POV-Ray : Newsgroups : povray.binaries.images : Cavorite Sphere (off the shelf) [~105K JPG] Server Time
5 Aug 2026 01:17:43 EDT (-0400)
  Cavorite Sphere (off the shelf) [~105K JPG] (Message 31 to 40 of 60)
Subject: Re: Cavorite Sphere (off the shelf) [~105K JPG]
Date: 23 Apr 2004 02:25:02
Message: <c6ackh$1r5$1@chho.imagico.de>
Dan P wrote:
> Try substituting the word "brighter" with "more bright" and it may sound
> more clear.
Earth is neither 21% brighter nor 21% more bright than moon assuming the
given albedo values.  If you want to give percentual values you have to
do it correctly, otherwise simply say the albedo of earth is 0.21 higher
than that of earth (which of course isn't a very useful information).
The whole thing is probably a bit confusing because the unit of albedo
is 1 (it is a ratio between two values of the same unit.  If you have
two people, one 1,60m tall and one 1,90m you also would not say one is
30% taller/more tall than the other...
Last updated 21 Mar. 2004 _____./\/^>_*_<^\/\.______
Date: 23 Apr 2004 19:09:14
Message: <cjameshuff-253827.19080523042004@news.povray.org>
In article <40889a54@news.povray.org>, "St." <dot### [at] dotcom> wrote:
> > We've been there, remember? ;-)
>     Heh, yes, I think I was about 6-7yo, cross-legged, wearing grey
> shorts, grey socks, in our sports-hall, watching a black and white TV
> when they touched down. A nice memory.  :)
Er...well, I didn't mean personally remembering the landing (I wasn't
even alive yet), but remembering that we have landed.
> <http://www.union.edu/PUBLIC/GEODEPT/COURSES/petrology/moon_rocks/7422
> 0.h
> > tm>
>     Aargh! 404 even when pasting the URL directly.
Damn...try this:
http://tinyurl.com/34weg
>  Yes, I used to walk our defunct railway lines when I was younger, and
> believe that I found samples of magma - I'm not sure, but that was
> what I was told. It was a dark substance with a golden
> sheen/iridescence to it, but it definitely looked molten and was round
> in shape when solidified. It was very 'glassy', and would break in
> half very cleanly, leaving a very reflective surface. I don't know if
> it was magma, it could have been anything native I guess, but I
> wouldn't know what.
Technically, magma is the still molten stuff under the crust. It becomes
lava when it leaks out onto the surface, and some form of igneous rock
when it solidifies. Solidified lava is often called just "lava rock".
What you describe sounds like some kind of obsidian (volcanic glass)
rich lava rock.
>    I found many shell fossils too, if that's a clue?
Shells are found in sedimentary rock, lava rock is igneous. Though it
could be from lava that flowed into sedimentary rock, or sedimentary
rock formed from ash and volcanic debris falling on a body of water.
Perhaps beach sand partially melted by lava? (That would explain the
glassiness and the shells.)
http://tag.povray.org/
Date: 23 Apr 2004 19:31:20
Message: <4089a748$1@news.povray.org>
Christoph Hormann wrote:
>> sound more clear.
The values are between 0 and 1. If they were between 0 and two, the
percentage would be half of what I said and so forth.
True; but that is a different set that does not map to a range between
zero and one because it constantly changes. If you took a snapshot in
time, say the shortest person is A and the tallest person is B, then you
could normalize the number and, indeed, use percentages.
> Christoph
Respectfully,
Dan P
http://<broken link>
Date: 23 Apr 2004 19:32:32
Message: <4089a790@news.povray.org>
St. wrote:
> "Christopher James Huff" <cja### [at] earthlinknet> wrote in message
> news:cjameshuff-4EC0B0.15182322042004@news.povray.org...
<snip />
> wouldn't know what.
Interesting! Where did you live when you were younger? Was it near any
volcanic activity?
Respectfully,
Dan P
Date: 23 Apr 2004 19:46:09
Message: <4089AAC3.5040605@yahoo.com>
>> Dan P wrote:
<snip />
I just had a thought: the real question here is, "Is the function of an
albedo value linear?" If we were to plot it on a graph from zero to one,
would the line be straight or curved? If straight, you we can relate the
values to each other using percentages. If not, we cannot.
Respectfully,
Dan P
Date: 24 Apr 2004 03:35:02
Message: <c6d57k$2n2$1@chho.imagico.de>
>> the given albedo values.  If you want to give percentual values you
>> have to do it correctly, otherwise simply say the albedo of earth is
>> 0.21 higher than that of earth (which of course isn't a very useful
>> information).
That's nonsense - in fact the albedo isn't even limited to [0..1] by
definition.  Anyway i am not really interested in convincing you from
using correct formulations if you don't want to, my arguments were clear
and easy to understand IMO, the rest is up to you.
Date: 24 Apr 2004 09:41:55
Message: <408a6ea3$1@news.povray.org>
Dan P nous apporta ses lumieres ainsi en ce 2004/04/23 19:46... :
> <snip>
> an albedo value linear?" If we were to plot it on a graph from zero to
> one, would the line be straight or curved? If straight, you we can
> relate the values to each other using percentages. If not, we cannot.
Albedo is linear. A planet with an albedo of 0.50 reflect 50% (2/4) of
the incident lignt, albedo 0.25 mean 25% (1/4) of incident light, albedo
0.75 = 3/4.
Date: 24 Apr 2004 09:47:11
Message: <408a6fde@news.povray.org>
> 0.75 = 3/4.
But it's not necessarily constant, is it?
A planet's albedo could be 0.25 with a certain amount of incident light, but
maybe, with twice as much incident light, its albedo would be only 0.21
(not talking about changes in the planet's surface, angle of incidence,
etc.)
light_source{9+9*x,1}camera{orthographic look_at(1-y)/4angle 30location
9/4-z*4}light_source{-9*z,1}union{box{.9-z.1+x clipped_by{plane{2+y-4*x
0}}}box{z-y-.1.1+z}box{-.1.1+x}box{.1z-.1}pigment{rgb<.8.2,1>}}//Jellby
Date: 24 Apr 2004 18:18:58
Message: <408ae7d2$1@news.povray.org>
Jellby nous apporta ses lumieres ainsi en ce 2004/04/24 09:47... :
>>0.75 = 3/4.
>etc.)
Albedo is the fraction of the total light, from low infrared to the
hardest UVs, faling onto a celestial body that is sent back into space.
Depending on the caracteristics of the surface, the body can be more
reflective along prevelieged directions, but the amount of incident
light won't chage it. Taking the moon closer to the sun, like at the
same distance as Mercury, will have no effect on it's albedo, altough it
will looks much brighter if you are to look at it from the same distance
as you look at it now.
The albedo depend entirely and only on the nature of the surface. Take
Venus and bring it on earth orbit, then most of it's clouds will rain
down, giving a lower albedo. Bring it down to Mercury orbit and it's
clouds will completely vaporize, maybe escaping into space, also
lowering it's albedo.
 From my past time in amateur astronomy, my physics cources and tons of
reading on the subject...
Date: 24 Apr 2004 19:17:43
Message: <408af597$1@news.povray.org>
>>> 0.75 = 3/4.
>> light, but maybe, with twice as much incident light, its albedo would
>> be only 0.21 (not talking about changes in the planet's surface, angle
>> of incidence, etc.)
Then it's settled! Because the albedo of a surface is linear, then it
can be expressed in terms of percentages :-)
Respectfully,
Dan P
