POV-Ray : Newsgroups : povray.binaries.images : Impossible triangle Server Time
13 Jun 2026 10:48:44 EDT (-0400)
  Impossible triangle (Message 7 to 16 of 26)
<<< Previous 6 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Impossible triangle
Date: 6 Jul 2001 18:02:36
Message: <3b46357b@news.povray.org>
Thomas Lake <tla### [at] homecom> wrote:
: The big block in the background is actually the same size as the blocks in
: the triangle?
  Nope. It's truely bigger (in fact, exactly 6 times).
Date: 6 Jul 2001 21:28:57
Message: <3b4665d9$1@news.povray.org>
The shadows go the opposite direction to the visible light source??
Nice pic btw :)
Dave
news:3b45f0cf@news.povray.org...
>   The impossible triangle with cubes was first invented by the
> Swedish artist Oscar Reutersvard back in 1934.
>   This image has two tricks. The first one is obvious (the triangle). But
> there's another trick which may not be obvious. Can you guess what it is?
Date: 7 Jul 2001 06:18:31
Message: <3b46e1f6@news.povray.org>
Davey B <kry### [at] totalisecouk*nospam*> wrote:
: The shadows go the opposite direction to the visible light source??
  Nope. There are two light sources, and nothing special is related to them.
Date: 7 Jul 2001 07:12:05
Message: <MPG.15b10d2958944fcf9897f3@NEWS.POVRAY.ORG>
In article <3b463501@news.povray.org>, Warp says...
> Sander <san### [at] stolscom> wrote:
> : The image wasn't done with POV alone, but you used some image editor,
> : right??
>   A suggestion like this is a great offence. I would never go that low!
>   The image is made entirely with (hand-coded) POV-Ray code and one render,
> and no external files. All the objects in the image are real 3D primitives
> and all textures are regular POV-Ray procedural textures (eg. no image maps
> nor anything).
No offence meant and intended: I stupidly forgot the :) in my reply.
When I look at the left vertical vertices of the vertical stack of cubes
I get the impression that there is a lack of AA, as if these cubes have
been cut out and pasted. That made me make my offensive remark...
But I suppose there are other reasons for this to happen :))))
Regards,  Sander
Date: 7 Jul 2001 07:27:53
Message: <MPG.15b110e2c50c9aae9897f4@NEWS.POVRAY.ORG>
> nor anything).
You have used an orthogonal camera?
Regards,  Sander
Date: 7 Jul 2001 07:33:08
Message: <MPG.15b112189ee6105a9897f5@NEWS.POVRAY.ORG>
In article <MPG### [at] NEWSPOVRAYORG>, Sander says...
> > nor anything).
If I draw a triangle called A aroud the "impossible triangle" and I
rotate a copy of this triangle, called B, 120 degrees, B nearly
perfectly overlaps A. This can only be so if you use an orthogonal
camera, right?
Regards,  Sander
Date: 7 Jul 2001 08:14:47
Message: <MPG.15b11bdeb37024f99897f6@NEWS.POVRAY.ORG>
> nor anything).
If you call the four "vertical" cubes for the sake of argument from top
to bottom a, b, c, and d, then c throws a shadow onto d, but a does not
onto b and b does not onto c. This is unreal, so here must lie the
sulution. I still don't see it, however. Clever!
Regards,  Sander
Date: 7 Jul 2001 08:16:55
Message: <3b46fdb6@news.povray.org>
: If I draw a triangle called A aroud the "impossible triangle" and I
: rotate a copy of this triangle, called B, 120 degrees, B nearly
: perfectly overlaps A. This can only be so if you use an orthogonal
: camera, right?
  You are getting closer.
Date: 7 Jul 2001 08:17:40
Message: <3b46fde4@news.povray.org>
: If you call the four "vertical" cubes for the sake of argument from top
: to bottom a, b, c, and d, then c throws a shadow onto d, but a does not
: onto b and b does not onto c. This is unreal, so here must lie the
: sulution. I still don't see it, however. Clever!
  I just applied no_shadow to some of the cubes to avoid annoying shadows.
Date: 7 Jul 2001 09:57:01
Message: <3b47152d@news.povray.org>
news:3b46fdb6@news.povray.org...
> : camera, right?
      From what I remember of this triangle, it's the angle that it's viewed
at that produces the illusion. I suspect that if you change the camera angle
on this image, you would have an entirely different view of it, ie,
something like two upright bars at opposing 45 degree(?) angles, at the end
of a horizontal bar at the base?
      Close Warp?  It's doing my head in!  ;)
       Great image though.
    ~Steve~
