POV-Ray : Newsgroups : povray.binaries.images : Some light tests with the RC (JPG 54Kb) Server Time
5 Jun 2026 22:25:28 EDT (-0400)
  Some light tests with the RC (JPG 54Kb) (Message 6 to 15 of 15)
<<< Previous 5 Messages Goto Initial 10 Messages
Subject: Re: Some light tests with the RC (JPG 54Kb)
Date: 26 Apr 2002 16:15:32
Message: <3cc9b564@news.povray.org>
Beautiful lighting, and the metal looks incredible. How slow was the render
when you got to the bolts? How many normal layers did you use?
 -Shay
Jaime Vives Piqueres <jai### [at] ignoranciaorg> wrote in message
news:3cc9a27e@news.povray.org...
Date: 26 Apr 2002 16:16:54
Message: <3cc9b5b6@news.povray.org>
More photorealistic than I have ever managed. Beautiful renders, and I for
one am eagerly awaiting these lighting macros.
All the best,
Andy Cocker
"Jaime Vives Piqueres" <jai### [at] ignoranciaorg> wrote in message
> Hi All:
>   Here is a test of my lighting macros with the last beta. It uses only 32
> samples for focal blur, so it is a bit grainy (tracing now at 64). There
is
> no rad nor caustics, but there are 2 area_lights.
>   I also used this scene to test averaged micro-normals (metals) and the
> function image pattern (wood table). Some more shots, with diferent
> lighting conditions and different metals:
>   http://www.ignorancia.org/images/boltstill.jpg
>   http://www.ignorancia.org/images/boltstill2.jpg
>   As always, criticism is accepted and expected.
> La Persistencia de la Ignorancia
Date: 26 Apr 2002 16:40:20
Message: <3cc9bb34$1@news.povray.org>
The grainyness really looks fine to me! ABSOLUTELY STUNNING!!!!
(I almost hear the high, metally "tling!" sound of that little metal ring)
What's that micro-normals all about? Did you do this all in povray? I'm not
asking for source (yet), but I'd like to know HOW you did those
micro-normals.
Keep up the good work!!!!
Apache
http://geitenkaas.dns2go.com/experiments/
apa### [at] yahoocom
Date: 26 Apr 2002 16:46:45
Message: <3cc9bcb5$1@news.povray.org>
I'm loving that wood texture. How did you make that?
- Slime
[ http://www.slimeland.com/ ]
[ http://www.slimeland.com/images/ ]
Date: 26 Apr 2002 19:03:35
Message: <3cc9dcc7$1@news.povray.org>
Jaime Vives Piqueres wrote:
> Hi All:
is
Fan-Bleepin-Tastic.
I wanna see the 64 sample versions :P
Is the wood texture procedural or is it an image_map?
-Jide
Date: 26 Apr 2002 23:54:50
Message: <3cca210a@news.povray.org>
Maestro! <kneels and worships>  ;)
Sweet, Jaime. I hope I can do some more testing of your macros this week. :)
Date: 28 Apr 2002 05:51:39
Message: <3ccbc62b@news.povray.org>
Hi again:
  Thanks to everyone for the compliments, tough most of the merit must be
given to the POV Team: they have done a fantastic job with 3.5.
  I finally managed to finish the 64 blur_samples version:
  http://www.ignorancia.org/images/boltstill3.jpg (124Kb)
  Anyhow, the result isn't much better. There is still some grain on the
metal, but it's mainly due to the technique used for the texture. To avoid
making a lot of replies to this thread, here a little explanation:
  + The metal texture is a simple, one-layer texture: it does not use the
nice "averaged reflections" trick. Rather, it uses an averaged pigment_map
used as normal pattern, wich mix rotated versions of a quilted pattern
scaled down very small, with some other (granite and bozo) scaled not so
small. This of course needs a lot of blur_samples or very high aa settings,
and it's slow, of course (the whole image took about 5 hours on a Athlon
1.2Ghz).
  + The wood texture it's a standard one from "woods.inc", with some
reflection added. The real trick is that it is applied to a thin
height_field done with the function image pattern. This function uses a
pigment_map of several woods and a turbulent leopard pattern. It's a bit
slow to parse for a decent hf resolution, but it traces really fast.
  + Yes, this is done entirelly with POV-Ray! Well, I used Imagemagik to
adjust a bit the contrast, but that's all.
  Appart from this, I've lied on my first post: there are 3 area_lights,
not 2 as I stated. And they are placed randomly! I suspect I'm getting
really lazy, if I use rand()+trial&error even for the lights placement!!
Date: 28 Apr 2002 11:22:08
Message: <3ccc13a0$1@news.povray.org>
Hi James,  :o)
I actually thought the wood was an image_map, since it looks so realistic! I
also thought you used a specular map, but no?
I especially like "boltstill2" because of the cleaner look. It's a challange
these days to have *clean* CG objects that *also* looks realistic. Your
metal texture is brilliant! How is the surroundings? Empty? To use a quilted
pattern never striked me. Do you think these micro patterns are too slow for
general purpose? Obviously, render speed is the biggest limitation in todays
3D, and I doubt this will change soon.. I'm trying to gather knowledge about
the best looking, AND fastest methods.
Do you think these special textures work in other enviroments without
tweaking? I experienced this myself at my recent attemps to imitate realism.
My settings didn't look good in other scenes - and rendering almost died.
Way too slow.
Btw, when you use the names "bolt-STILL" does this means you're planning
animations? Just curious. Not that I see a big potential for animating
*these* particular scenes.
Okay, that's all.  ;o))
Hugo
Date: 29 Apr 2002 06:36:07
Message: <3ccd2217@news.povray.org>
  It's better than an image_map, but only for planar surfaces (hf),
although it can be done with isos for any shape (i.e. isowoods from
Christoph).
> Your metal texture is brilliant! How is the surroundings?
  The enviroment is a simple 5x5m room with hf-walls, a white ceil and a
checkered floor.
> To use a quilted pattern never striked me. Do you think these micro
> patterns are too slow for general purpose?
  Yes, the use of the quilted patern for this isn't very obvious. It works
well because I average multiple rotated copies. I found that simply by
using the old & good "trial&error" method with all patterns. :)
  The "micro patterns" (paterns scaled lower than pixel size) are slow, no
doubt. As with the "averaged reflections" trick, it depends on the number
of patterns averaged, but it's not so slow, as it only averages normals.
However, you need to use much higher quality settings on aa or focal blur
to get ride of the grain. So finally, it's hard to tell wich method is
slower... :(
> tweaking?
  Well, I'm lately trying to make things valid for any situation. For
example, this texture works with surfaces oriented in any direction (the
bolts and nuts shapes demonstrates this), because the normal averages
multiple rotations of the same "micro pattern", in the hope to face any
posible surface. For the rest of the texture, it is simply "T_Chrome_2C",
so it must work on any scene, I think.
> animations?
  :) Not really... my relation with animations is view-only. I fear all the
work and organization involved on good animations (that is: I'm really
lazy). The name comes from the fact that I'm managing the idea of making it
more like a tipical "still life"... replacing the fruits with different
kinds of bolts and nuts...
  Will see, I've too many projects pending... :(
Date: 3 May 2002 23:49:20
Message: <3CD35A40.B0D300C6@iki.fi>
I find it hard to believe it's CG picture. Amazing work of art!
          /"\                           |    iki.
          \ /     ASCII Ribbon Campaign |    fi/
           X      Against HTML Mail     |    zds
