POV-Ray : Newsgroups : povray.binaries.images : Domenator II, the sequel Server Time
27 Oct 2025 19:24:17 EDT (-0400)
  Domenator II, the sequel (Message 1 to 10 of 19)
Subject: Domenator II, the sequel
Date: 21 Apr 2012 02:13:34
Message: <4f92500e@news.povray.org>
Here are a few images to illustrate the versatility of the Domenator utility
which is a 3D shape generator using OpenGL (used to be a Moray plug-in).
As you can see actual cathedral/church/mosque may be modeled with Domenator
(that was my start point), but you can also model many very different shapes
(sword's blade, umbrella, ice-cream, futuristic building, etc.).
These images are not very nice because I wanted to show Domes and nothing
else (no background, no other objects (but the bottom of the cage which is a
simple cylinder), not a great deal of work on material .).
You can find the exe file in the binaries.utilities forum.
This is a beta-version, so there is room for improvement, thanks to you for
pointing me bugs and desired features.
If some of you are interested, I will also transform my other Moray plug-ins
into stand alone programs (including SeaShell, Knots, Tube .)
Best regards.
Futuristic Building, Waste Paper basket, Asian Hat, Umbrella and Sword's
Blades are made of only one dome.
Rusty Bird's Cage is made of one dome and one cylinder.
Saviour Dome is made of two domes (the main body and the top cone). I also
included a view of this dome "in situ", with a bit more of work.
La Defense Conference Hall is made of two domes (one for the concrete part
and one for the glass part (the very same dome but with no window)).
Ice Cream is made of two domes, one for the cornet and one for the actual
ice-cream (Vanilla - Fudge).
Staring from the Darth Vader helmet, you can model dinner plates ;-)
Sorry for my lousy English ;((.
Download 'Domenator.jpg' (202 KB) Download 'saviour.jpg' (24 KB)
Preview of image 'Domenator.jpg'
Preview of image 'saviour.jpg'
Subject: Re: Domenator II, the sequel
Date: 21 Apr 2012 03:03:05
Message: <4f925ba9$1@news.povray.org>
Philippe! How good to see you back here! Welcome!
Excellent idea to have Domenator as a stand alone utility. I have great
use for it (Gancaloon of course) but I have been unsure about whether to
reinstall Moray on my new PC or not. It is/was one of my favourite plugins.
Your other plugins would be welcomed too, especially Seashell I think.
Date: 21 Apr 2012 04:21:25
Message: <4f926e05$1@news.povray.org>
Hi Thomas,
Thanks for your kinds comments.
You will be able to re-create the domes you have created with Moray (just
let the new parameters to their default value, but I hope you will enjoy
them).
There is only one exception: the inverse check box which was equivalent to a
negative height+scale.
Future developpment: use a mesh2 rather than a mesh and use interior texture
Philippe
PS : there is no documentation so far so, don't hesitate to ask ...
Philippe
4f925ba9$1@news.povray.org...
> plugins.
> Thomas
Date: 21 Apr 2012 07:17:33
Message: <4f92974d$1@news.povray.org>
On 21-4-2012 10:21, Philippe Gibone wrote:
> Hi Thomas,
> them).
> Philippe
Well for a start, I am stuck with the msvcr100d.dll. Downloaded it and
put it in Windows\System32  Windows\SysWOW64 and in the Domenator
directory as indicated by the site, and restarted the PC. However, I get
an error message telling me that the dll is missing from my computer.
Checked this with CMD regsvr32 and got the answer that the module may
not be compatible with the version of windows I am running.
Using windows7 x64.
Date: 21 Apr 2012 07:53:47
Message: <4f929fcb$1@news.povray.org>
a dependency to this dll is usually a build problem of
the program. It should be built with release configuration
to publish it. Then it will run on any system that has the
VC++ 2010 runtime environment installed (which is usually
present on newer systems but you can also download it
from the website of microsoft).
Also, manually copying msvcr* dlls to windows system directory
may not work on newer version of Windows, they have some protection
against getting corrupted and the simple folder view presented by
explorer is an illusion hiding all the side-by-side versioning issues
(you could still try to place the dll next to the exe, note that you
need the correct bitness depending on whether the application is
compiled for x86 or x64).
Date: 21 Apr 2012 10:02:38
Message: <4f92bdfe$1@news.povray.org>
Well, that did not work.
Date: 22 Apr 2012 04:45:12
Message: <4f93c518$1@news.povray.org>
With the sequel of the sequel: glut32.dll is missing.
I have couple of copies (different dates and sizes) of this for the
ancient TesselSphere, Terragen2, and Silo2, in their respective
directories. What should I do?
Date: 22 Apr 2012 13:32:13
Message: <4f94409d@news.povray.org>
Hi Thomas,
I'm really sorry for that, OpenGL seems to be a real mess, this is my first
programm using it, it may be the last.
The DLL on my computer are :
glu32.dll  22/08/2001  21:00           116 736
glut32.dll 27/03/2005  12:10           483 460
Hope that helps
Philippe
Philippe
4f93c518$1@news.povray.org...
> Thomas
Date: 23 Apr 2012 03:14:06
Message: <4f95013e$1@news.povray.org>
On 22-4-2012 19:32, Philippe Gibone wrote:
> Hi Thomas,
> Hope that helps
It does, Philippe, thanks. I just copied my youngest glut32.ddl from
Silo2 to the Domenator directory. It works now. Going to play ;-)
...later: Works well and hugely enjoyable. A couple of questions:
(1) Not sure what Translation Z does. Now it shears the dome, allowing
an inside view. Is that correct?
(2) Materials: How are they invoked?
(3) Mesh2{} would be great eventually, including the csg objects.
Date: 23 Apr 2012 11:53:43
Message: <4f957b07@news.povray.org>
Hi Thomas,
Very good news.
> (1) Not sure what Translation Z does. Now it shears the dome, allowing  an
It is a scaling along the z-axis (in OpenGL and Moray, which happens to be
the y-axis in POV-Ray) this scaling is done before the struts and spheres
are created (it has no particular effect on the "faces").
I enclosed an image of a Dome with no scaling (on the left), with pov-ray
z-scaling (in the middle) and with the Dome z-scaling (on the right)
I choose materials rather than textures because when you want to use a
texture, you just have to write :
#declare Mat1 = {texture {myFavoriteTexture}}
And you have turn your favorite texture into a material.
If you're not the only one to be interested in I will (if you're the only
one, it will take a little bit more of time ;-)).
Regards
Philippe
Philippe
4f95013e$1@news.povray.org...
>> Hi Thomas,
>> first
>> Hope that helps
> Thomas
Download 'ScaleZ.jpg' (100 KB)
Preview of image 'ScaleZ.jpg'
