POV-Ray : Newsgroups : povray.binaries.images : mars probe landing site [88k] Server Time
31 Dec 2025 13:07:41 EST (-0500)
  mars probe landing site [88k] (Message 1 to 10 of 11)
Subject: mars probe landing site [88k]
Date: 4 Jan 2004 13:12:11
Message: <a21mc1-eht.ln1@triton.imagico.de>
From current cause: a render of the landing site of the recent NASA
mars probe 'spirit'.
See also:
http://marsoweb.nas.nasa.gov/landingsites/
Last updated 25 Oct. 2003 _____./\/^>_*_<^\/\.______
Download 'mars_spirit1.jpg' (89 KB)
Preview of image 'mars_spirit1.jpg'
Subject: Re: mars probe landing site [88k]
Date: 5 Jan 2004 11:46:55
Message: <3FF99635.944C0D00@gmx.de>
High!
Cool image... is the surface just a bumpmap or a real relief? If the latter,
how did you do it, with a common mesh or with your Iso_HF macro?
How long did it parse?
See you in Khyberspace!
Yadgar
Date: 10 Jan 2004 00:21:15
Message: <3fff8bcb@news.povray.org>
Here's one of the Spirit landed color images *before* it was "cleaned up".
Guess how POV-Ray fits into this picture? :-)
Jon
Download 'ColorMars.jpg' (32 KB)
Preview of image 'ColorMars.jpg'
Date: 10 Jan 2004 00:40:38
Message: <m14vvvg9ls4mvdpd205urrhqiccndj55br@4ax.com>
On Fri, 9 Jan 2004 23:19:43 -0600, "Jon Berndt" <jsb### [at] hal-pcdotorg> wrote:
Nice one!
Regards
Subject: Re: mars probe landing site YAMPLS [27K JPG]
Date: 10 Jan 2004 13:38:26
Message: <400046a2@news.povray.org>
The monolith fits right into this scene, just needs a few proto-humans
touching it and jumping around.
Christoph didn't mention the specific source for his elevation map but it
looks like it has real good resolution. I didn't look around too far into
the aforementioned web site.
However, I used some images from www.space-graphics.com which seem very good
too. Nice thing about the texturing image map is that it doesn't use faked
shadowing, which messes up the lighting direction. The bump map is very high
resolution, and yet I'm not sure if it rivals that of Christoph's or not
since I haven't rendered the Gusev crater region. Here's the expected
Opportunity rover landing site though. Should be slightly down and right of
center. I'm still working on the media for the dusty air because it doesn't
spread across the planet the way I'd like it too.
Bob H.
http://www.3digitaleyes.com
Download 'Mars_Opportunity_Landing-Site_small.jpg' (20 KB)
Preview of image 'Mars_Opportunity_Landing-Site_small.jpg'
Date: 11 Jan 2004 06:42:03
Message: <b6p7d1-5ih.ln1@triton.imagico.de>
http://wufs.wustl.edu/missions/mgs/mola/megdr.html
The complete planet data is nearly 2 GB.
The elevation map is probably lower resolution but the image maps look
very nice (especially the 'flat' one on
http://www.space-graphics.com/redmars_v3.htm) - i was not able to find
any high resolution images without shading when i did my first renders.
Last updated 11 Jan. 2004 _____./\/^>_*_<^\/\.______
Date: 23 Jan 2004 16:02:34
Message: <40118be9@news.povray.org>
Cool image. The atmosphere is IMO too big and strong but artistic reasons
justify the exageration. The flat angle of light definitely rocks.
I'm rendering landing sites as well currently, but Christoph was
faster, as always :)
Just a question:
Spirit is located at 14.59 S, 175.30 E (IAU 2000)
Is my assumption correct that we're in the tile megt00n090.. ?
(I just want to be sure, there seem to be different zero longitude
definitions around...)
Wolfgang
Date: 23 Jan 2004 21:41:19
Message: <4011db4f$1@news.povray.org>
"Wolfgang Wieser" <wwi### [at] gmxde> wrote in message
news:40118be9@news.povray.org...
> Just a question:
Yes, that's the one. "000" for longitudes 000 to 090, "090" for 090 to 180,
"180" for 180 to 270, lastly "270" for 270 to 360. Apparently only files
needed are the megt*.img ones too.
What confused me at first was how the megt00n000hb.img to megt00n270hb.img
tiles are really for the southern hemisphere too. As you might have already
discovered, it goes southward from 00*n* to 44s and for northward is 44n to
88n. Oh, and watch out for those missing 2 degrees at the poles. I finally
worked that out for a orthographic rendering which pieces all the tiles
together for a spherical image map I used afterward. Polar tiles were
shifted up or down by about 6% of a unit, for my unit-sized tiles which are
30 X 30 degrees each.
I'm using 3DEM, http://www.visualizationsoftware.com/3dem/downloads.html ,
to convert those IMG files to bitmaps and it's both free and very good at
manipulating or displaying them.
P.S.
Something strange about the Mars image/bump maps I got from
www.space-graphics.com was that I needed to rotate a little to align with
POV's map_type 1, 'rotate (+80.88-175.2)*y', or else it was offset from the
wrapped ends. Using the start/end wrapping point to judge where the planet
surface features are when the camera is directly along -z (or +x if not
rotating away from the 0 degree longitudinal line) it makes it a little
tricky if that line isn't at zero.
Bob H.
Date: 24 Jan 2004 09:03:11
Message: <40127b1e@news.povray.org>
> 180, "180" for 180 to 270, lastly "270" for 270 to 360. Apparently only
> files needed are the megt*.img ones too.
> already discovered, it goes southward from 00*n* to 44s and for northward
> is 44n to 88n. Oh, and watch out for those missing 2 degrees at the poles.
> I finally worked that out for a orthographic rendering which pieces all
> the tiles together for a spherical image map I used afterward. Polar tiles
> were shifted up or down by about 6% of a unit, for my unit-sized tiles
> which are 30 X 30 degrees each.
There is no problem with the interpretion of the tiles and their formats.
I have been using a self-written program to convert the 4x4 tile map
row-by-row into two full-sized and scaled-down grayscale PNGs.
See: http://www.cip.physik.uni-muenchen.de/~wwieser/render/img/mars/
It's just that I got a bit confused about the coordinate system on
(NASA) so I was not sure if everybody was using the same zero
meridian. But from searching the net and comparing the names of the
locations (Isidis Planitia, etc) to pixel locations on the spherical
projections, I now think I can correctly locate the landing sites on
the map.
> P.S.
> the wrapped ends. Using the start/end wrapping point to judge where the
> planet surface features are when the camera is directly along -z (or +x if
> not rotating away from the 0 degree longitudinal line) it makes it a
> little tricky if that line isn't at zero.
I did not come across that problem. I measured several outstanding points
(in maris vallineris, a volcano) and the topo map matches the color map.
The yellow-blue image map I was using before needed such hand-tweaking
but not the current one.
Wolfgang
Date: 24 Jan 2004 13:32:24
Message: <4012ba38$1@news.povray.org>
news:40127b1e@news.povray.org...
> the map.
Yeah, I noticed ESA and NASA seemed to be switching it around. You have a
great web page about rendering Mars with POV-Ray. Does your custom
conversion have more than 8 bits for elevation? I searched around but the
grayscale maps or other elevation maps I find don't seem to say much about
it.
Bob H.
