POV-Ray : Newsgroups : povray.binaries.images : Turbulent Isosurface box? Server Time
15 Jul 2026 18:44:46 EDT (-0400)
  Turbulent Isosurface box? (Message 6 to 15 of 25)
<<< Previous 5 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Turbulent Isosurface box?
Date: 23 Mar 2002 12:05:15
Message: <3C9CB5CA.CA4992BB@gmx.de>
Patrick Dugan wrote:
> That type would certainly be close. I am looking for a more "slate
> like"/"platey" appearance but that might get me started.
> Can you be more specific about the function?  I have tried the function but
> simply end up with a "rounded box." I tried:
>   isosurface {
>      function {f_rounded_box(x,y,z, 0.25, 0.25, 0.25, 0.25) }
>      pigment{Red}
>      scale 0.5
> I'm no math whiz so I'm really not certain what the last four values should
> really be.  I've tried various values but always end up with a simple
> rounded box.  How do you get yours to look so randomish?  I even tried using
When looking for 'f_rounded_box' in the docs you get:
f_rounded_box(x,y,z, P0, P1, P2, P3).
The Rounded Box is defined in a cube from <-1, -1, -1> to <1, 1, 1>.
By changing the " Scale" parameters, the size can be adjusted,
without affecting the Radius of curvature.
P0 : Radius of curvature. Zero gives square corners, 0.1 gives corners
that match "sphere {0, 0.1}"
P1 : Scale x
P2 : Scale y
P3 : Scale z
If you add/subtract a noise function to the box this should probably
achieve what you want, something like:
f_rounded_box(...) - f_noise3d(x, y, z)*0.2
(see docs section 3.6.3.6)
And you should add an appropriate container and max_gradient to the
isosurface.
Last updated 18 Mar. 2002 _____./\/^>_*_<^\/\.______
Date: 23 Mar 2002 12:12:41
Message: <3c9cb789@news.povray.org>
Well I have read the tutorials and attempted to create "something" that I
was pretty certain
would make a rough box shape.  Instead it is perfectly square.  For example:
 isosurface {
     function { f_rounded_box(x,y,z,0,1,1,1) - f_noise3d(x*5, y*5, z*5)*
0.25 }
     pigment{Red}
     scale 0.2
I wanted a sharp cornered rounded box with some turbulence to it. I felt the
second function
f_noise3d(x*5, y*5, z*5)* 0.25
(shown in the tutorial under the sphere example) should do what I wanted.
From the tutorial it
seemed to be the most likely function, but it apparently isn't.
news:3C9CACC2.D0857FB6@gmx.de...
> > How do/can you make a isosurface box that has a "rough" surface?
> Have a look at:
> http://www-public.tu-bs.de:8080/~y0013390/pov/wtunnel.html
> for an example (note this is megapov syntax).
> The isosurface tutorial in the Povray 3.5 docs should also give sufficient
> explanation how to add 'roughness' to a shape.
> Christoph
> POV-Ray tutorials, IsoWood include,
> TransSkin and more: http://www.tu-bs.de/~y0013390/
Date: 23 Mar 2002 12:17:54
Message: <3C9CB8C2.E4D0FC55@gmx.de>
>  isosurface {
> 0.25 }
>      pigment{Red}
>      scale 0.2
As said in the other post you need an appropriate container object.  In
your example all surfaces are outside the (default) container, therefore
you only see the container itself.
Date: 23 Mar 2002 12:18:33
Message: <3c9cb8e9@news.povray.org>
I tried:
 isosurface {
     function { f_rounded_box(x,y,z,0,1,1,1) - f_noise3d(x, y, z)* 0.25 }
     contained_by { box { -1 , 1} }
     pigment{Red}
     scale 0.2
but this yields a perfectly square box.  No roughness at all.  Would the
max_gradient make or break this?
news:3C9CB5CA.CA4992BB@gmx.de...
but
> >   isosurface {
> >      pigment{Red}
> >      scale 0.5
should
using
> P1 : Scale x
> P2 : Scale y
> P3 : Scale z
> isosurface.
> Christoph
Date: 23 Mar 2002 13:07:28
Message: <3c9cc460$1@news.povray.org>
"Patrick Dugan" <pat### [at] netinsnet> wrote in message
news:3c9c9e4e@news.povray.org...
> I have a (poor) image I made by hand of a "turbulent" box shape.
Basically
> I am trying to
> make boxes that look like randomly made rectangular stones that have been
> placed within
> a stone wall (like a fireplace) but have been chipped to be somewhat
> rectangular so they
> can be placed somewhat close together.
    I was just doing that too after talking to Tom about stone walls and
talking to my lovely wife about the stone wall we want in the front yard.
Here's what I've got so far, there are some odd things in it from left over
experiments but I think the basics are there. Hopefully it doesn't wrap
funny...
////////////// Camera //////////////////////
camera {                                  //
        right      <  1.333, 0.0, 0.0 >   //
        up         <  0.0, 1.0, 0.0 >    //
        direction  <  0.0, 0.0, 1.0 >     //
        location   <  3.0, 3.0, 7.0 >
        look_at    <  0.0, 0.0, 0.0 >     //
////////////// end Camera //////////////////
///////////////  Light  ////////////////
light_source { < 1000.0, 1000.0, 1000.0 >
color rgb < 1.0, 1.0, 1.0 > }
#declare Rock=function{
                 pigment{
                         crackle
                         turbulence 0.25
                         color_map { [0 rgb 1] [1 rgb 0] }
                         scale < 0.5, 0.25, 0.5 >*3
#declare Wall1 = function { max((x*x*x-1),(y*y-1),(z*z-1)) }
#declare RockWall =
           isosurface {
              function {
                         Wall1(x,y,z)
                        +Rock(x,y,z).x
                        *0.5
              contained_by { box { <-8.0,-1.5,-1.5 >,
                                   < 8.0, 1.5, 1.5 > }
              accuracy 0.0001
              max_gradient 25
              pigment { rgb 1 }
              finish  { ambient 0.125 }
              translate < 0.0, 0.0, 0.0 >
 object { RockWall }
Download 'RockWall02.jpg' (15 KB)
Preview of image 'RockWall02.jpg'
Subject: Yes! Re: Turbulent Isosurface box?
Date: 23 Mar 2002 14:30:09
Message: <3c9cd7c1@news.povray.org>
Yes!  Thank you!
 isosurface {
     function { f_rounded_box(x,y,z,0,0.75,0.75,0.75) - f_noise3d(x, y, z)*
0.25 }
     max_gradient 0.5
     pigment{Red}
     scale 0.2
I made the function smaller than the box and finally got something like I
want.
(I'm sorry I'm so dense about this.)
news:3C9CB8C2.E4D0FC55@gmx.de...
> >  isosurface {
> > 0.25 }
> >      pigment{Red}
> >      scale 0.2
> Christoph
Subject: Final "Rock"
Date: 23 Mar 2002 14:56:28
Message: <3c9cddec@news.povray.org>
I tweaked it some more and finally got this:
 isosurface {
     function { f_rounded_box(x,y,z,0,0.85,0.85,0.85) - f_noise3d(x*5, y*5,
z*5)* 0.05 }
     max_gradient 25
        gradient y
        color_map {
           [0.00 color Gray90]
           [0.20 color Gray30]
           [0.40 color Gray80]
           [0.60 color Gray20]
           [0.80 color Gray10]
           [1.00 color Gray80]
        turbulence 0.75
        scale <1,0.1,1>
     finish {ambient 0.4}
     scale <0.3,0.1,0.3>
That was the look I was trying to achieve.  Thanks for your help!
> >  isosurface {
> > 0.25 }
> >      pigment{Red}
> >      scale 0.2
> Christoph
Subject: Re: Final "Rock"
Date: 23 Mar 2002 15:49:06
Message: <3c9cea42@news.povray.org>
this is the code i used.  scaling the wrinkles pigment gives different
'smoothness' of bricks.  i guess granite or bumps would do just as well.
the random seed also makes sure every brick is different.  you could also
try messing around with the gray value.
john
#declare f_rounded_box = function { internal(60) }
#declare rndm = seed(14577);
#macro aBrick(Seed)
#local W1 = function { pigment {wrinkles scale 2.5 translate
<Seed,Seed,Seed> } }
 isosurface {
 function { f_rounded_box(x,y,z,0.01,1.5,0.7,0.3) - W1(x,y,z).gray*0.65 }
 threshold 0
 max_gradient 1.7
 accuracy 0.01
 contained_by { box {<-2,-1,-1>,<2,1,0>} }
 scale 10
 pigment { rgb 0.975 }
 finish { ambient 0.1 diffuse 0.8 reflection  { 0 }specular 0.1 roughness
0.005 }
#declare yC = 0;
#while(yC < 50)
 #declare xC = -50;
 #while(xC < 50)
  object { aBrick(rand(rndm)*999999) translate <xC,yC,0> }
  object { aBrick(rand(rndm)*999999) translate <xC-16.5,yC+18,0> }
  #declare xC = xC + 33;
 #declare yC = yC + 36;
    location <50,50,-150>
    look_at <0,25,0>
 light_source { <100,50,-200> rgb 1 }
news:3c9cddec@news.povray.org...
>  isosurface {
y*5,
> z*5)* 0.05 }
>      max_gradient 25
>       pigment {
>         gradient y
>         color_map {
>            [0.00 color Gray90]
>            [0.20 color Gray30]
>            [0.40 color Gray80]
>            [0.60 color Gray20]
>            [0.80 color Gray10]
>            [1.00 color Gray80]
>         turbulence 0.75
>         scale <1,0.1,1>
>      scale <0.3,0.1,0.3>
> "Christoph Hormann" <chr### [at] gmxde> wrote in message
> > >  isosurface {
z*5)*
> > > 0.25 }
> > >      pigment{Red}
> > >      scale 0.2
> > Christoph
Download 'wall.jpg' (19 KB)
Preview of image 'wall.jpg'
Date: 23 Mar 2002 15:53:36
Message: <3c9ceb50@news.povray.org>
i had to set the light source to be a really high rgb value.  for some
reason i had to also put a plane behind the stain glass or it just came out
looking dull.  heres a 'makeshift' bit of code.
john
global_settings {
    ambient_light rgb 0.0
    max_trace_level 10
    radiosity {
      pretrace_start 0.08
      pretrace_end   0.02
      count 100
      nearest_count 8
      error_bound 1.15
      recursion_limit 6
      low_error_factor 0.6
      adc_bailout 1/255
      gray_threshold 0.05
      minimum_reuse 0.015
      brightness 0.125
      max_sample -1
      normal on
media {
    intervals 50
    scattering { 2, rgb 0.005 }
    samples 1, 5
    confidence 0.95
    variance 1/128
    ratio 0.9
#declare Dull = finish { ambient 0.05 diffuse 0.3 reflection 0.0 specular 1
roughness 0.001 }
#declare Cutty =
union {
 box {<-15,-40,-2>,<15,0,2>}
 intersection {
  cylinder {<-10,0,-2>,<-10,0,2>,25}
  cylinder {<10,0,-2.1>,<10,0,2.1>,25}
difference {
 box {<-210,-110,31>,<210,130,-340>}
 box {<-200,-50,29>,<200,125,-330>}
 object { Cutty translate <0,40,30> }
 pigment { rgb 1 }
 finish {
  ambient 0.1
  diffuse 0.8
  reflection  { 0 }
  specular 0.1
  roughness 0.005
 normal { granite 0.2 scale 1 }
 box {<-16,-1,30.5>,<16,70,30.6>
  image_map { gif "bruce4.gif" interpolate 2 filter all 0.6}
  translate <-0.5,0,0>
  scale <32,75,1>*0.8
 finish { Dull }
    perspective
    location <85,-30,-190>
    direction <0,0,1.5>
    look_at <-55,0,30>
 light_source { <0,60,-260> rgb <1,0.5,0.2>*0.4 media_interaction off  }
 light_source { <0,1200,2000> rgb 25 }
 background { rgb 1 }
 plane {<0,0,1>,2100 hollow pigment { rgb 0.05 } finish { Dull }}
/////////////////// the end
"Alastair Murray" <ala### [at] hotmailcom> wrote in message
news:3c9cab9b$1@news.povray.org...
> How did you get the light to shine through the dust like that?
> Sources would be incredibly useful.
> "John & Amy Robinson" <jro### [at] columbusrrcom> wrote in message
> news:3c9ca1c3$1@news.povray.org...
> > Basically
> > > I am trying to
> been
> > > placed within
> > > rectangular so they
> > i used the f_rounded_box function for the walls in this image
> > http://www.fishinglog.com/Art/bigThe%20Keep.html
Download 'light.jpg' (9 KB)
Preview of image 'light.jpg'
Date: 23 Mar 2002 16:31:33
Message: <3c9cf435@news.povray.org>
Bill, that looks about perfect for the type of walls you see along highways (where
they've cut through hills). Evaluating the
pigment
properly might be problematical, but I think there's a use for what you have here.
Salute,
Grim
