POV-Ray : Newsgroups : povray.binaries.images : gallery - gallery9_lowkb.jpg [0/1] Server Time
13 Apr 2026 22:29:25 EDT (-0400)
  gallery - gallery9_lowkb.jpg [0/1] (Message 15 to 24 of 34)
Subject: Re: gallery - gallery9_lowkb.jpg [1/1]
Date: 30 Mar 2001 11:27:52
Message: <MPG.152ed309d63706299896a5@news.povray.org>
In article <gfp8ctg1qffjln61frtschfo6r2sublis5@4ax.com>,
dav### [at] blueyondercouk says...
> Any chance of an animation taking us on a tour of this display area?
Would take a BIT too long to render...and wouldn't be very interesting in
its current state (the room behind the bend is very much empty) ;-)
Date: 30 Mar 2001 11:29:53
Message: <MPG.152ed381be0abf849896a6@news.povray.org>
In article <3AC3AC1F.7B89E128@gmx.de>, chr### [at] gmxde says...
> Not necessarily if you thereby avoid a lot of additional light sources.  I
> would definitely try it.
Ok, i'll try it.
Somebody has good rad. settings? I havn't done anything with MegaPovs
radiosity yet.
Lutz-Peter
Date: 30 Mar 2001 11:42:32
Message: <3AC4B820.9079498C@inapg.inra.fr>
> radiosity yet.
Below is what I use for most of my radiosity images.
Use HQOn=0 for tests (fast), HQOn=1 for final render and HQOn=2 if you really
have some trouble with radiosity artefacts (may not be enough though).
Turn all "ambient" to 0 and all "diffuse" to 1 for regular objects. You may have
to tweak the light intensities, color intensities, light color and sky color to
get proper effects.
G.
#declare HQOn=1;
#declare QR=1;
global_settings{
        assumed_gamma 1
        max_trace_level 15
        #if (QR=1)
            ini_option "+QR"
        radiosity{
            pretrace_start 1
            pretrace_end   1
            #switch (HQOn)
                #case (0)
                    count 100 error_bound 1
                #break
                #case (1)
                    count 800 error_bound 0.02
                #break
                #case (2)
                    count 1600 error_bound 0.02
                #break
            nearest_count 4
            recursion_limit 1
            low_error_factor 1
            gray_threshold 0
            minimum_reuse 0.015
            brightness 2
            adc_bailout 0.01/2
            normal on
http://www.oyonale.com
Graphic experiments
Pov-ray gallery
Date: 30 Mar 2001 11:48:16
Message: <3AC4B8D0.47B58239@gmx.de>
>             brightness 2
Are you sure about that?
brightness 1 is a fairly universal value that should be realistic in most
cases.  If you change an existing scene for using radiosity, it's often
even useful to use lower values.
Date: 30 Mar 2001 12:25:05
Message: <3ac4c171@news.povray.org>
In the room WIP I posted a while ago which only has one window I have to use
a brightness of above 3 to be able to see anything except blackness, it all
depends on how much of the scene is actually lit by direct light. I
regularly use a brightness of about 2 though.
Kev
http://perso.libertysurf.co.uk/kevin.ellis
Date: 30 Mar 2001 12:29:30
Message: <MPG.152ee17af1ee8c6e9896a7@news.povray.org>
In article <3AC4B8D0.47B58239@gmx.de>, chr### [at] gmxde says...
I had to set it so 0.3, at 1 everything is white... maybe because I use
colors > rgb 1.
But theres another problem: 0 PPS even with HQOn=0 :-(
Only if I switch EVERYTHING off (reflections, isosurfaces, arealights
etc), I can get a preview.
Lutz-Peter
Date: 30 Mar 2001 12:37:59
Message: <3AC4C51E.A1AB420E@inapg.inra.fr>
Christoph Hormann wrote:
> >             brightness 2
Well, it happens that I use brightness 2 in scenes where I have direct
photographic references (I just cut and pasted the settings here), so the
choice is only dictated by the similarity between the "real" scene and its
rendered version (I'm not talking about the Cornell box here, but of complex,
real-life pictures). These images also require extremely bright lights.
But you're right,  brightness level depends on the scene. My "Contrast" image
used 1.2 for instance (but it was not based upon a photography). I don't
remember using values lower than 1. It's more an aesthetic choice than a
technical one IMHO.
G.
Graphic experiments
Pov-ray gallery
Date: 30 Mar 2001 12:40:12
Message: <3AC4C4FC.18634B71@gmx.de>
It's usually better to increase the ambient finish of the light emitting
objects than to increase brightness.  While the fist only brings more
light in the scene, the brightness parameter strongly influences the
colors of the scene in an often unrealistic way.
Date: 30 Mar 2001 12:46:04
Message: <3AC4C65C.5F516FD9@gmx.de>
> colors > rgb 1.
As Gilles said, all finishes need to be changed, if you want to avoid
adapting the colors, you can try to play with the diffuse finish
component.
Be sure to turn off all additional light sources (just leave the sun
light).  Of course reflections and isosurfaces slow down things too, but
at least the pretrace should run with 'visible speed'.
Date: 30 Mar 2001 12:50:03
Message: <3AC4C7F3.C474CF1@inapg.inra.fr>
> colors > rgb 1.
Strange. I use HQOn=0 on my old, slow Pentium 133. Note that scenes that use
these settings :
- have only one light source
- all objects have ambient = 0
- have few reflections
- have few (or none !) objects with ior
- colors are normal (below rgb 1)
I hope this helps, but as I design images around radiosity, I can't say that
these settings are universal.
G.
Graphic experiments
Pov-ray gallery
