POV-Ray : Newsgroups : povray.binaries.images : Granite_21 - the final macro Server Time
26 Jun 2026 19:41:55 EDT (-0400)
  Granite_21 - the final macro (Message 21 to 30 of 30)
Subject: Re: Granite_21 - the final macro
Date: 21 Sep 2021 15:45:00
Message: <web.614a357db21f010c1f9dae3025979125@news.povray.org>
"Samuel B." <stb### [at] hotmailcom> wrote:
All my attempts have failed. There is probably a basic solution
> > > and I'm just over-complicating things...
Doesn't seem that way.  Having never done any of this type of work, in my
ignorance, I believe I was initially suggesting an overly simplistic approach.
OK, here's the deal.
.... a family of lattice planes is determined by three integers h, k, and
ℓ, the Miller indices. They are written (hkℓ), and denote the family
of planes orthogonal to hb1 + kb2 +lb3, where bi are the basis of the reciprocal
lattice vectors....
from which I can see that the key part is incorporated by reference at
https://en.wikipedia.org/wiki/Reciprocal_lattice
The reciprocal lattice is the set of all vectors Gm, that are wavevectors of
plane waves in the Fourier series of a spatial function which periodicity is the
same as that of a direct lattice Rn
So:
The guy you want to talk to is Michael Joseph Waters - a postdoctoral researcher
in X-ray crystallography at Northwestern.  Nice guy - we emailed back and forth
a while back.
"NiO is a odd material, it's antiferromagnetic so there are alternating planes
of spin up and spin down electrons. If you learn Miller indices, these are on
(111) planes."
Also:
https://ciderware.blogspot.com/2016/08/getting-isosurfaces-from-data-grid-into.html
Find his contact info here:
https://mtd.mccormick.northwestern.edu/group/
He's likely a busy guy, but he may have some advice on how to approach
unraveling this all.  I'm guessing it might take a 3rd party software package -
or maybe not, if we can use the FFT that I coded up a while back.
Date: 21 Sep 2021 19:15:00
Message: <web.614a66a9b21f010ccb705ca46e741498@news.povray.org>
> Not sure if this might help: http://jcrystal.com/products/winwulff/
> I am still thinking how this would help. Fifty five years ago (!) when I
> was introduced to the use of a Wulff net, you were given the model of a
> crystal with the task to translate its features onto the net,
> determining the symmetry planes, the axes of rotation, measuring the
> angles between faces, etc. I suppose the difficulty here is to do the
> opposite, or am I wrong?
That might help, but I'm not sure. Ideally, I'd like to perform all the
necessary conversions in POV-Ray. I'll check that out and see if it shines a
light on the subject.
Sam
Date: 21 Sep 2021 19:40:00
Message: <web.614a6c5fb21f010ccb705ca46e741498@news.povray.org>
> from: https://en.wikipedia.org/wiki/Miller_index
> lattice vectors....
Thank for the time you took to research this! It's indeed probable that the
reciprocal lattice is the way forward. I'll read through the articles and try to
glean some useful info from them.
Unfortunately, I've got two things holding me back: my inability to parse
mathematical formulas due to only being self-taught; and my inconsistent mental
energy. Most people suffer from the latter, but it seems I am particularly
affected by such fluctuations :S
> So:
> a while back.
> (111) planes."
I'm intrigued by that. What sorts of special properties does Nickle(II) oxide
possess, I wonder?
> Also:
FFT=fast Fourier transform? What have you been using it for? (Sorry for being
out of the loop, haha.)
And I'd hate to bother him to pick his brain, but I do know some people like to
talk. Heck, maybe the creator of KrystalShaper would be willing to share the
code he used to convert HKL indices to planes.
Thanks again, and I will be looking into the matter further. I'm betting the
conversions for various crystal symmetries are actually super easy to
implement...
Sam
Date: 21 Sep 2021 22:00:00
Message: <web.614a8d3bb21f010c1f9dae3025979125@news.povray.org>
I'm mostly self-taught as well.  Let me know what you need to know, and I'm
always happy to try to explain.
> possess, I wonder?
"Exploring the interplay between electronic doping, magnetism, and Ni diffusion
in NiO from first principles."
NiO and NiO solid solutions are typically the first passivating oxides to form
during the corrosion of Ni-rich alloys. Ni diffusion from the alloy interface,
through the oxide, to the exposed surface is the rate-limiting kinetic process
for continued oxidation. From first principles, we calculate the effects of
magnetic order and electronic doping on the minimum energy diffusion pathways.
We elucidate the origin of the diffusion barrier dependencies by assessing
changes in the defect states and chemical bonding along the diffusion paths. Our
work highlights the complexity of diffusion in even structural simply but
strongly correlated oxides with practical recommendations for corrosion
resistance that may be transferable to diffusion-mediated redox processes in
energy storage materials.
http://news.povray.org/povray.binaries.images/thread/%3C58bfe702%241%40news.povray.org%3E/
http://news.povray.org/povray.binaries.images/thread/%3Cweb.58bd5ea376ca50b7c437ac910%40news.povray.org%3E/?ttop=435711
&toff=550
I haven't had much of a chance to really use it for anything.
It was suggested that I might be able to use it for my gear tooth counting
project:
http://news.povray.org/povray.general/thread/%3C59371017%241%40news.povray.org%3E/
http://news.povray.org/povray.binaries.images/thread/%3C593bd19f%40news.povray.org%3E/
They are supported by millions of our tax dollars.  If he wants to answer your
email, he will.  If he doesn't, then you made a reasonable request, and you can
try elsewhere.  And really, he seemed very cool and happy to talk about his
research, and explain some of the basics that I was ignorant of.  Politely
asking for some expert assistance with one thing isn't really "bothering."
> implement...
Probably.  Hopefully we'll find out.
Date: 23 Sep 2021 19:45:00
Message: <web.614d1063b21f010ccb705ca46e741498@news.povray.org>
> > (...) my inability to parse mathematical formulas due to only being self-taught
I might just take you up on that. I know the rules of PEMDAS, and I know
functions and their usages in programming languages, but when I see formulas on
Wikipedia or elsewhere I see many symbols representing unfamiliar equations. I
know it's only a matter of searching and finding, but I'm certain these things
are more easily grokked by the formally-trained.
> > possess, I wonder?
Not sure what this means, but am I jumping to conclusions by thinking this means
NiO-rich alloys corrode more easily from the 'sides'? Similar to how a
stratified bedrock can be more easily penetrated by weathering forces attacking
between its layers?
11
> &toff=550
> project:
Very interesting!
After reading that I was trying to figure out a better way to count gear teeth,
but was drawing a blank. Somebody in one of those threads mentioned (to heavily
paraphrase) performing a polar-to-cartesian transformation on an image of a gear
and evaluating that (probably by tracing rays horizontally and incrementing a
counter). I wonder how that would work out?
And I think you mentioned possibly using an FFT to approximate 3D geometry using
isosurfaces. I do believe there is some potential there.
I heard that many researchers are willing to share their research. In fact, it's
been said if you can't find a paper for free on sci-hub, then maybe you should
contact the author(s) directly. I love the fact that people are willing to share
their findings, regardless of profit.
Sam
Date: 23 Sep 2021 20:20:00
Message: <web.614d1928b21f010c1f9dae3025979125@news.povray.org>
Correct on both counts, but I've already done a lot of that searching and
finding, and I've managed to grok a fair amount.  Might as well pull you along
the learning curve with me.  :D
Nope.   If you read it again, it means that an oxide skin/film/crust forms, and
then metallic nickel has to diffuse through that to get oxidized on the surface
of that crust.
If it's published, it's already been paid for.  I had to do some backflips to
find copies of MY OWN research that got published through ACS.  What a scam to
the taxpayer.
Date: 25 Sep 2021 17:50:00
Message: <web.614f987ab21f010ccb705ca46e741498@news.povray.org>
> the taxpayer.
That's messed up! Didn't you have a preprint version on hand? Or were you trying
to obtain a peer-reviewed version?
Sam
Date: 25 Sep 2021 20:10:00
Message: <web.614fba05b21f010c1f9dae3025979125@news.povray.org>
> > the taxpayer.
> Sam
Well, y'know - it's a long story.
But I lost the digital copies I had, and hard copies of nearly everything were
gone too.
But thanks to the interwebs, I got around any of the stupid paywall sites and
got the paper (somewhere) and the supporting information.
https://pubs.acs.org/doi/10.1021/jo0207022
I even found out that it got referenced in Greene & Wuts.  :)
https://www.wiley.com/en-us/Greene%27s+Protective+Groups+in+Organic+Synthesis%2C+5th+Edition-p-9781118057483
Date: 29 Dec 2021 06:05:00
Message: <web.61cc408eb21f010c9bd2e6b8f7885d08@news.povray.org>
> The final version of the Granite_21 macro package can be found in
> p.b.scene-files under the same header.
> The image here illustrates, from the start, the principal rule of the
> macro, written on the wall!
> Enjoy!
> Thomas
Make it part of a DLC
Date: 31 Dec 2021 02:28:40
Message: <61ceb128$1@news.povray.org>
Op 29/12/2021 om 12:03 schreef Saul F. Luizaga:
>> Enjoy!
>> Thomas
I have no idea about what this entails, frankly.  :-)
