POV-Ray : Newsgroups : povray.binaries.images : displace_warp - dispWarp.jpg (1/1) Server Time
8 Apr 2026 07:24:40 EDT (-0400)
  displace_warp - dispWarp.jpg (1/1) (Message 11 to 18 of 18)
Subject: Re: displace_warp - dispWarp.jpg (1/1)
Date: 25 Jun 2000 18:45:15
Message: <39568C39.6F528226@aol.com>
Chris Huff wrote:
> > Ah, yes. I was playing with something like this a few weeks ago. You can
> > make subliminal images this way.
> I'm not quite sure what you mean...was it a patch? If so, I would be
> interested in what you came up with...my patch simply adds the "color"
> vector to the position vector.
No, it was using combined functions of #declared pigments. I just tried it
again, and your method does it differently, so no, mine wasn't quite like
yours.
> And "subliminal images"?
Err, subliminal messages using images. Hidden images the subconscious mind
picks up. Adverstisements used to use them.
BTW, I'm looking forward to your patch.
Samuel Benge
E-Mail: STB### [at] aolcom
Visit my isosurface tutorial at http://members.aol.com/stbenge
Date: 25 Jun 2000 18:59:44
Message: <chrishuff-C77E7F.18041325062000@news.povray.org>
In article <3956875a@news.povray.org>, "Simen Kvaal"
<sim### [at] studentmatnatuiono> wrote:
> When will this make it into the next (?) MegaPOV-release?
Don't know...Nathan has said he is busy with something called "life", so
probably whenever he gets spare time. It will be in my next release of
MegaPOV+, though. I only release a Mac application and the source code,
you will have to compile it yourself if you use Windows, Linux, BeOS,
etc.
Date: 25 Jun 2000 19:08:22
Message: <chrishuff-BA3AE4.18125125062000@news.povray.org>
In article <39568639$1@news.povray.org>, "Simen Kvaal"
>       //something like; don't know the synatx ;)
The syntax is like this, you had it pretty close.
    blah-blah
    warp {
        displace_warp {
            PATTERN+COLOR_MAP or other pigment stuff
Though I will probably shorten "displace_warp" to simply "displace"
before I release it. The "_warp" is a bit redundant, since it is always
used in a "warp {...}" block.
Date: 25 Jun 2000 19:17:03
Message: <chrishuff-DD74F1.18213225062000@news.povray.org>
In article <39568C39.6F528226@aol.com>, SamuelT <STB### [at] aolcom>
> tried it again, and your method does it differently, so no, mine
> wasn't quite like yours.
Hmm, I see...I think it would be possible to duplicate the patch with
function patterns and 3 pigment functions(one for x, y, and z). It would
be much more complex to use, though, and probably a lot slower.
> mind picks up. Adverstisements used to use them.
Yeah, I know what subliminal messages are supposed to do...I just don't
see how they fit in with my patch. If you aren't careful, the pattern
gets scrambled beyond recognition, conscious or subconscious.
BTW, it might be interesting to apply this warp to an isosurface
function pattern used in a pigment function to see how it affects the
resulting object...did that make sense?
#declare Foo = function {pigment {function {...}...warp {displace
isosurface {function {Foo(x,y,z)}}
Date: 25 Jun 2000 19:25:05
Message: <q05dlsgo61bucggu6ki87rkqjncler5out@4ax.com>
On Sun, 25 Jun 2000 18:04:13 -0500, Chris Huff <chr### [at] maccom>
This "life" thingy is very addictive, believe me. I too used to spend
hours in front of the stack of gridded sheets (or, later, the
monitor).
Peter Popov ICQ : 15002700
Date: 26 Jun 2000 02:37:12
Message: <3956fa18$1@news.povray.org>
Very Nice! this one looks very useful.
Mick
"Chris Huff" <chr### [at] maccom> wrote in message
news:chrishuff-55AC14.11432025062000@news.povray.org...
> Remember the "distortion field"? This feature is similar, but it is an
> actual patch that implements a warp which does the same thing to a
> pattern. The syntax is simple:
> warp {
>     displace_warp {PIGMENT}
> Here is an image of a displace_warped checker pattern(left) and a
> gradient pattern(right). The displacing pigment is a bozo pattern with
> an automatically generated color_map.
> Christopher James Huff - Personal e-mail: chr### [at] maccom
> TAG(Technical Assistance Group) e-mail: chr### [at] tagpovrayorg
> Personal Web page: http://homepage.mac.com/chrishuff/
> TAG Web page: http://tag.povray.org/
Date: 26 Jun 2000 02:52:34
Message: <3956FEB3.5D7B38F4@yahoo.com>
would this be like adding two pigments together, like beats in wave
theory, where matching peaks cause constructive interference and
matching troughs create destructive interference and values in between a
mix of the two?  i'm thinking this would cause a mix between say, bozo
and granite to look like neither one.  i am way off?  or am i getting
it?
> warp {
Date: 26 Jun 2000 10:40:39
Message: <chrishuff-D15E51.09450926062000@news.povray.org>
In article <3956FEB3.5D7B38F4@yahoo.com>, ryan constantine
> it?
No. It distorts a pattern by moving each point by the value of the color
vector of the displacing pigment at that point. The displacing pigment
isn't used for colors, but for vectors. The rgb values are used for xyz
values for translating the each point of the pattern being warped.
I am trying to figure out how to add a "vector_map" keyword, that would
clear things up a little.
