POV-Ray : Newsgroups : povray.binaries.images : Evening at the River Server Time
4 Jun 2026 14:36:35 EDT (-0400)
  Evening at the River (Message 17 to 26 of 26)
Subject: RE: Evening at the River
Date: 9 Nov 2002 09:57:22
Message: <3dcd2252@news.povray.org>
3dccf24b@news.povray.org...
> Here is just a quick try to implement some of the comments (trees
disabled).
> Bumpiness of the watersurface is much lower and a tint of red is added to
> the horizon. Much better in my opinion, especially the water. Thanks for
the
> hints!
Much better now.
Maybe the sun itself should be a little bit orange
and the water a little less bumpy, but it's just my opinion.
It's getting better and better.
Would be too much to ask for a 1024x768 version
when you'll finish your image?
See you.
Txemi Jendrix
http://www.txemijendrix.com
Subject: Re: Evening at the River
Date: 9 Nov 2002 12:51:42
Message: <3dcd4b2e$1@news.povray.org>
very nice work. my two comments are that the darks don't seem dark enough
and the water is too rough. A wide slow river would seem to not have such
waves, atleast not i all the parts. for instance if the wind is from the
right, the right part of the river would be calm, blocked from wind. but
this is very picky, only because its such a nice scene. i mean, those trees
are excellent.
Christoph Gerber <ni.### [at] bluewinch> wrote in message
news:3dcc2787@news.povray.org...
> This scene is derived form my Elevado scene posted a few days ago. It
> contains more than 15'000 mesh trees. The river terrain is a one of the
> samples coming with World Machine. Except the number of trees this is a
> quite simple scene. Nevertheless it took almost 30 hours to render on a
1.7
> GHz PC with 500  MB of RAM.
> Regards, Christoph
Date: 9 Nov 2002 16:52:32
Message: <3dcd83a0@news.povray.org>
The code for the water uses variable reflection but is real simple
otherwise:
#declare WaterTex = texture {
  pigment {rgb 0.1}
  normal {bumps 0.05 turbulence 0.5 scale 0.3}
  finish {
    ambient 0.1
    diffuse 0.1
    reflection_min 0.0
    reflection_max 0.8
    specular 0.5
    roughness 0.01
    phong 0.5
    phong_size 200
Regards, Christoph
"Peter Popov" <pet### [at] vipbg> schrieb im Newsbeitrag
news:815qsu0042mami5pns81ii9jdfae3lohqt@4ax.com...
> On Sat, 9 Nov 2002 12:32:03 +0100, "Christoph Gerber"
disabled).
the
> >hints!
> Much better now (and yes, I know you'll put the trees back in :) ).
> The water still looks a little CG. Are you using fresnel reflection?
> Attenuation?
> Peter Popov ICQ : 15002700
> Personal e-mail : pet### [at] vipbg
> TAG      e-mail : pet### [at] tagpovrayorg
Date: 9 Nov 2002 17:47:25
Message: <chrishuff-A5C1AF.17470609112002@netplex.aussie.org>
In article <3dcd83a0@news.povray.org>,
 "Christoph Gerber" <ni.### [at] bluewinch> wrote:
>     reflection_min 0.0
>     reflection_max 0.8
You're using MegaPOV? Why?
It might benefit from conserve_energy being turned on, but I doubt it
will have much visible effect here.
http://tag.povray.org/
Date: 10 Nov 2002 08:58:03
Message: <79pssu0ois4jioc7d20kt097u6l029fi2q@4ax.com>
On Sat, 9 Nov 2002 22:52:23 +0100, "Christoph Gerber"
>otherwise:
I would suggest a few things:
1. Use POV-Ray 3.5 :)
2. Use fresnel reflection (coupled with a ior of 4/3) and
conserve_energy
3. The pigment is way off, water is normally perfectly clear with only
slight attenuation. Why don't you use something like pigment { rgbf 1
} and add attenuation to the ior (either fade_power 1000 or absorbing
media)?
These are realistic settings, try giving them a shot and see if they
make your scene look more real.
Date: 10 Nov 2002 10:42:26
Message: <chrishuff-C54E04.10420910112002@netplex.aussie.org>
In article <79pssu0ois4jioc7d20kt097u6l029fi2q@4ax.com>,
Agreed.
> media)?
Actually, a dark opaque pigment makes sense here, you usually can't see
through this kind of water unless you are right above a shallow portion,
and the scene is already slow rendering. I'd get rid of the ambient
though, as a rule I only use a non-0 ambient value for objects that are
supposed to glow.
Date: 10 Nov 2002 11:28:11
Message: <t62tsu4m6eq18omqjunq22lug2aji9a3pp@4ax.com>
On Sun, 10 Nov 2002 10:42:10 -0500, Christopher James Huff
Attenuation won't slow it down, but it adds more realism along the
shores and at steep angles of incidence.
>I'd get rid of the ambient though, as a rule I only use a non-0 ambient
>value for objects that are supposed to glow.
Agreed.
Date: 10 Nov 2002 12:19:42
Message: <chrishuff-8D0F13.12192410112002@netplex.aussie.org>
In article <t62tsu4m6eq18omqjunq22lug2aji9a3pp@4ax.com>,
Instead of an opaque texture? Yes, it will be slower. The attenuation
calculations themselves don't cost much, though they are quite a bit
more than just using a constant color value, but any transparency at all
will require tracing at least one refracted ray every time the water is
hit, and then the additional texture calculation of the ground under the
water.
The shores often don't slope gradually out of the water, in fact there
is often an overhang. It takes practice to see into the water in this
situation even when it is clear, and if the water is carrying lots of
silt, you often can't see your feet if you are wading. A nearly black
opaque texture is a decent time saving approximation for this type of
image, even if it won't look good close up.
Date: 10 Nov 2002 14:30:34
Message: <nsctsu0cr34dvmiv8bueqbcelom031meq1@4ax.com>
On Sun, 10 Nov 2002 12:19:24 -0500, Christopher James Huff
>water.
You're right, of course, it's just that I thought it was rgbf 0.1 in
the original post.
Date: 12 Nov 2002 04:12:07
Message: <cah1tuoljeft79a8q0f8a63hil60euc5ec@4ax.com>
On Fri, 8 Nov 2002 22:06:32 +0100, "Christoph Gerber" <ni.### [at] bluewinch>
I wonder how it could look under film exposure patch made recently by Karii.
ABX
