POV-Ray : Newsgroups : povray.binaries.images : Finally, the rings are visible, but... Server Time
29 Jul 2026 01:36:15 EDT (-0400)
  Finally, the rings are visible, but... (Message 3 to 12 of 12)
<<< Previous 2 Messages Goto Initial 10 Messages
Subject: Re: Finally, the rings are visible, but...
Date: 29 Nov 2009 18:13:07
Message: <4b130003@news.povray.org>
High!
Reactor wrote:
> They cannot cast a shadow, if they do not absorb light (since the extinction is
> zero and there is no absorption).  You can either fake a shadow, by placing
> another ring with the no_image keyword and allow it to cast a shadow, or you
> could adjust the media to make it do both.
> I am not sure what you mean by invisible rings that cast a shadow - they don't
> show up against the planet or space in lit areas, but the shadow does?  Also,
> increasing all of the density_maps values is equivalent to increasing the
> scattering color (second parameter).  Can you post some of the code?
Whenever I add even the slightest absorption media and/or extinction,
the rings simply disappear - but strangely, only now cast a shadow on
the planet!
Here is the code:
difference // rings
   cylinder
     <0, -0.11, 0>/sc, <0, 0.1, 0>/sc, 140390/sc
   cylinder
     <0, -0.12, 0>/sc, <0, 0.11, 0>/sc, 74510/sc
   /* cylinder // unlit side!
     <0, -0.15, 0>/sc, <0, -0.1, 0>/sc, 150000/sc
     texture
       cylindrical
       texture_map
         [0                                   Ring_UnlitSide_Map_1_to_255 ]
         [255*(((140390-74510)/140390)/1500)  Ring_UnlitSide_Map_256_to_510]
         [510*(((140390-74510)/140390)/1500)
Ring_UnlitSide_Map_511_to_765]
         [765*(((140390-74510)/140390)/1500)
Ring_UnlitSide_Map_766_to_1020]
         [1020*(((140390-74510)/140390)/1500)
Ring_UnlitSide_Map_1021_to_1275]
         [1275*(((140390-74510)/140390)/1500)
Ring_UnlitSide_Map_1276_to_1500]
       scale 140390/sc
   #if (lores)
     texture // low resolution texture: 255 entries in ring color map
       pigment
         cylindrical
         color_map
           #declare a=0;
           #while (a<255)
             #declare c=eval_pigment(Saturn_Rings_Colors,
<509/510-a/255, 0.5, 0>);
             #declare f=eval_pigment(Saturn_Rings_Transparency,
             [a*(((140390-74510)/140390)/255) rgb c filter f.gray]
             #declare a=a+1;
         scale 140390/sc
       finish { F_Saturn_Rings }
   #else
     hollow
     pigment { rgbt 1 }
     interior
       media
         scattering
           5, 1
           eccentricity -0.4
           extinction 0
         // absorption 0.
         density
           cylindrical
           /* density_map
             [0                                   Ring_Color_Map_1_to_255]
             [255*(((140390-74510)/140390)/1500)  Ring_Color_Map_256_to_510]
Ring_Color_Map_511_to_765]
Ring_Color_Map_766_to_1020]
Ring_Color_Map_1021_to_1275]
Ring_Color_Map_1276_to_1500]
           density_map // preliminary low-res version
             #declare a=0;
             #while (a<255)
               [a*(((140390-74510)/140390)/255) rgb c*3000 /* filter
f.gray */ ]
               #declare a=a+1;
            scale 140390/sc
   SetAxis(bodies[72][10], bodies[72][11])
   translate Pos_Saturn/sc
See you in Khyberspace!
Yadgar
Date: 30 Nov 2009 00:40:00
Message: <web.4b1359eaff01319391f52710@news.povray.org>
=?ISO-8859-1?Q?J=F6rg_=27Yadgar=27_Bleimann?= <yaz### [at] gmxde> wrote:
> High!
> the planet!
> Here is the code:
That code really wasn't quite what I'd expected.  It lacked the various
declarations required to actually make it work, and contained a lot of
extraneous code.  I do understand if there are some things you do not wish to
share, but could you provide a minimal scene with only the relevant parts?  This
should be just the ring object, a basic media declaration (this doesn't have to
include the special color_map, but it should be similar in color), and a
light_source placed similarly to the real scene.
-Reactor
Date: 30 Nov 2009 11:45:02
Message: <4b13f68e@news.povray.org>
High!
O.k., once more:
#include "starry_sky.inc" // self-programmed macro to generate a starry
sky sphere according to real astronomical data, 900 stars, configurable
according to camera angle and image resolution
#include "functions.inc" // for eval_pigment()
#declare sc=13347; // 1 POV unit = 13347 kilometres
#declare rs=0; // radiosity flag, 0 = radiosity off
#declare lores=0; // flag for low resolution Saturnian rings (dependent
on camera distance in the future)
#declare F_Standard_Planetary_Surface =
finish
   #if (!rs)
     ambient 0.0001
   diffuse 1
   brilliance 0.8
#declare F_Saturn_Rings =
finish
   #if (!rs)
     ambient 0.01
   diffuse 1
   brilliance 0.05
#declare F_Saturn_Rings_UnlitSide =
finish
   #if (!rs)
     ambient 0.3
   diffuse 5
   brilliance 0.05
#declare cam = 7; // camera mode
// CELESTIAL BODIES OF THE SOLAR SYSTEM DATA
// Column 0: orbital semi-major axis (to the Sun or the respective
planet) in kilometres
// Column 1: radius in x dimension, in kilometres
// Column 2: radius in y dimension, in kilometres (if oblateness is
given then stated as -1)
// Column 3: radius in z dimension, in kilometres (if oblateness is
// Column 4: axial tilt in degrees (planets: relative to orbit around
the Sun, moons: relative to planet's equatorial plane)
// Column 5: orbital inclination in degrees (planets: relative to
ecliptic, moons: relative to planet's equatorial plane)
// Column 6: orbital eccentricity
// Column 7: perihelion argument (degrees; if variable (Earth's Moon)
then stated als -1)
// Column 8: longitude of ascending node (degrees; if variable (Earth's
Moon) then stated als -1)
// Column 9: oblateness (not taken into account if different radii
explicitly stated)
// Column 10: declination of north pole (degrees)
// Column 11: right ascension of north pole (degrees!)
// Column 12: albedo (if irrelevant (Sun) stated as -1)
#declare bodies = array [74][12]
   {           0,     696000,       -1,      -1,         7.25,     0,
0,             0,         0,       0.000009,  63.87,   286.125   }, //
  0 - Sun
{  1433449370,      60268,    54364,   60268,  26.73,        2.484,
0.055723219, 336.013862,113.642811,-1,       83.537,   40.589    } // 72
- Saturn
// PROVISIONAL PLANETARY POSITIONS (to be replaced later according to
astronomically accurate orbital data)
#declare Pos_Saturn = bodies[72][0]*<sin(radians(157.4)), 0,
cos(radians(157.4))>;
// CAMERA DATA
#switch(cam)
   #case (7) // centered on Saturn, rings oblique view
     #declare camPos = Pos_Saturn + 350000 * <sin(radians(64)), 0,
cos(radians(64))>;
     #declare camLook = Pos_Saturn;
     #declare camAng = 40;
   #break
   #case (7.01) // view through Saturn's D ring
cos(radians(64))>;
     #declare camLook = Pos_Saturn+<10000, -32000, 0>;
     #declare camAng = 5;
   #break
   #case (7.02) // centered on Saturn, view of unlit ring side
     #declare camPos = Pos_Saturn + 350000 * <sin(radians(244)), 0,
cos(radians(244))>;
   #break
// CELESTIAL SPHERE
Stars(6, image_width, camAng, 1.5) // invocation of starry sky sphere macro
#macro SetAxis(dec, ras) // macro for orienting planets
   rotate <bodies[3][4]-(90-dec), 0, 0>
   rotate <0, 90-ras, 0>
light_source // Sun
   0
   color rgb 1
   looks_like
     sphere
       0, 1
       texture
        pigment { color rgb <1, 1, 0.85> }
        finish { ambient 1 diffuse 0 }
       scale bodies[0][1]/sc
       SetAxis(bodies[0][10], bodies[0][11])
// the following three image files can be obtained at
http://www.mmedia.is/~bjj/data/s_rings/index.html
#declare Saturn_Rings_Colors =
pigment
   image_map
     png "solarsys/sat_ring_color_bjoernjonsson.png"
#declare Saturn_Rings_Transparency =
pigment
   image_map
     png "solarsys/transparency_bjoernjonsson.png"
#declare Saturn_Rings_UnlitSide =
pigment
   image_map
     png "solarsys/unlitside_bjoernjonsson.png"
currently not yet working with media! (but that would be another thread
here!)
#declare Ring_Color_Map_1_to_255 =
     color_map
       #declare a=0;
       #while (a<255)
         #declare c=eval_pigment(Saturn_Rings_Colors, <2999/3000-a/1500,
0.5, 0>);
<2999/3000-a/1500, 0.5, 0>);
         [a*(((140390-74510)/140390)/1500) rgb c filter f.gray]
         #declare a=a+1;
#declare Ring_Color_Map_256_to_510 =
texture
   pigment
     cylindrical
     color_map
       #declare a=255;
       #while (a<510)
0.5, 0>);
         #declare a=a+1;
#declare Ring_Color_Map_511_to_765 =
texture
   pigment
     cylindrical
     color_map
       #declare a=510;
       #while (a<765)
0.5, 0>);
         #declare a=a+1;
#declare Ring_Color_Map_766_to_1020 =
texture
   pigment
     cylindrical
     color_map
       #declare a=765;
       #while (a<1020)
0.5, 0>);
         #declare a=a+1;
#declare Ring_Color_Map_1021_to_1275 =
texture
   pigment
     cylindrical
     color_map
       #declare a=1020;
       #while (a<1275)
0.5, 0>);
         #declare a=a+1;
#declare Ring_Color_Map_1276_to_1500 =
texture
   pigment
     cylindrical
     color_map
       #declare a=1275;
       #while (a<1500)
0.5, 0>);
         #declare a=a+1;
#declare Ring_UnlitSide_Map_1_to_255 =
texture
   pigment
     cylindrical
     color_map
       #declare a=0;
       #while (a<255)
         #declare c=eval_pigment(Saturn_Rings_UnlitSide,
         #declare a=a+1;
   finish { F_Saturn_Rings_UnlitSide }
#declare Ring_UnlitSide_Map_256_to_510 =
texture
   pigment
     cylindrical
     color_map
       #declare a=255;
       #while (a<510)
         #declare a=a+1;
#declare Ring_UnlitSide_Map_511_to_765 =
texture
   pigment
     cylindrical
     color_map
       #declare a=510;
       #while (a<765)
         #declare a=a+1;
#declare Ring_UnlitSide_Map_766_to_1020 =
texture
   pigment
     cylindrical
     color_map
       #declare a=765;
       #while (a<1020)
         #declare a=a+1;
#declare Ring_UnlitSide_Map_1021_to_1275 =
texture
   pigment
     cylindrical
     color_map
       #declare a=1020;
       #while (a<1275)
         #declare a=a+1;
#declare Ring_UnlitSide_Map_1276_to_1500 =
texture
   pigment
     cylindrical
     color_map
       #declare a=1275;
       #while (a<1500)
         #declare a=a+1;
// the actual planet and rings objects
union
sphere // Saturn
   0, 1
   texture
     pigment
       image_map
         jpeg "solarsys/saturn_bjoernjonsson.jpg" // also from
http://www.mmedia.is/~bjj/data/saturn/index.html
         map_type 1
         interpolate 2
     finish { F_Standard_Planetary_Surface }
   scale <bodies[72][1], bodies[72][2], bodies[72][3]>/sc
difference // rings
   cylinder
   cylinder
   // originally used with the no-media hi-res version of the rings -
I'm currently not sure whether I will able to make use of it also with
media!
     texture
       cylindrical
       texture_map
         [510*(((140390-74510)/140390)/1500) Ring_UnlitSide_Map_511_to_765]
         [765*(((140390-74510)/140390)/1500) Ring_UnlitSide_Map_766_to_1020]
       scale 140390/sc
   // ultra-cheap no media version of the rings
   #if (lores)
       pigment
         cylindrical
         color_map
           #declare a=0;
           #while (a<255)
             #declare a=a+1;
         scale 140390/sc
   #else // current media problem!
     hollow
     pigment { rgbt 1 }
     interior
       media
         scattering
           5, 1
           eccentricity -0.4
           extinction 0
         density
           cylindrical
           // hi-res version (1500 color and transparency levels),
currently not usable with media (but please let's discuss this later on!)
           /* density_map
             [510*(((140390-74510)/140390)/1500) Ring_Color_Map_511_to_765]
             [765*(((140390-74510)/140390)/1500) Ring_Color_Map_766_to_1020]
           // current media version
             #declare a=0;
             #while (a<255)
f.gray*/]
               #declare a=a+1;
            scale 11
camera
   location camPos/sc
   look_at camLook/sc
   angle camAng
// end of code
Ring color and transparency maps are at
Yadgar
Date: 1 Dec 2009 03:00:01
Message: <web.4b14cc15ff013193d4fa99a30@news.povray.org>
> High!
> O.k., once more:
I would like to help, but I cannot wade through that and make it work.  I wasn't
requesting more code in my last post, I was requesting working code.  Even after
tinkering with the code quite a bit, I could not really make it work.  As such,
I could not try to fix the problems.
    Please note that by minimal scene, I meant the absolute minimum code
required to duplicate the problem.  This code should be self contained as best
as possible, and should simply work upon copy and paste.  The image maps,
textures, starry skies, and a lot of other stuff is not required to troubleshoot
the parameters of your media.  If it is not possible to easily separate out the
components, consider posting an archive under the binaries group.
What I did notice is that, as best as I can tell, you are viewing the rings edge
on.  Does the media container show up when it isn't transparent?
The variable names are a little ambiguous, as such I could not tell the relative
thickness of the rings.  However, it seems like they are very thin.  Did you
already try increasing the scattering amount proportionally?
  good luck,
 -Reactor
Date: 1 Dec 2009 13:02:26
Message: <4b155a32@news.povray.org>
High!
I didn't try yet... but will do so later this night (CET)!
Relative thickness is 200 metres!
> Did you
Yes, I just tried this, by setting the scattering amount to 10 - and I
got blazingly bright rings close to white-out, but still no shadow on
the planet! As general scattering amount and rgb values in the density
map are equivalent, there seems to be no point in trying the lower the
density values there instead...
And, yes, later this evening I will come up with a self-containing
Saturn scene to test for you! But first I have to do my daily Afghan
bodycount...
Yadgar
Date: 1 Dec 2009 16:53:49
Message: <4b15906d$1@news.povray.org>
High!
> bodycount...
Here it is:
// beginning of code
// INCLUDES
// VARIABLES
#declare sc=13347; // 13347; // 1 POV unit = 13347 kilometres
global_settings
   max_trace_level 20
   assumed_gamma 1.5
// FINISHES
finish
   ambient 0.0001
   diffuse 1
   brilliance 0.8
finish
   ambient 0.01
   diffuse 1
   brilliance 0.05
#declare bodies = array [2][12]
//   0 - Sun
  1 - Saturn
#declare Pos_Saturn = bodies[1][0]*<sin(radians(157.4)), 0,
#declare cam = 1; // camera mode
#switch (cam)
   #case (0) // centered on Saturn, view of lit ring ride
cos(radians(64))>;
   #break
   #case (1) // centered on Saturn, view of unlit ring side
cos(radians(244))>;
   #break
   rotate <23.439281-(90-dec), 0, 0>
light_source // Sun
   0
   color rgb 1
   looks_like
     sphere
       0, 1
       texture
pigment
   image_map
pigment
   image_map
union
sphere // Saturn
   0, 1
   texture
     pigment
       image_map
         map_type 1
         interpolate 2
   scale <bodies[1][1], bodies[1][2], bodies[1][3]>/sc
difference // rings
   cylinder
   cylinder
     hollow
     pigment { rgbt 1 }
     interior
       media
         scattering
           5, 10
           eccentricity -0.4
           extinction 0
         // absorption 0.
         density
           cylindrical
             #declare a=0;
             #while (a<255)
f.gray */ ]
               #declare a=a+1;
            scale 140390/sc
   SetAxis(bodies[1][10], bodies[1][11])
camera
   location camPos/sc
   look_at camLook/sc
   angle camAng
// end of code
Yadgar
Date: 1 Dec 2009 17:23:44
Message: <4b159770@news.povray.org>
...also ring color and transparency maps!
Download 'sat_ring_color_bjoernjonsson.png' (4 KB) Download 'saturn_bjoernjonsson.jpg' (1013 KB) Download 'transparency_bjoernjonsson.png' (2 KB)
Preview of image 'sat_ring_color_bjoernjonsson.png'
Preview of image 'saturn_bjoernjonsson.jpg'
Preview of image 'transparency_bjoernjonsson.png'
Date: 2 Dec 2009 03:50:01
Message: <web.4b162954ff0131937dea0d300@news.povray.org>
> High!
> Here it is:
The problem has to do with floating point accuracy limitations in the media
container.  This part here:
does NOT go well with this part down here:
> difference // rings
>    cylinder
>    cylinder
The thickness of the rings is too small with respect to the rest of the scene.
I am sure it is the scientifically correct value, but there is a problem with
mixing such small and large values in a scene.  Interestingly enough, you should
be able to render the container shape with those dimensions without any
problems.  If you did that, you could use double_illuminate to make it look like
the media would.
If you want to use media, you will have to make the rings thicker and change
some of the sampling parameters.  This is the media block I used with visually
ok results.  I am not sure if the ring color and thickness is correct, but it
should be easy to tune at this point by changing the scattering extinction and
color values.
Ring code:
#local sc2 = 25; // new scale value for thickness only, as old
                 // scale value was too small.
difference // media rings
   cylinder
     <0, -0.11, 0>/sc2, <0, 0.1, 0>/sc2, 140390/sc
   cylinder
     <0, -0.12, 0>/sc2, <0, 0.11, 0>/sc2, 74510/sc
     hollow
     no_radiosity
     pigment { rgbt 1 }
     interior
       media
       samples 30
         scattering
           5, 150
           eccentricity -0.4
           extinction    0.4
         density
           cylindrical
             #declare a=0;
             #while (a<255)
               #declare c=eval_pigment(Saturn_Rings_Colors, <509/510-a/255, 0.5,
0>);
<c.red,c.green,c.blue>*f.gray ]
          /* you should be multiplying by f.gray, as it returns a transparency
             value from [0..1].
             Note that scattering media is inherently filtering, and the filter
             component of a color needn't be used.
               #declare a=a+1;
            scale 140390/sc
You can also test scaling the entire scene up by 100 units or so.  Consider this
thread here (web view)
http://news.povray.org/povray.general/thread/%3C47fa4f1b%241%40news.povray.org%3E/)
Anyway, hope that helps.  I rendered with those settings and got some ok
results, but the rings look rather different from camera 0 compared to camera 1.
 I think part of this is the media type, which has direction dependent
scattering, but this might mean you'll have to change sampling parameters
between angles if you want a certain look.
-Reactor
Date: 2 Dec 2009 04:00:01
Message: <web.4b162c53ff0131937dea0d300@news.povray.org>
I noticed that you used ambient values for the finish, and that probe pictures
of Saturn show that the backside of the planet receives quite a bit of light
from the rings.  This made me wonder about using no_image and no_shadow with an
object the same size and shape as the media container object so that its
radiosity can reflect light onto Saturn, then using the no_radiosity flag on the
media container so that it can fit in there as it did before.
Anyway, I went back and took a few liberties with your code... then took a whole
bunch more.  There are a few artifacts on the innermost ring closest to the
shadowed side of Saturn, but those can probably be removed by increasing the
samples.  It is also possible that they are caused by a non-zero specular value
for the finish - note the bright outer edge of the ring on the far right, it
could be the same thing (I didn't check).
Using radiosity gives Saturn a nicely back-lit surface.
//----------- beginning of code
#version 3.6;
// INCLUDES
// VARIABLES
#declare Use_Radiosity = on;
global_settings
   max_trace_level 20
   assumed_gamma 1.5
#if(Use_Radiosity)
 radiosity{
  pretrace_start 256/max(image_width,image_height)
  pretrace_end     8/max(image_width,image_height)
  count 100
  nearest_count 10
  error_bound    0.125
  recursion_limit  1
  low_error_factor 0.50
  gray_threshold   0.75
  minimum_reuse 0.00
  brightness  0.50
  adc_bailout 0.01
  normal off
  media  off
  always_sample on
// FINISHES
finish
 #if(Use_Radiosity)
   ambient 0 // zero if radiosity is used
  #else
   ambient 0.0001
   diffuse 1
   brilliance 0.8
finish
 #if(Use_Radiosity)
  #else
   ambient 0.01
   diffuse 1
   brilliance 0.05
//   0 - Sun
//   1 - Saturn
#declare cam = 0; // camera mode
#switch (cam)
cos(radians(64))>;
   #break
cos(radians(244))>;
   #break
light_source // Sun
   0
   color rgb 1
   looks_like
     sphere
       0, 1
       texture
pigment
   image_map
     png "sat_ring_color_bjoernjonsson.png"
pigment
   image_map
     png "transparency_bjoernjonsson.png"
union
sphere // Saturn
   0, 1
   texture
     pigment
       image_map
         jpeg "saturn_bjoernjonsson.jpg"
         map_type 1
         interpolate 2
difference // rings radiosity:
   cylinder{ <0, -0.11, 0>/sc, <0, 0.1, 0>/sc, 140390/sc }
   cylinder{ <0, -0.12, 0>/sc, <0, 0.11, 0>/sc, 74510/sc }
 pigment { rgb 1 }
 finish{ F_Saturn_Rings }
 no_image
 no_shadow
//------------ The issue was floating point accuracy - see posts:
// this issue causes artifacts with media when the container shape is too thin.
#local sc2 = 25;
   cylinder
   cylinder
     hollow
     no_radiosity
     pigment { rgbt 1 }
     interior
       media
       samples 30
         scattering
           5, 150
           eccentricity -0.4
           extinction    0.4
  emission 2*Use_Radiosity
         density
           cylindrical
             #declare a=0;
             #while (a<255)
0>);
             value from [0..1].
               #declare a=a+1;
            scale 140390/sc
camera
   location camPos/sc
   look_at camLook/sc
   angle camAng
//------------- end of code
Note that I changed the path for the image_maps, since I had the files all in a
single directory.
-Reactor
Download 'yagdar_saturn.png' (679 KB)
Preview of image 'yagdar_saturn.png'
Date: 2 Dec 2009 06:25:40
Message: <4b164eb4@news.povray.org>
High!
Thank you for your help... as even 200 metres (like in my original
postings) for the rings is ten times too thick to be scientifically
accurate, but also your solution (with media) would have resulted in
rings many kilometres thick, I decided to use double_illuminate rather
than media (I wonder that it works also with 3.6!), as it also speeds up
  animation renderings considerably, compared to using media.
See below what I've got now...
Yadgar
Download '2009-12-02 saturn, take 12.jpg' (32 KB) Download '2009-12-02 saturn, take 13.jpg' (30 KB)
Preview of image '2009-12-02 saturn, take 12.jpg'
Preview of image '2009-12-02 saturn, take 13.jpg'
