version, so the slowdown isn't too bad,
especially if it only covers a small area of the image.
These images both had 12 samples, and rendered in about the same
time(around 2 minutes, though I haven't performed a real test of
rendering speed yet).
> you have any results in that direction ?
I am planning to make another try, the first one wasn't very successful
or easy to use(it used a 3D convolution matrix, which allowed effects
other than blur, but was a pain to use and too slow with matrices large
enough to get decently smooth blur. I plan to allow this and another,
easier to use and faster method in my next try.). I am debating whether
to blur patterns or pigments...probably both.
Date: 12 Oct 2000 17:34:59
Message: <39E62E83.2104786E@schunter.etc.tu-bs.de>
> repetitive nature).
> blur:
How about combining geometric and random techniques, that would help adjusting
graininess, but i'm not sure if that's easy to implement.
I always thought a convolution matrix can only be applied to a rastered pattern,
at least you would have to specify some kind of scale factor for the matrix IMO.
If i understand things right, it's worth trying adaptive calculations (like used
with antialiasing) when working with a larger matrix.
Date: 12 Oct 2000 21:21:42
Message: <chrishuff-9A3167.20241912102000@news.povray.org>
In article <39E62E83.2104786E@schunter.etc.tu-bs.de>,
> adjusting graininess, but i'm not sure if that's easy to implement.
I plan to add jittering to my patch eventually, it should be quite easy.
> rastered pattern,
Why?
> matrix IMO.
What? I don't know what you mean by "scale factor"...
My patch allowed you to specify the size of the matrix separate from the
number of elements, is that what you meant?
> (like used with antialiasing) when working with a larger matrix.
That is the other method I was talking about. :-)
Basically, sample along each axis, possibly with anti-aliasing and/or
jitter.
Date: 13 Oct 2000 04:16:16
Message: <39E6C4CF.D31473CE@schunter.etc.tu-bs.de>
Sounds like a good idea to me.
> > rastered pattern,
> Why?
> > matrix IMO.
I mean the convolution matrix has some scale in relation to the pattern, the
distance between two neighbored elements in the matrix must have some
representation in Pov-units.  Of course that's independent from the number of
elements...
> jitter.
That's not exactly what i was thinking of, although it also sounds interesting.
I meant a regular convolution matrix but leaving out elements in calculation
that are not neccessary.  Imagine fo example blurring a checker pattern leads to
a lot of identical elements in the matrix.
After thinking a bit further about this idea it's probably not that feasible,
maybe just forget about it :-)
Date: 13 Oct 2000 05:11:39
Message: <39E6DFAF.41B3AD9@mailme.dk>
Hello!
I'm really glad whenever I see people want to improve POV, and are able
to do it!  ;o)  Now, pardon me for being dumb maybe but I still wonder
why you are not using a simpler method for blurring.
I can imagine my idea isn't working with transparent surfaces, but.. In
my opinion it wouldn't produce a wrong result if: POV renders the
reflection in the "ordinary" old way, but into a separate buffer instead
of the screen. Then use simple and fast gaussian blur, and them UV map
it onto the object again, as a pigment.
I don't know if nearby objects are supposed to blur less, according to
physics, but if so, then we could use the same method as post-processing
camera depth blur.
I know there's a tricky thing according to edges of the object, if it's
blurred my way. But my idea is that the buffer should contain a
reflection of the object that "follows the objects shape".
As you can see, I'm not used to explaining this.. But I can try further,
if necessary..  :o)
Hugo
