POV-Ray : Newsgroups : povray.binaries.images : Proof of Concept: Cutoff Distance for Fading Lights Server Time
26 Oct 2025 20:19:58 EDT (-0400)
  Proof of Concept: Cutoff Distance for Fading Lights (Message 1 to 10 of 15)
Subject: Proof of Concept: Cutoff Distance for Fading Lights
Date: 28 Jan 2014 21:19:27
Message: <52e8652f@news.povray.org>
A scene with 1000 randomly placed light sources with distance-dependent
attenuation (fade_power, fade_distance).
First image: POV-Ray 3.7, render time 73s.
Second image: experimental patch, render time 9s.
For each light source, the patch automatically computes a cutoff
distance based on light source brightness, fade parameters, and a global
threshold (currently this is the global adc_bailout setting). Beyond
this distance, the lights source is simply ignored.
(As an alternative, the patch also allows for manually specifying the
cutoff distance, but that's not used in this scene.)
Download 'fade_light_pov37.png' (293 KB) Download 'fade_light_upov.png' (281 KB)
Preview of image 'fade_light_pov37.png'
Preview of image 'fade_light_upov.png'
Subject: Re: Proof of Concept: Cutoff Distance for Fading Lights
Date: 28 Jan 2014 21:33:10
Message: <52e86866$1@news.povray.org>
That was fast! I can only stand in awe of your achievements.
John
Protect the Earth
It was not given to you by your parents
You hold it in trust for your children
Date: 29 Jan 2014 03:27:07
Message: <52e8bb5b$1@news.povray.org>
I think this is exactly what the original supplicant was asking for.
That is a nice addition to our favourite program.
Date: 29 Jan 2014 03:38:56
Message: <52e8be20@news.povray.org>
A notable result.
Please, promote the patch to release!
Paolo
Date: 29 Jan 2014 13:25:00
Message: <web.52e946e581045008ddb0c31e0@news.povray.org>
Hey, that looks pretty nice there; it reminds me of the MegaPov Glows a bit. ;)
Ian
Date: 29 Jan 2014 15:52:30
Message: <52e96a0e@news.povray.org>
Am 29.01.2014 19:22, schrieb [GDS|Entropy]:
> Ian
No, just a bunch of ordinary lights with matching looks_like emissive
spheres, placed neatly on the floor. Place them somewhere in mid-air and
most of the visual magic is gone.
Date: 29 Jan 2014 20:30:04
Message: <52e9ab1c$1@news.povray.org>
Very nice, thank you! It sounds strangely familiar ;)
Date: 30 Jan 2014 14:30:00
Message: <web.52eaa6fe810450087579b7ac0@news.povray.org>
Cool work, Christoph!
There's something odd going on between the two images you posted: the spheres in
the UberPOV version are noticeably darker, but the plane is not. Did you change
the spheres' material settings between renders?
Sam
Date: 31 Jan 2014 15:23:37
Message: <52ec0649@news.povray.org>
Am 30.01.2014 20:24, schrieb Samuel Benge:
You mean the diffuse spheres, right?
No, that's not odd at all:
- The darkening of the spheres of course comes from the fact that even
though the cut-off light sources don't contribute much brightness
individually, they still do contribute a good deal in total.
- The (apparent) non-darkening of the plane comes from the fact that
here the contribution of the individual light sources isn't just
affected by the inverse-square distance-based falloff, but also the
falloff due to the angle of incidence.
If you'd use a "brilliance 0" finish on the plane (causing diffuse
brightness to be entirely independent of the angle of incidence), the
darkening effect would be just as visible on the plane as it is on the
spheres.
Date: 1 Feb 2014 04:20:01
Message: <web.52ecbc2a810450089805db690@news.povray.org>
How does the patch deal with radiosity? does it still provide an improvement?
any order of magnitude for it?
