POV-Ray : Newsgroups : povray.binaries.images : Brute force rendering Server Time
16 Jun 2026 10:04:16 EDT (-0400)
  Brute force rendering (Message 91 to 97 of 97)
Subject: Re: Brute force rendering
Date: 16 Mar 2008 13:38:59
Message: <47dd6943@news.povray.org>
> Here is a sample image. Basically identical to previous with some small
> additions. This was also about a 8h rendering but bigger image and
> almost twice the passes -> less noise.
This one has 4:3 ratio -- will work much better for wallpaper.
*changes wallpaper from kuva11 to kuva14*
Date: 16 Mar 2008 16:17:46
Message: <47dd8e7a@news.povray.org>
> Oh, one feature would be quite useful in test renderings: let the user
> select a rectangular area in the image and the renderer starts to render
> only that area until told otherwise. That way the user can quickly get
> high quality renders from interesting areas. This should be a piece of
> cake implementationally.
This was a definite keeper. Works quite well in practice. See the image.
(Don't mind the odd noise. Image is scaled so the noise looks odd.)
Now I can select areas of interest and let the program render only that
area.
Download 'kuva15.jpg' (187 KB)
Preview of image 'kuva15.jpg'
Date: 17 Mar 2008 06:30:01
Message: <web.47de55e56d8b2453943b35b60@news.povray.org>
> area.
Fantastic!
Makes me want the QX9650 even more ;) But it's $1200.00 just for the CPU
alone...!! :O
You know that feature you just implemented would be great for when a render is
almost done but there are still 1 or 2 noisy areas (e.g. caustics, or in a dark
corner) and you could concentrate all the power just on that section -
brilliant!
By the way I've been meaning to ask you - where does the interesting striped
reflection in the pink glass box (next to the yellow/gold sphere) come from? I
couldn't replicate that when I tried to recreate your scene last time.
sooperFoX
Date: 17 Mar 2008 13:43:12
Message: <47debbc0@news.povray.org>
sooperFoX wrote:
> Fantastic!
> CPU alone...!! :O
True. But 9300 and 9450 are quite cheapish already :) I just wonder if
it is stupid to spend 300 euros just because one single program needs
the additional cores...naaah :)
> render is almost done but there are still 1 or 2 noisy areas (e.g.
> caustics, or in a dark corner) and you could concentrate all the
> power just on that section - brilliant!
I think so too. And in the test phase you can just render the
interesting objects without spending time on large uninteresting
surfaces - without the need to alter camera/image size settings. It
would also be easy to assign different areas for different threads. But
even this is usable now.
> striped reflection in the pink glass box (next to the yellow/gold
> sphere) come from? I couldn't replicate that when I tried to recreate
The pink tower is made of 6 smaller boxes which have just a small gap
between them. They also get "pinker" downwards. So it must be total
reflections/refractions the individual pieces cause. (If my code is
calculating them properly...).
Date: 3 Apr 2008 07:19:57
Message: <47f4cb6d@news.povray.org>
Back again!
I've been refactoring and restructuring the code. It takes time to
figure out what is "the best" program structure. And I'm sure I'll
restructure it many times more later on.
Still missing transformations and acceleration structures - which both
are desperately needed. I also improved the UI code and now it works
perfectly. The UI thread now takes only minimum amount of CPU time and
thus doesn't slow the rendering down at all. And is still responsive enough.
I did implement one cool new feature: Depth of Field. It works just as
in real life (well, I don't model complete multi-element lenses...).
There is a virtual lens and all rays are cast through random points of
it based on aperture size and focal distance. So the result is very
realistic. Now the aperture is a conventional circle but it would be
quite easy to implement other kinds of apertures which look like actual
lens apertures. See the sample image below. (There is another DOF image
on the webpage.) The implementation was, again, very easy with no "side
effects" at all.
I also setup a webpage about this program (it is called "ssRay" at the
moment ;-). All the images are shown there:
http://www.saunalahti.fi/~sevesalm/ssRay.html
Download 'kuva.jpg' (55 KB)
Preview of image 'kuva.jpg'
Date: 3 Apr 2008 20:45:00
Message: <web.47f587296d8b2453ae42298f0@news.povray.org>
Love the evolution!  Very impressive.
 - Ricky
Date: 5 Apr 2008 15:16:05
Message: <47f7de05$1@news.povray.org>
I'd really really really love to see the code... :)
Ray
