POV-Ray : Newsgroups : povray.binaries.images : The same attractor by Manuel Kasten Server Time
5 Aug 2026 00:46:14 EDT (-0400)
  The same attractor by Manuel Kasten (Message 9 to 18 of 18)
<<< Previous 8 Messages Goto Initial 10 Messages
Subject: Re: Another one :)
Date: 16 Mar 2004 14:20:14
Message: <4057536e$1@news.povray.org>
Not Java, but Matlab :)
Anyway, the syntax is very similar I think.
If you have any question, let me know.
Fernando
news:405752fe$1@news.povray.org...
> Fernando G. del Cueto schrieb:
> > 100 million points :)
> > and a different color scheme. I must go to class now, but I'll post my
> > coloring scheme soon.
> Is it possible to get the Java-Source of your programm? I would like to
> play around with it.
> mat### [at] matweide
> http://www.matwei.de
Download 'att.m.txt' (1 KB)
Date: 16 Mar 2004 15:03:00
Message: <40575d74@news.povray.org>
> Thanks! Yes, I remember that screensaver in linux. There's another one,
> called 'flow'. I love that one.
flow is also very nice, but my prefered one is IFS...  and I hope I'll
get to remake it with OpenGL one day!
> Here's the URL where you can find the wallpaper version of the image
> http://www.deviantart.com/view/5883845/
Thanks a lot!
   Simon
Date: 16 Mar 2004 15:25:16
Message: <405762ac$1@news.povray.org>
The java code is mine. It is without coloring and can be found at
http://madonion.homeip.net/attractors/
Manuel
Subject: Re: The same attractor by Manuel Kasten
Date: 16 Mar 2004 18:50:41
Message: <405792d1$1@news.povray.org>
"Fernando G. del Cueto" <fcu### [at] yahoocom> wrote in message
news:4056a4c0@news.povray.org...
> I didn't use POV, I made a program in Matlab and exported the resulting
> matrix to a 48-bit PNG. I had to do extensive image processing to stretch
> the contrast and luminosity of the image and some minor cosmetic
> adjustments.
> I also had the idea of adding different values for the colors of the
pixels.
> Basically, the colors are related to the change in position. The bigger
the
> change, the more intensity is put into the pixel.
> I used 10 million point. If I have time, probably I'll do a 100 million
> points.
> The image was generated in 3 minutes and less than 200 Mb of RAM.
> I hope you like it.
Very mathemagical.
- Respectfully,
Dan
http://<broken link>
Date: 18 Mar 2004 01:19:35
Message: <40593f77$1@news.povray.org>
I've set it as my work wallpaper and it's fabulous!  On some computer I
can't have a better resolution than 1024x768 and the image is still
centered and I can't see the 'strange' circle, which I like very much
and on some other computer I get a 1280x1024 perfect bg image which is
different and also very nice!
I was wondering...  the 'strange' screensaver used to animate the
attractors you have been rendering... could you animate it also?
Simon
Date: 18 Mar 2004 01:46:17
Message: <405945b9$1@news.povray.org>
news:40593f77$1@news.povray.org...
Thanks :) I'm glad you liked it.
Actually I'm working on some kind of animation right now... I'll leave it
overnight working... tomorrow I'll check what was the result :)
Fernando
Date: 18 Mar 2004 07:51:17
Message: <40599b45@news.povray.org>
> I hope you like it.
I really do. Is there some website where attractors are described in
detail? I've seen many differents by now (the Lorenz one being the first
:), but I've never found a source which could explain me the theory
behind it :(
Florian
Date: 18 Mar 2004 11:14:36
Message: <4059caec$1@news.povray.org>
"Florian Brucker" <tor### [at] torfboldcom> wrote in message
news:40599b45@news.povray.org...
> > I hope you like it.
first
> behind it :(
> Florian
This can help visualise a 2-D arrangement (OK - so it is part of a
spherical surface).
As a boy, one distraction was to hang a bar magnet vertical on a 0.5
or 1 metre string about 5 cms above the floor/table. 1 or more bar
magnets (or steel bolts) were then placed on the floor/table near this
pendulum which was then set swinging.
A variation was to use a glass table as base, a small torch taped to
the cord and place a camera (long exposure) below the magnets.
Alf
Date: 18 Mar 2004 12:17:35
Message: <4059d9af@news.povray.org>
> behind it :(
Tor Olaf Kristensen posted the following:
//Just in case anyone is interested in a free online versions of a book
//about "Strange Attractors":
//http://sprott.physics.wisc.edu/sa.htm
//"Strange Attractors: Creating Patterns in Chaos (ISBN 1-55851-298-5)"
//by Julien C. Sprott
I downloaded the pdf version and read it partially. It describes the concepts
behind these attractors very clearly. Note that the attractor Fernando posted
uses different equations:
x2 = sin(a*y1) - cos(b*x1)
y2 = sin(c*x1) - cos(d*y1)
Manuel
Date: 18 Mar 2004 13:05:00
Message: <4059e4cc$1@news.povray.org>
Excellent job!  Looking forward to see the results! =)
Simon
