POV-Ray : Newsgroups : povray.binaries.images : PoVEarth, day #2 Server Time
30 Jul 2026 19:43:07 EDT (-0400)
  PoVEarth, day #2 (Message 1 to 5 of 5)
Subject: PoVEarth, day #2
Date: 15 Jul 2008 17:20:04
Message: <487d1484@news.povray.org>
High!
Second day of the PoVEarth project... meanwhile, I calculated the
coordinates for the Local Model, added a ground plane (with a simple
standard texture for bare soil) and placed the apartment box
(provisionally) 6.4 metres above it. Now also the sky is no longer
completely stupid, it looks remotely like a fine day on Terra...
The camera position is that of a pedestrian standing in the middle of
the suburban side street where I live, looking south-eastward.
Watch out for more!
See you in Khyberspace!
Yadgar
Download '.jpg' (16 KB)
Preview of image '.jpg'
.jpg
Subject: Re: PoVEarth, day #2
Date: 15 Jul 2008 18:35:00
Message: <web.487d254da89311484a226ad00@news.povray.org>
=?ISO-8859-15?Q?J=F6rg_=27Yadgar=27_Bleimann?= <yaz### [at] gmxde> wrote:
> High!
> Watch out for more!
> Yadgar
Are you planning on placing your objects via script or macro, and are you using
a modeling tool?
Before I started experimenting with wings3d, I found complex shapes
prohibitively hard to produce by hand via SDL/
-Reactor
Date: 15 Jul 2008 19:17:00
Message: <487d2fec@news.povray.org>
High!
> a modeling tool?
For curved structures such as roads and sidewalks, I probably will use a
Python script converting GIMP bezier paths into PoV-Ray splines... but
more rectangular structures (like most buildings), for the time being, I
could do with simple CSG!
See you on www.khyberspace.de!
Yadgar
Date: 16 Jul 2008 15:43:22
Message: <487e4f5a@news.povray.org>
BTW, you should familiarize yourself with scaling issues and
floating point accuracy if those buildings are then intended
to be placed on an earth-sized sphere.
Date: 16 Jul 2008 18:47:23
Message: <487e7a7b$1@news.povray.org>
High!
In fact, I did!
// SCALE LEVEL VIEW FLAGS
#declare cosmic=0;
#declare global=0;
#declare regional=0;
#declare loc=1;
#declare microloc=0;
// SCALING FACTORS
#if (cosmic)
   #declare f=100000; // 1 POV unit = 100 kilometres
   #else
     #if (global)
       #declare f=1000; // 1 POV unit = 1 kilometre
       #else // regional, local and microlocal view
         #declare f=1;  // 1 POV unit = 1 metre
         #if (regional)
         #else
           #if (loc)
             #declare trans=<247.38, 0, 248>/f; // coordinate origin for
local model
// end of listing slice
I'm pretty aware that in the "global" model, the smallest object to be
rendered correctly will be about 1 km/12500 = 8 cms across... probably I
will "fine-tune" the scaling factors later on! In the long run, we also
could hope for a smaller epsilon value with the version 4.0 - and, of
course, faster CPUs!
Yadgar
