POV-Ray : Newsgroups : povray.binaries.images : texture interpolation... why rgb ? Server Time
31 Jul 2026 11:58:18 EDT (-0400)
  texture interpolation... why rgb ? (Message 21 to 25 of 25)
Subject: Re: texture interpolation... why rgb ?
Date: 30 Nov 2007 12:08:01
Message: <47504371$1@news.povray.org>
Le 30.11.2007 14:59, Trevor G Quayle nous fit lire :
> Having seen the differences between the different colour spaces, I think rather
> than trying to figure out which is right or wrong (as opinion on this can vary
> drastically)  I think it could be of use to be able to implement this in future
> POV versions (likely POV4) provided efficient conversion algorithms can be made
> (my HSL/HSV algorithm is SDL function based and renders quite slow compared to
> the regular RGB gradient).  Anywhere a pattern gradient can be applied, be able
> to specify the colour space to use (RGB being default) and have whatever colour
> spaces can be properly set up (HSV,HSL,YUV, etc.)
I would agree... would you mind sharing your SDL interpolation code ?
The superior man understands what is right;
the inferior man understands what will sell.
-- Confucius
Date: 30 Nov 2007 12:45:00
Message: <web.47504bf52088bdecc150d4c10@news.povray.org>
I don't mind.  It can be likely far better optimized.  It is quite easy to do as
a macro using #if, #range, etc., but was quite cumbersome to make a continuous
function through creative use of select(), especially since functions don't
handle vectors, so each component has to be split out separately and
recombined.
I have also influded the function for converting HSV/HSL to XYZ and back
The formulae for these are based on the ones from wikipedia
http://en.wikipedia.org/wiki/HSV_color_space
Let me know if you see any errors or have questions.
//RGB to HSV
#declare HHSV=function(R,G,B)
  60*
  select(
    min(R,G,B)-max(R,G,B)
  ,//min<max
    select(
      R-max(R,G,B)
    ,//R<max
      select(
        B-max(R,G,B)
      ,//G=max
        (B-R)/(max(R,G,B)-min(R,G,B))+2
      ,//B=max
        (R-G)/(max(R,G,B)-min(R,G,B))+4
    ,//R=max
      (G-B)/(max(R,G,B)-min(R,G,B))+
      select(
        G-B
      ,//G>B
        6
      ,//B>G
        0
  ,//min=max
    0
#declare SHSV=function(R,G,B) {select(-max(R,G,B),1-min(R,G,B)/max(R,G,B),0)}
#declare VHSV=function(R,G,B) {max(R,G,B)}
//END RGB to HSV
//RGB to HSL
#declare HHSL=function(R,G,B) {HHSV(R,G,B)}   //same as HSV
#declare SHSL=function(R,G,B)
  select(
  ,//max>min
    (max(R,G,B)-min(R,G,B))/
    select(
      1-(max(R,G,B)+min(R,G,B))
    ,//l>1/2
      2-(max(R,G,B)+min(R,G,B))
    ,//1/2=>l
  ,//max=min
    0
#declare LHSL=function(R,G,B){(max(R,G,B)+min(R,G,B))/2}
//END RGB to HSL
//HSL to RGB
#declare tHSL=function(H,C){(H/360+C/3)-floor(H/360+C/3)}
#declare qHSL=function(H,S,L){select(L-1/2,L*(1+S),L+S-L*S)}
#declare pHSL=function(H,S,L){2*L-qHSL(H,S,L)}
#declare CHSL=function(H,S,L,C)
  select(
    -S
  ,//S>0
    select(
      tHSL(H,C)-1/6
    ,//tc<1/6
      pHSL(H,S,L)+2*(qHSL(H,S,L)-L)*6*tHSL(H,C)
      select(
        tHSL(H,C)-1/2
      ,//tc<1/2
        qHSL(H,S,L)
        select(
          tHSL(H,C)-2/3
        ,//tc<2/3
          pHSL(H,S,L)+2*(qHSL(H,S,L)-L)*6*(2/3-tHSL(H,C))
        ,//esle
          pHSL(H,S,L)
  ,//S=0
    L
#declare RHSL=function (H,S,L){CHSL(H,S,L,+1)}
#declare GHSL=function (H,S,L){CHSL(H,S,L, 0)}
#declare BHSL=function (H,S,L){CHSL(H,S,L,-1)}
//END HSL to RGB
//HSV to RGB
#declare hHSV=function (H){floor(mod(H/60,6))}
#declare fHSV=function (H){H/60-hHSV(H)}
#declare pHSV=function (H,S,V){V*(1-S)}
#declare qHSV=function (H,S,V){V*(1-fHSV(H)*S)}
#declare tHSV=function (H,S,V){V*(1-(1-fHSV(H))*S)}
#declare RHSV=function (H,S,V)
  select(hHSV(H)-0.5
  ,//0
    V
    select(hHSV(H)-1.5
    ,//1
      qHSV(H,S,V)
      select(hHSV(H)-2.5
      ,//2
        pHSV(H,S,V)
        select(hHSV(H)-3.5
        ,//3
          pHSV(H,S,V)
          select(hHSV(H)-4.5
          ,//4
            tHSV(H,S,V)
          ,//5
            V
#declare GHSV=function (H,S,V)
  select(hHSV(H)-0.5
  ,//0
    tHSV(H,S,V)
    select(hHSV(H)-1.5
    ,//1
      V
      select(hHSV(H)-2.5
      ,//2
        V
        select(hHSV(H)-3.5
        ,//3
          qHSV(H,S,V)
        ,//4,5
          pHSV(H,S,V)
#declare BHSV=function (H,S,V)
  select(hHSV(H)-0.5
  ,//0
    pHSV(H,S,V)
    select(hHSV(H)-1.5
    ,//1
      pHSV(H,S,V)
      select(hHSV(H)-2.5
      ,//2
        tHSV(H,S,V)
        select(hHSV(H)-3.5
        ,//3
          V
          select(hHSV(H)-4.5
          ,//4
            V
          ,//5
            qHSV(H,S,V)
//END HSV to RGB
//CONVERT HSV to XYZ (polar to caresian) for interpolation and back
#declare HSVX=function(H,S,V){sin(radians(H))*S}
#declare HSVY=function(H,S,V){cos(radians(H))*S}
#declare HSVZ=function(H,S,V){V}
#declare
XYZH=function(X,Y,Z){select(-sqrt(X*X+Y*Y),abs(degrees(acos(Y/sqrt(X*X+Y*Y)))-select(X,360,0)),0)}
#declare XYZS=function(X,Y,Z){sqrt(X*X+Y*Y)}
#declare XYZV=function(X,Y,Z){Z}
#declare HSLX=function(H,S,L){sin(radians(H))*S}
#declare HSLY=function(H,S,L){cos(radians(H))*S}
#declare HSLZ=function(H,S,L){L}
//H & S same as above
#declare XYZL=function(X,Y,Z){Z}
//END CONVERT HSV to XYZ
#declare INTRGB=function (PTA,PTB,K){PTA+(PTB-PTA)*K}
Date: 30 Nov 2007 13:18:36
Message: <475053fc@news.povray.org>
Le 30.11.2007 18:44, Trevor G Quayle nous fit lire :
Thanks, that's interesting.
I trusted the povray macro for CRGB2HSV/CRGB2HSL and opposite for
HSV/L <->RGB.
XYZ opens an interesting path.
-- Confucius
Date: 30 Nov 2007 15:55:01
Message: <web.475077962088bdecc150d4c10@news.povray.org>
> HSV/L <->RGB.
> -- Confucius
The problem with the macro is that it can't be used in a function, which is what
I wanted.
Here is the pigment declaration for an HSV gradient:
#macro PIG2(RGB1,RGB2)//HSV gradient
  #declare RA=RGB1.x;#declare GA=RGB1.y;#declare BA=RGB1.z;
  #declare RB=RGB2.x;#declare GB=RGB2.y;#declare BB=RGB2.z;
  average
  pigment_map{
    [function{
      RHSV(
        XYZH(
INTRGB(HSVX(HHSV(RA,GA,BA),SHSV(RA,GA,BA),VHSV(RA,GA,BA)),HSVX(HHSV(RB,GB,BB),SHSV(RB,GB,BB),VHSV(RB,GB,BB)),x)
INTRGB(HSVY(HHSV(RA,GA,BA),SHSV(RA,GA,BA),VHSV(RA,GA,BA)),HSVY(HHSV(RB,GB,BB),SHSV(RB,GB,BB),VHSV(RB,GB,BB)),x)
INTRGB(HSVZ(HHSV(RA,GA,BA),SHSV(RA,GA,BA),VHSV(RA,GA,BA)),HSVZ(HHSV(RB,GB,BB),SHSV(RB,GB,BB),VHSV(RB,GB,BB)),x)
        XYZS(
        XYZV(
    } color_map{[0 rgb 0][1 rgb <1,0,0>]}]
    [function{
      GHSV(
        XYZH(
        XYZS(
        XYZV(
    } color_map{[0 rgb 0][1 rgb <0,1,0>]}]
    [function{
      BHSV(
        XYZH(
        XYZS(
        XYZV(
    } color_map{[0 rgb 0][1 rgb <0,0,1>]}]
    box{<0,0,0>,<1,0,1>
      pigment{PIG2(COLA,COLB)}
      finish{ambient 3 diffuse 0}
      translate <-1/2,0,-1/2>
      scale <LEN,1,WID/3*2>
      translate z*WID/3*2
Date: 5 Dec 2007 17:09:47
Message: <475721ab@news.povray.org>
here is a small experiment (real patched code), currently only for
polygon interpolation.
Still a little problem of green for degenerate hsv...
Next step, the blob 3D object...
Playing with ADC_bailout might be fun, if only it was per object and
not a global.
-- Confucius
Download 'demo1.png' (87 KB) Download 'demo2.png' (72 KB) Download 'demo3.png' (72 KB) Download 'demo4.png' (98 KB) Download 'demo5.png' (86 KB)
Preview of image 'demo1.png'
Preview of image 'demo2.png'
Preview of image 'demo3.png'
Preview of image 'demo4.png'
Preview of image 'demo5.png'
