POV-Ray : Newsgroups : povray.binaries.images : Artifacts in scattering media Server Time
29 Jul 2024 22:32:02 EDT (-0400)
  Artifacts in scattering media (Message 1 to 10 of 11)
Subject: Artifacts in scattering media
Date: 18 Sep 2013 09:45:01
Message: <web.5239ae4fbc5e76cf314aa6840@news.povray.org>
So I made this image using scattering media to get light "rays" spilling out of
a broken skull.
I am getting artifacts in the media rendering that I don't know how to
handle...I've marked them out with a red box in the attached image. Any ideas?
I've tried:
Upping the media sample min/max a lot.
Increasing the confidence.
Decreasing the variance.
Various combinations of the above.
Messing around with intervals.
Here's the code:
#version 3.7;
#include "glass.inc"
#include "metals.inc"
#include "stones.inc"
#include "skies.inc"
#include "woods.inc"
#include "golds.inc"
#include "textures.inc"
#include "transforms.inc"
#include "skullmodel_POV_geom.inc"
global_settings
  assumed_gamma 2.2
  ambient_light 1
#default{ finish{ ambient 0.1 diffuse 0.9 }}
  orthographic
  location <0,0,200>     // position & direction of view
  look_at  <0,0,0>
  right    x*24.5
  up       y*14.5
light_source {
  0*x                  // light's position (translated below)
  color rgb <1,1,1>    // light's color
  translate <3, 2.25, 400>
  media_interaction off
light_source {
  translate <0, 0, 10>
#declare Min = min_extent(skull_01___Default_);
#declare Max = max_extent(skull_01___Default_);
#declare ScaleFactor = max(Max.x - Min.x, max(Max.y - Min.y, Max.z - Min.z));
#declare skull_ =
object{
  skull_01___Default_
  Center_Trans(skull_01___Default_, x)
  Center_Trans(skull_01___Default_, y)
  Center_Trans(skull_01___Default_, z)
  scale 2/ScaleFactor
#declare iso_ =
isosurface {
  function{
    x-f_snoise3d(x, y, z)*5
  contained_by { box {<-10,-10,-10>, <10, 10, 10> } }
  accuracy 0.003
intersection {
  object { skull_ scale 5.0 }
  object { iso_ }
      color White
    finish {
      specular 0
      roughness 0.09632328
      ambient 0.1
      diffuse 0.7
      reflection 0.2
  translate 10*z
sphere {
  <0, 0, 10>, 25
    pigment { rgbf 1 }
    finish { ambient 0 }
  interior {
    media {
      scattering { 4, rgb 1 }
      density {
        spherical
        density_map {
          [0 rgb 0.0]
          [1 rgb 0.2]
        scale 10
        translate 10*z
      samples 40, 400
  hollow on
Download 'skullthingie02.jpg' (129 KB)
Preview of image 'skullthingie02.jpg'
Subject: Re: Artifacts in scattering media
Date: 18 Sep 2013 10:16:27
Message: <5239b5bb@news.povray.org>
On 18-9-2013 15:44, jceddy wrote:
>        samples 40, 400
By default, intervals is 1 and method is 3 in version 3.7. Accordingly,
samples needs only /one/ parameter, the second one being ignored.
instead of 40, try samples 100 or higher. Render time will not be too
much influenced.
Date: 18 Sep 2013 11:15:01
Message: <web.5239c34c5cbaed3314aa6840@news.povray.org>
> much influenced.
Thanks for the tip on only specifying one parameter for samples.
I increased it to 400 and still get that artifact, although in general the media
effect looks smoother.  I pushed it up way higher and am doing another test
render, although it is progressing much more slowly.
Incidentally, I ran the same code in v 3.6 just to test and have the same
artifact there.
Date: 18 Sep 2013 12:50:01
Message: <web.5239d9865cbaed3314aa6840@news.povray.org>
The artifact remains after pushing the samples up to 4000, and it took an hour
and a half to render.
I don't think it's something that tweaking samples will fix, but I'm at a loss
to figure out what's causing it.
I attached the file from the 4000 samples run.
Download 'skullthing4000.png' (88 KB)
Preview of image 'skullthing4000.png'
Date: 18 Sep 2013 14:20:01
Message: <web.5239ee6e5cbaed3314aa6840@news.povray.org>
This might be a red herring...I wonder if the artifact is actually due to some
interaction with the isosurface in CSG.
Date: 18 Sep 2013 15:04:47
Message: <5239f94f$1@news.povray.org>
maybe not such a red herring ... noticed in your example that you didn't
set a max_gradient value so it's 1.1 (default) ... was/is there an
warning message ... if so bump it up some until it goes away. btw: more
render time is the cost here
Date: 18 Sep 2013 15:50:01
Message: <web.523a037d5cbaed3314aa6840@news.povray.org>
No, I didn't get a max_gradient warning, but I'll bump it up and re-try anyway,
to see if it helps.
I might try to do it without the isosurface, as well.
Date: 18 Sep 2013 17:05:01
Message: <web.523a14a15cbaed3314aa6840@news.povray.org>
That was it...I cranked max_gradient on the isosurface up to 5 and the artifacts
went away.
I'm still tweaking the samples value for the media to find the threshold where
"normal" media artifacts go away, but it's somewhere south of 400 for this
scene. ;)
Thanks for the suggestion!
Date: 18 Sep 2013 20:55:00
Message: <web.523a4a7f5cbaed3306548240@news.povray.org>
> to see if it helps.
See "Isosurface: max_gradient warning?" in p.beta-test.
Date: 24 Sep 2013 12:10:00
Message: <web.5241b8675cbaed3314aa6840@news.povray.org>
Could max_gradient being too low also cause issues when doing CSG between and
isosurface and a solid mesh object?
