POV-Ray : Newsgroups : povray.binaries.images : Brute force rendering Server Time
16 Jun 2026 06:47:22 EDT (-0400)
  Brute force rendering (Message 71 to 80 of 97)
Subject: Re: Brute force rendering
Date: 5 Mar 2008 18:56:50
Message: <47cf3342$1@news.povray.org>
> With high-precision geometry, you are free to model entire solar systems
> to scale. With arbitrary-precision geometry, you could model entire
> galaxies to scale! :-D
And the render time would be similar to flying to another galaxy with
current technology? :)
Date: 6 Mar 2008 01:50:41
Message: <47cf9441@news.povray.org>
Nicolas Alvarez wrote:
>> True. But in the world of brute force renderers that is not _that_
>> impressive
> You still haven't shown me your renderer do it >:)
Here you are :) A bit grainy still and a different setup but still shows
indirect caustics - as it should.
Download 'kuva13.jpg' (19 KB)
Preview of image 'kuva13.jpg'
Date: 6 Mar 2008 03:30:00
Message: <web.47cfaabf6d8b2453943b35b60@news.povray.org>
Severi Salminen wrote:
> W000t! Where can I get my prize? :-)
I haven't rendered it yet :P
> 2. What was the actual color value you specified for the green glass?
> Maybe the glass is so dark that multiple layers simply don't let enough
> light through?
RGB <59, 255, 96> refraction with White 100% reflection also, an IOR of 1.56 and
fresnel falloff.
When I did the MLT/PT render that I posted initially the light passed through no
problems.. since then some setting must have changed. I don't know :)
> 3. My image seems to have less noise on the table and more noise on the
> floor.
That is correct for PT because directly lit surfaces will receive more light and
so smooth out much faster than indirectly lit or occluded (the floor) surfaces.
> So this is not very scientific result. At some point I'll make a better
> test scene and post the dimensions. Or anyone else can do it. Maybe in
> Pov-SDL so we can compare results from it too. And we can keep this even
> remotely on-topic :-)
I wait eagerly both for the chance to do some comparisons with the same data but
also for the time when we can try out your renderer ourselves!
Date: 6 Mar 2008 03:55:00
Message: <web.47cfb0fe6d8b2453943b35b60@news.povray.org>
Just had a look in the settings.. MLT goes up to 100 bounces with a stay-alive
probability of 0.7 (the same termination method yours does, but also with a
hard limit), but PT has a default max of 6!!
Taking it to 20 is enough to get the glass to render transparent. :blush:
OK, now you can get back on topic. Sorry.
Date: 6 Mar 2008 09:13:07
Message: <47cffbf3$1@news.povray.org>
fidos wrote:
> Here a rendering of 1h on one core of a Q6600 2.4 GHz with my MegaPov Montecarlo
> Path tracing patch. Noise is important but there is no spikes.
  I find the almost complete lack of color bleeding from the colored
walls to the white walls/ceiling rather suspicious.
  Don't tell me your patch only reflects brightness, not color?
Date: 6 Mar 2008 11:42:22
Message: <47d01eee@news.povray.org>
Quite possibly.
I haven't been able to dredge up any material of the performance of
arbitrary-precision numbers versus simple primitives (not that I've
looked very hard yet). I don't know if I'm dealing with something twice
as slow, or a full order of magnitude speed difference, or something
that gets exponentially worse.
But, yeah, it's definitely going to be slow. :-)
William Tracy
    It occurred to him that now he was going to be not only the first
man on Mars, but the first detective. He grinned at the thought, and the
last action of the omegendorph set his nerves aglow.
     -- Kim Stanley Robinson, _Red Mars_
Date: 6 Mar 2008 12:34:44
Message: <47d02b34@news.povray.org>
GMP is a very fast arbitrary-size number library. But it's integer only
so I don't think that can help you much :)
Date: 6 Mar 2008 14:10:00
Message: <web.47d040ad6d8b245323549e750@news.povray.org>
Strange idea !
I think that the walls aren't bright enough.
Some color blending of the green wall is visible on the small diffuse sphere or
on the wall in the penumbrea.
Fidos
Date: 6 Mar 2008 17:03:01
Message: <47d06a15$1@news.povray.org>
"almost complete lack of color bleeding" == "some color bleeding", right?
It is just a little faint. Take your favorite photo editing software and
tune saturation up. You'll see some bleeding in the right places :)
Date: 7 Mar 2008 04:19:36
Message: <47d108a8@news.povray.org>
  I would expect it to be a bit more visible. Compare eg. to:
http://www.winosi.onlinehome.de/Gallery_t14_10.htm
http://www.winosi.onlinehome.de/Gallery_t14_11.htm
http://www.winosi.onlinehome.de/Gallery_t14_17.htm
