While watching a documentation about Zanzibar, I noticed a short beach
scene. In the foreground the sea water was invisible completely. Only
caustics indicated that there was water above the ground. So I played a
little bit with photons to model this observation.
I used and modified slightly some resources given by others:
Water by Jaime Vives Piqueres, sea material by Sean Day (IRTC June 2005,
wreck), hight\_field by Roman Reiner (IRTC February 2006, Firelake),
palms from Tomtree by Tom Aust and Genady Obukhov (nowadays available
via the wayback machine only) and Xfrog.
The dugout trimaran I dugged out off a cylinder in Wings 3D.
Enjoy and best regards
Michael
Download 'zanzibarbeach_1920.jpg' (679 KB)
Preview of image 'zanzibarbeach_1920.jpg'
Op 25/10/2021 om 08:49 schreef MichaelJF:
> Michael
Ah, yes! That is one of those todo things I have kept on the backburner
for an indefinite time indeed. This is very well done Michael.
> Michael
Looks good - and warm. Starting to feel winter's dark approach here.
Bill P.
Am 25.10.2021 um 10:16 schrieb Thomas de Groot:
Thanks for your praise! If you really will go for this task in the
future: I had to use a very fine spacing to get more or less realistic
reflective caustics at the boats, the refractive caustics at the sea
bottom are cheaper. I ended up with some 8 hours of Photon-collection
and a photon file of about 16 GB with 9 GB peak memory use during the
photon collection. In the final rendering the peak memory use was 23 GB RAM.
Best regards
Michael
Am 25.10.2021 um 12:25 schrieb William F Pokorny:
>> Michael
> Bill P.
Thanks for your praise too! And yes, 6 degrees south would be better now
than 50 to the north, where I live.
Best regards
Michael
Op 26-10-2021 om 09:58 schreef MichaelJF:
Hm, yes, I can understand that. I had not realised it however.
> RAM.
Right. That will mean some night's hours work for my machine. ;-)
It makes me think that my crystal needs better photons too...
Thanks for the clarification!
A beauty! It looks photo-real, especially the lighting contrast (the dark
shadows under the trees look exactly like I would imagine, with my eyes being
more accustomed to the beach's relative brightness.) And the water caustics are
great! Ditto the overall composition.
My only nit-pic: The bits of foam(?) on the water look like they need some ...
dimensionality? Or something to give the tiny foam 'bubbles' more of an
interaction with the lighting. Like tiny glints, perhaps. Or smaller/granier
break-ups re: the warp/turbulence that's used (via the omega value? I've
forgotten which parameter to use for that.) Or perhaps even as separate very
short height_fields(!)
Otherwise, don't touch anything, as it's *really* stunning! This image is going
into my 'best POV-ray renders' folder. Thanks for sharing.
Hi Michael,
Wow, this is really great. I looked at it on my phone last night when I was
bored and just opened the image without reading the description fully. My first
thought was you had posted a photo of what you wanted to achieve in POV then I
read the description..
On a bigger screen today I can see that it is a render but still very
impressive.
Photons have always been a problem for me (mainly due to the fact it takes so
long to gather them then if I don't like the output you have wait again so I
normally give up.
Unless you tweaked my wreck texture the only criticism you have got so far about
the foam is my fault and one I wasn't happy with in the wreck image but couldn't
improve on ;-).
Sean
Am 03.11.2021 um 10:24 schrieb s.day:
> Hi Michael,
> impressive.
> normally give up.
> improve on ;-).
> Sean
Many thanks to you and Kenneth. Please apologize the delay, I visited my
sister living some 600 km to the north of me (East Frisia) and was
occupied with family issues the last days.
I was not sure about the foam. In a moment I thought to comment it out,
in another I liked it. Finally I decided to keep it. It is not perfect,
but a very good approximation IMO.
Best regards,
Michael
MichaelJF <fri### [at] t-online de> wrote:
> So I played a
I am interested in how the Caustics effect was done.
Would it be possible to publish or send me the corresponding code part ?
