POV-Ray : Newsgroups : povray.binaries.images : POV-Ray vs. Lightwave image (16k + 20k) Server Time
15 Aug 2024 10:14:23 EDT (-0400)
  POV-Ray vs. Lightwave image (16k + 20k) (Message 1 to 10 of 20)
Subject: POV-Ray vs. Lightwave image (16k + 20k)
Date: 7 Jul 2002 16:37:53
Message: <3d28a6a1@news.povray.org>
I came across a Lightwave 7 review and it featured a picture to show
Lightwave's caustic capabilities.  The picture is fairly simple so I decided
to try and duplicate it in POV-Ray 3.5 rc6.  The first picture is from
Lightwave (in case it posts in reverse order, the one with the brighter
glass spheres) and the second picture is what I rendered.  The most notable
differences are caustics that appear on the blue wall (I don't know how they
achieved the caustics to appear white) and the subtle highlights and shadows
on the red wall in Lightwave's render (I'm not sure how to get that effect
either).  Oh yeah, and the light on the ceiling in my render does not appear
to be "in the ceiling" (although it is...it shows if I don't render with
radiosity) and the shadows aren't as soft.
-Paragon
Download 'draft.jpg' (17 KB) Download 'caustics_f_02_lightwave.jpg' (21 KB)
Preview of image 'draft.jpg'
Preview of image 'caustics_f_02_lightwave.jpg'
Subject: Re: POV-Ray vs. Lightwave image (16k + 20k)
Date: 7 Jul 2002 17:59:29
Message: <chrishuff-08D523.16570007072002@netplex.aussie.org>
In article <3d28a6a1@news.povray.org>, "Paragon" <use### [at] hostcom> wrote:
The metal balls in your image have a fairly blurry texture, the
Lightwave ones have barely any blur at all. The camera is slightly
off...look how the room corners meet the image corners in the Lightwave
room. Also, the POV room looks like it is about twice the size of the
Lightwave room, judging from the reflections...it looks like there is a
wall just behind the camera in the Lightwave room, and one twice as far
away in the POV one. And I think the POV glass objects look washed out
in comparison because the texture isn't entirely transparent...I like to
use a 100% transparent pigment and some attenuation or media in glass
materials.
As for the shadows...your area light might be half as big as it should
be. And it looks like you might have left the default ambient values in.
Source code?
Date: 7 Jul 2002 18:52:58
Message: <3d28c64a@news.povray.org>
"Paragon" <use### [at] hostcom> wrote in message news:3d28a6a1@news.povray.org...
decided
notable
they
shadows
appear
Don't know about Lightwave, but it could be that the light has a
"brightness" value over the "maximum". That way it makes the spot on the
wall white. Just a thought.
Date: 7 Jul 2002 19:22:30
Message: <3d28cd36@news.povray.org>
> materials.
Yeah, I blurred the reflection a little too much,  I'll have to fix that.
And the POV room is longer than the Lightwave room.  Actually, I don't know
how to adjust the camera properly so that I can get a good perspective in
such a small room.
> Source code?
I'll post in povray.text.scene-files.  If you can adjust and get better
results,
please post results (and adjusted settings).
-Paragon
Date: 8 Jul 2002 02:50:18
Message: <3d29362a$1@news.povray.org>
> from Lightwave (in case it posts in reverse order ..
It does come up reversed, but why?
Anyway I thought your picture was the lower one and I preferred the upper
one.. Now I see the upper one is yours, congratulations!  ;o)
Hugo
Date: 8 Jul 2002 10:09:39
Message: <3d299d23$1@news.povray.org>
What you can do for the back wall is use a plane with an interior texture
using the wall texture and for the exterior texture make it transparent so
you can see through it like a window and place the camera farther back.
"Paragon" <use### [at] hostcom> wrote in message news:3d28cd36@news.povray.org...
> such a small room.
Date: 8 Jul 2002 19:27:04
Message: <3d2a1fc8@news.povray.org>
"Paragon" <use### [at] hostcom> wrote...
decided
notable
they
Instead of using rgb<0,0,1> for your wall, use something not quite so
perfect, like rgb<0.01, 0.01, 1.0>.  The non-zero components for red and
green will allow the wall to show colors other than blue.
> either).
Did you enable reflection photons for the glass spheres and metal spheres?
Also, their spheres might have a bit more reflection.  You might also want
to consider the possibility that those "subtle highlights" might be
aretefacts (though the more likely scenario is internal reflection in the
glass spheres).
Your image is very nice, though!
-Nathan
Date: 8 Jul 2002 23:04:44
Message: <3d2a52cc@news.povray.org>
I use Outlook Express for browsing the newsgroups and when I attach files,
it orders them alphabetically them posts them in the reverse order.  I
always get this confused though.
Thanks!
-Paragon
Date: 8 Jul 2002 23:08:06
Message: <3d2a5396$1@news.povray.org>
> glass spheres).
Thanks for the comments and suggestions, learning POV-Ray is an ever growing
process for me.
-Paragon
Date: 9 Jul 2002 05:12:41
Message: <3d2aa909$1@news.povray.org>
decided
notable
they
shadows
appear
Personally I disagree that the "most notable differences are caustics"... I
think the most notable difference is the price of the software!!!!
LW = $1,595
POVRay = $0
I know which is best value for money!
Rarius
